Boom! Nitecore’s TM handle, straightaway what I thought of when the thought of a handle was first breeched.
I had one for my TM36 Lite and it was a game changer. Should have kept it to use with the TM16 but it’s not as necessary on the more easily carried 16… the 36 shortie was a bugger to hold!
I wonder if it fits.
Should be reversed though, because the ‘engine’ with switch of the GT is very wide.
You’ll and up with the TM handle mounting somewhere in the middle of the battery tube, i guess…
But you can position it where your hand will be right above the centre of gravity.
Fritz had a nice idea for a handle too, coming from the tail cap area.
Clamped onto the tube allows a lot of leeway, a lot of options to use it however you see fit.
Also allows for easy cell changes. Of course, our tail cap comes off and the carriers slide out so this helps a lot too.
ARsee, why the hinge? Why not just bolt it together on both sides? Simplify the construction and streamline the overall design. Or even a toothed bottom end, like a dovetail, that would suffice with the bolted top section applying the necessary pressure to lock in the joint.
Aha, you found a picture that says it all.
Do you think it will fit the GT tube?
I’m not willing to gamble on a $30 handle.
And maybe a group buy of some sorts is possible and bring the price down?
Jerommel, B&H Photo and Video has it for $28 and they state “The internal diameter is 1.97” and the length is 4.65”.” I measure the GT tube at 2.19”, so it would probably be possible to use longer screws for the clamping force and spring the mount slightly. Should work. Think I will order one and try it. If nothing else it should fit my TM16.
Of course, the beauty of a handle like the one above is that you can move it to adjust for balance, or reverse it. You could also stand it on that handle, or hang it up.
Unfortunately making such a thing and then having it anodised, it could easily soar past the price of the Gt lol!
Modifying a cheap one like that is the way to go.
DB would love to know how you get on with that please. If it’s too tight you could always slightly soften the aluminium with some heat, not overdoing it obviously unless you want it golden.
That depends on where the center of gravity is because a plastic handle would need to attach in front and behind the grip to be strong enough. And depending on the operating temperature, it could get too warm. Not to mention 3D prints look like dollar store items unless you put way too much time into finishing them.
There are plenty of other threads with chit-chat of what is available for handles. Just guessing, likely every BLF GT thread.
That was not my intention, to start another one to re-hash what's been talked about elsewhere. I posted a design I have in my head, in efforts of interest and refining. I was hoping at a group level.
I'm very much open to ideas, thoughts, and suggestions. Of my original post. But this was not possible to remain on topic. I don't know why.
Well you deleted your design but the conversation goes on. Thank you for starting the conversation, it’s interesting. That use of an existing handle looks like a great idea if you can slither it on. Due to the GT head being so big, reversing it (screws towards head) might give it the needed balance.
R/C - you had a fantastic idea. Thank you for starting the convo. I ordered a Nitecore off Amazon $28 and free shipping (prime), figure some heat and bending will work if it doesn’t fit first go round.
Because this is BLF, and we twist every thread sideways and have 25 experts chime in on the manufacturing of a reflector,
about the proper “Perfect Tint” needed to cut through 78% humidity in the Alps, about the inefficiencies of a Buck/Boost driver when driven at 9.3 volts.
Or about the best shipping solutions to east/slight west aberdeen.
Or my favorite, Copyright laws.
Why ever hire a Lawyer when all the free, expert advice is right here on the internet.
Butttt, back to your OP, just keep hashing it out, I thought your design had promise.
Later,
Keeping it real,
Keith
