Thanks a lot! I will try to grab it fast.
bilakos10: I would rather have 128GB version, if possible
Zanflare F1 $9.99 (Is there any chance to have this price again?)
KZ ZST Earphones
KZ Wireless Bluetooth
Thanks.
https://www.gearbest.com/led-flashlights/pp_647939.html?
Suggestion: wuben G339 light or something similar.Also an inexpensive 4 slot charger.
Lastly flashlight storage box.
Thanks
All of your requests have been noted.
I will try to fulfill them on Monday.
That’s OK.
I will try to get you a code for Monday.
I’m also interested for discount code 9.99 usd for F1 if possible.
thank you bilakos10 for all good deals
bilakos10: thank you very much!
wellerus: I don’t think we are getting any more of F1 (read a few pages back)
Active Deals
12/1/2018
Available for these countries:
HK,US,CA,MY,TW,GB,IE,AU,NZ,IN,SG,ZA,PH,GR,NL,HU,SK,CZ,HR,BG,SI,RS,TH,IT
Hello… I’m new here… I would Ike to get the lumintop…can I get a code for that one?.. Thank you
In which Lumintop model are you referring to?
The aaa ti one… I’m still learning how to navigate the blf…
All of my codes are available in the first page of my thread.
You can click on this link to get there: ☢ [Bilakos10 Premium Deals] ● Astrolux FT03 SST-40 ● Astrolux A01 UV ● Seeknite X6S ● JCD 8898 Hot Air Station ● SQ-D60
The link and code for the Tool Ti should be listed under 10/1/2018 Deals
What is this used for?
Heat shrink tubing shrinks in diameter when it is heated up.
Mostly use it to insulate electrical connections. It is also useful for bundling wires together.
Can be used for anything you can think up.
Works best with a heat gun but a lighter or a match will do if you don’t have one.
What is WLXY Sn63 / Pb37 Professional Solder Paste for?
Oh… I see… Its in blue under the pic… Lol… I told you I was a noob… Thank you
YooSin:What is this used for?
Thank you.
Do any of you have a link to silicone paste, used for putting on “screwing parts” of flashlights?
The solder paste is useful for reflowing LEDs on stars or soldering SMD parts.
It has the consistency of a thermal paste and once it’s heated it turns into regular solder.
You are welcome!
BLF is very easy to navigate through, so you should get used to it easily.
If you need any other kind of help you can ask me.
There is a nice discussion about o-ring/thread lubricants in here:
Hey guys, Any input? I have been using regular vaseline because I figured it will not harm human skin so it will not harm flashlights? Please advise. Thanks.
You are correct. It’s highly likely that there will be quite some time before I can score a great deal on the F1
The deals will be uploaded in 20 to 30 minutes.
Anybody around?
Active Deals
13/1/2018
Anybody around?
Me and the dogs. Chester puppy is up here in the loft with me.
