Best budget rail running headlamp for 2018?
Hello J.Gramm, and welcome to BLF :wink:
I don’t have an exact answer for you regarding headlights but I have a suggestion! Please check this thread to see some information of headlights :wink:
BTW, Nitecore has some nice headlights, Lumintop has new one, and there are other brands with very good models!
I hope it helps :wink:
it sounds like you will need an 18650 head lamp. I run with my skilhunt h03 and find it light and very useful. I have used it on trail running for the last couple of seasons. It will run at 500 lumens for at least three hours with no issues. When I do not need as much light for a shorter period of time I use my thrunite TH20.
I also use a zebralight on occasion but always go back to the skilhunt.
also remember if using the light in extreme cold is an issue, the skilhunt can use cr123 cells.
I recommend the Armytek Wizard Magnet USB with XP-L LED (NOT the more expensive XHP50 version, it’s too floody). It has an almost perfect beam for running and has all the features and comfort you could ever ask for. If you search around for a good deal you should be able to get it for a fair price ( ~60$ is good).
The beam is so good because of the TIR lens with built-in hexagonal diffusor. In combination with the correctly sized LED it produces a very good beam for running. There is no real hotspot. It’s just brighter in the center. Ther is no “bouncing spot effect”, no tunnel vision. The spill does not have a hard outer edge like some reflector lights have. This also reduces the tunnel vision effect.
It produces 390 lumens for 3.8h on one 18650 (second highest mode). I consider this mode the best one for running. It’s bright enough. There is also a warm-neutral white version which is slightly less bright.
Because of the Buck-Boost-driver it also works better in winter when it is cold compared to other headlamps. It will keep the brightness constant even when the battery has a reduced voltage because of the cold. The integrated over discharge protection also allows you to use unprotected high-drain cells like the Samsung 30Q. These offer much better performance in cold temperatures compared to standard high-capacity cells.
The current Amrytek headlamps have a new plastic holder which is much better compared to the older style silicone holders. They are very comfortable (ergonomic shape) and the light doesn’t wobble at all when running. It also allows you to instantly remove the light for hanging the headband out to dry or when you want to use the light handheld (it’s also a very practical edc flashlight). You can also easily adjust the angle of the light in the holder with one hand.
The included magnet USB charger allows you to charge it on the go with any usb charger you have on hand (it’s pretty slow though).
I know only one headlamp with an even better beam for running: the Olight HS2. At the same ~400 lumens it has an even wider spill and also more throw. But there are lots of tradeoffs. It has less modes, the driver buzzes next to your ear, it doesn’t use 18650s, no 1000 Lumen turbo mode, wobbles a little bit, a bit more expensive, cannot be used as a flashlight etc.
Love my Nitecore NU30, super lightweight, but its only 400 lumens for 1hr 15min. with its built in battery. That said you can plug any powerbank into it and run it off of that too. So you could decide on a lightweight powerbank attached to the headband or run a longer lasting heavier one out of your pocket/pack for an all-nighter. I know its pretty far off from your requirements but for $30 it might be worth a look for ya. Welcome to BLF!!!
Skilhunt H03 NW. No contest. I use mine for climbing at night and trail running, and they are awesome. I own 4 of them and love them all.
Definitely look at the skilhunt H03. Also look at the wowtac A2S, which is similar to the H03 but with a reflector instead of a TIR. It has about twice the beam intensity as the H03 and should be a closer match to the BLF A6 beam profile.
These lights are pretty light weight and the weight is located pretty close to the head. I just tried my H03 while running around my apartment and it didn’t flop around much as long as the strap was tightened adequately.
angle lamp does not need on your headm you can also clip it to your belt
It can’t compete with the Skillhunt H03 on value and it does have a custom battery, but for minimal weight up front have a look at the Olight HS2.
https://olightworld.com/olight-hs2
For your next drunk run.
Panasonic NCR18650F are good low-temperature cells. Except for truly extreme weather they should do better than CR123.
I have both Pro XHP50 and non-Pro XP-L version, and find the Pro much preferable - way more useful UI with separate circling through 3 firefly and three main modes, buck-boost fully regulated with constant output , more modes, lower firefly and higher turbo…… To me it is well worth the higher price. :slight_smile: Both with TIR, neither does appear more floody to me.
If you put both lights in 60min or even 4h mode (running takes too long for 20min mode of the pro), the XP-L version has more throw than the XHP-50 version because the LED is half the size and the lumens are similar. To me it makes a difference for running.
Do you have the current version of both lights? Why is the UI of the XP-L version different?
The XHP-50 has a boost driver, not buck boost (XHP-50 runs with 12V in the light).
The XP-L version has a buck-boost driver (see footnote here).
Wowtac A2S High(460 lumens/4.5 hrs) and only $30
Much, much obliged you guys, awesome data. It seems like the Skilhunt is leading for now with the Armytek in close follow but a bit pricey where I live and can’t seem to find it the Chinese Sources I know of. All it takes now is to snipe a banggood sale for the Skilhunt when it comes around, too bad I smashed all of my points on batteries by the end of the year.
Although I see that Olight locally at the same price as Skilhunt on BG. Has anyone done a teardown of that battery pack? I can always fabricobble together an alternate pack if need be but I’d rather just replace the battery itself.
Ah and thanks for the cold weather 18650 tip, it is priceless - my A6 almost died in 15C when I was escorting a lost soul back to a mountain hut in the middle of the night every damned headlamp on everyone crapped out (strong wind, alkalines and eneloops decided to hibernate) and that A6 was a lifesaver.
I run on the road with a club, and something I have noticed is that many of the runners, ladies in particular (I have no idea why) run with a headlamp on their waist. It gives great foot illumination. Not suggesting this is ideal for you (clearly not a good idea as sole illumination on a trail), but it gives an option for extra illumination, and you might get away with a heavier lamp here, depending how mounted.
Actually now that I think about it, maybe women look at each other more when they talk, and wear them low to avoid blinding each other.
If you are used to an A6, you are a bit spoilt, headlamps suffer a bit in comparison to that I think. The H03 is certainly the most recommended headlamp here at BLF, mine is still in the post. For really budget lamps the Boruit RJ02 at $7 or so is an eye opener, love mine, but the strap is heavy and based on smelly rubber, also on a trail run you will lose the USB cover unless you glue it on.
A waist mounted light gives you better depth perception because it will actually create shadows. The problem is the wobble. Your waist moves left to right when you’re running (also up and down a lot depending on how good your technique is). Also when you look to your sides you won’t see much.
Oh the Boirut, that name rang a bell and I wondered why.
Turns out I ordered it last Friday around 2:30 AM. It is so nice of me to think about me when I am blind drunk! (One might see a pattern here.)
Waist light does indeed sound alright for road running but two lamps and two power sources is a bit heavy even for me, but sometimes I do think about mounting a cheap Xanes bike light with a single 18650 onto my running vest for longer distances as a secondary light but it draws 1.1A and I find it hard to power it properly and provide proper heat dissipation to the module of choice. Anyhow, I never wear that vest below 15k of trail so it is on hold as most of my reasonable tinkering projects.
A6 is indeed an overkill for running 98% of time so I am fine with sacrifices. But dual wielding two of them on the sides of my backpack straps makes me feel like a Wyatt Earp of trollhunters in the mountains, that’s for sure. Necessary? No. Awesome? Ah yes, quite a bit.
Good day,
my personal choice of Imalent HR20W
Pavol
I usually run with a floody 18650 light in-hand, but had a similar need for a running headlamp (though my requirements are different), and after quite a bit of research I went with the Olight H1. I got it today and already tried it out so I’ll post the whole story together with some impressions.
What I wanted:
- something above 100 lumen for 2 hours. It may seem on the low side, but once the eyes have adjusted I find it enough for most situations even when going downhill fast
- a light with no top strap ( I hate them! ) that would not bounce around when running fast / jumping above creeks or other obstacles
- decent tint, I don’t think this needs any explanation :smiley:
- a floody beam so that there would not be an hotspot bouncing around or blinding me when I tighten my shoelaces
  • IPX7 or better so I don’t have to worry about the weather
The main problem was finding a light that didn’t bounce around. I already had a Thrunite TH20 and that was unusable, the main problem is it’s heavy and sits far from the head giving it too much leverage. So I looked for a light that was lightweight and had its center of mass close to the head. I narrowed it down to the Olight and the Nitecore NU20 CRI, but the Nitecore had limited runtime and lacked swappable batteries.
Here you can see how it sits in its holder basically as close to the head as it is possible.
So I got the Olight, here’s what I like and what I don’t:
LIKE:
- lightweight enough not to bounce around at all
- though it is 70cri, the tint is consistent throughout the beam, slightly rosy and overall pretty good
  • 16340 batteries are so small I can easily carry a spare in the mini-pocket most running pants have for car keys and not notice it
DISLIKE:
- the button is flat and only activates when pressed in the center, basically unusable when running fast
  • depth perception is definitely a problem, I really felt less capable of gauging step distances during fast downhill sections and overall I feel my performance was lower than usual
So overall I think this is almost as good as it gets for my needs, and allows me to keep my hands free if I want to do mixed training.
But I will keep bringing an 18650 handeld like my E2L on more serious runs.
That Olight does indeed look awesome. So far I went with Skilhunt and Boirut. Tested the Boirut twice already - well it is a damn spectacular light for it’s price and the light is almost enough - I had two ankle crashes with some branches I didn’t see on the trail, but otherwise it is nearly sufficient. I finally got some snow over here so next test is to see how it performs in sub zero and with nice reflections from the general snowiness. Skilhunt is still on it’s way to me.
And yeah, the top straps are annoying but I can live with them if I have to.
And you are correct with the depth perception, I recently ran along some tractor trails, and once they got frozen solid it was probably the toughest terrain I ever ran on, twisting my ankles randomly on every step. Seems like I will need to carry the A6 on my running belt as a backup after all.
