I’ve tried it with regular short alkalines, with Eneloops, and with unprotected 14500. All lead to the same result - you have to cut power to the driver via loosening the tailcap before it will power again. I also took a quick look at the little spike jobbies sticking out from the driver, and they aren’t long enough to contact anything on my cells. The driver seems flawed. As an aside, this driver also will not go into program mode, so maybe they were forced to remove the program mode and broke some other aspect along the way (?). Keep me posted, guys, if you unravel the mystery any further. Thanks.
Update: Now it will only turn on if I'm using regular alkaline AAs. The length of those seems to be identical to the Efest 700mah (red) 14500 I was using before. What gives? It's not the Efest batts as I tried three of them fully charged and none would get the UT01 to turn on.
I agree completely with eas. I ended up using a circle of thin silver solder in the tail caps to give a bit more length.
I suspect that many of these issues start from the tubes being too short, and the initial battery install causing permanent crush-force damage to the driver.
Every one of my four had the anodized edge of the tail cap making contact, or almost making contact, with the anodized lip on the tube when I received them. Only a hard tightening would result in contact of the conducting surfaces. I added length and the problems disappeared.
When i tried a protected 14500 in the Utorch Ut01 it was dead. Nothing. I traded the body and tail cap of my new Lumintop EDC05 and the Ut01 worked fine. Has to be an issue of length. The body of the UT01 is just to short to work correctly.
(Reply to Mtonne here, but my post ended up in the wrong place)
I don’t know how to post pics here, but it goes right up inside against the inner circumference of the cap and up against the outside edge of the switch plate. I used 1.6 mm rosin core solder (.062”) and its just right. Not too stiff and not too soft. Adds just enough length. Wrap a piece around an AA cell, and you’ll be pretty close in size.
Trim to length with your nail clippers.
It should end up the same size as the shiny end of the tube, so it squeezes between the end of the tube and the switch plate - hence increasing the inner length of the tube by 1.6 mm. Wiggle it in there with tweezers.
Other materials will no doubt work as well, but I find the piece of solder is just the right softness to form easily into a circle and sort of squeeze into place and stay there. (Just don’t use acid core solder, that’ll mess things up for sure).
I too believe this may be causing some of the issues. My UT01 would not work with any of the alkaline batteries I had on hand, the battery tube is too short and the spring bottoms out before the tail cap makes contact with the end of the tube.
The unprotected Sanyo 14500 worded well. Tried the alkaline’s and just jumped from the rear of the battery to the end of the tube and they all worked.
As others have mentioned, a small diameter wire formed into a circle that fits around the outside edge of the spring and the tail cap will fix the problem, for my light anyway.
Received mine recently (3D) finally had a few minutes to play with it. Installed a regular Alkaline primary cell and it worked great, real nice tint, switch works fine and all modes are working, I switched many times through all 4 levels and back to off, plus 2 clicks for hidden strobes with no problems.
The memory mode (long press from off) only memorizes L-M-H modes, it does not memorize Moonlight, I guess you wouldn’t need that because a single click always enters moonlight anyway.
I haven’t tried a protected 14500 because I didn’t want to crush the driver, don’t have any shorter unprotected right now. I also have some NIMH I will check their length and try later. My 14500 protected 750mAh AW is only slight longer than the Alkaline, will try that one later after I do a paper clip mod in the tailcap.
I also didn’t try programming the levels yet.
The last good AA/14500 light I bought was an Olight S15, but it was only available in CW and its greenish blue tint is pretty ugly. This UT01 NW tint is far better for my liking. The Olight has a much larger reflector and a tighter hot spot, the UT01 in comparison is thinner, shorter and more compact. I’m really liking this light so far!
The reprogramming function appears to be working but it’s kind of confusing, it went through the sequences as described in the review but there were only 3 programmable modes instead of 4, apparently High is not programmable?
It says in the review “Light has programmable output levels for every mode” but after I set levels for 3 lower modes it just goes to high and is no longer auto-ramping, then I have to single click to get to strobe (to turn off in strobe as described in the review instructions). I have to spend some more time with the programming.
In programming there are 3 levels to chose from, anyone know what the factory default levels were?
Maybe they don’t want people messing with that since nothing in the manual about it?
Thanks yasenf! So it seems they have upgraded to remove programming for HI.
I’m wondering if they changed it because when it first came out some people were complaining of low maximum output, only to discover the default programming for HI wasn’t set to the maximum level.
In a side by side comparison it makes the 4C Convoy look white, and I always thought it was quite yellowish, but I think I’m starting to like warmer tints sometimes.
