If no mod the battery carrier, Keep 2S2P.
Can be used in 6V for XHP50 or XHP70?
You need to use a simple fet driver , the Mf-01 driver lexel builds can be used .
2S/2P carrier and 6V LED can be used with normal parts up to 5A with lowered buck frequency
with upgraded parts about 8A
of course this might be well enough for a XHP50.2, but rather poor for a XHP70.2
Those are the currents to stay safe well within specification of the parts, of course it is possible to get out more but then no guarantee to operate without any issues over a long time,
if you want it just lower the sense resistors as usual for buck/boost drivers
Im definitely interested in a driver for the MF02, i have on on the way.
The first boards have arrived
been busy yesterday and today
12 MF02 2.5A drivers
2 MF02 6A
1 TN42 and
1 TN40 12V 8A
I think this should show the carrier modification pretty well
added Haikelite MT07S XHP35/XHP70 driver
I made a 30mm layout that could be extended in my board program to the nessesary size or grinding down the 42mm TN42
The Curoi should be 38.5mm, if the edge clearance is small the TN42 could fit
I PMed everyone that was replying in this topic if I missed you please PM me
Hi Lexel. I guess you received my payment for two drivers, just cant see my name on your spread sheet. I slipped you a couple of dollars extra so all should be good here.
you are on the spreadsheet in line 70
So I did further testing of the drivers
With 2.5A Output I get on my bench test LED XHP70.2 12.31V
This means 31.02W output
to get this output the driver draws 2.075A at 16.14V
33.49W
so we ge an efficiency of 92.6% for turbo
Sounds pretty good to me Lexel.
Hey blf, we are going to mod the astrolux mf-02 to the best… of course xhp35 hi. Which parts do i need to order ?? Do i need a new sink pad? Thanks
You can use old Sinkpad it is pretty good
Just the LED seems not to be pretty good flux bin looks from my measurements like a D2 flux bin
You need just the driver, maybe also interested in my 2x2 LED board that supports up to 4 different LED colors
I have MF02 coming, would like to do this mod. I also have electrical school baground and soldering irons etc home.
Still bit unsure what will I need? Is this bolt-on mod requiring only battery serial modification for 12V supply with new driver?
interested
Battery carrier needs mod as shown so from 7.4 to 14.8V
Then it is just replacing old with new driver
new boards shipped
yes they are……thank you Lexel
I’m in!!!for GT style driver…it should work just fine with my Mateminco MT35?
