[PART 1] Official BLF GT Group Buy thread. Group buy officially closed! Lights shipping.
A $2K toy…
Very nice though.
JasonWW wrote:
Correct, the GT has a massive 45mm diameter mcpcb. Richard carries them up to about 27mm. Keep in mind that the Convoy L6 with its xhp70 and 9,000 lumen potential (for the 70.2 and fet driver) only uses a 20mm mcpcb.
The reason the GT needs the massive size, even though it’s only putting out 2,500 lumen, is because of the massive reflector. The base of the reflector and centering ring are quite huge by normal flashlight standards.
See the base diameter of the reflector below. Courtesy of MRsDNF (Next to C8, S2+ and P60 reflectors)
Bonus pics.
Next to a Q8.
Currently there is a 32mm maxtoch mcpcb for an xml. These can be converted to 12 volt by some cutting and soldering, but I’m still not sure it would fit.
If anyone happens to find a big 12 volt xhp35 mcpcb for sale, please post about it here.
Thanks
End JasonWW post.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Good info & pictures Jason……. . :+1:
Guys, I think there is something wrong with my GT!
I have it now in momentary mode (press&hold for turbo) and each time I press the button
I can feel slight recoil!. This only happens if I go from off to turbo, all normal if it turns ON
in mode that is not turbo.
:smiling_imp:
A large reflector might also be produced differently. A large reflector might also be produced differently… Production reflectors part 1. And without waste. :+1: :+1:
Pretty sure it’s normal. Do you have it loaded with 4 or 8 cells? 8 cells gives more mass which reduces the recoil.
Imagine all the trillion photons shooting away in just a couple of miliseconds after pressing the button.
How to unscrew the head? I tried, but no chance.
Neal does not get a list of Lumintop to whom has the lamp been shipped? I wrote a message to Neal but did not answer.
Wouldn’t hydroforming be a better and more cost effective way to produce a reflector of this size?
This is for anyone who does not know how to acess the MCPCB/LED easily on the BLF GT.
First & foremost… DO NOT REMOVE THE BEZEL. :slight_smile:
So…… here is the process….
  • Remove battery tube
  • Place the ‘flats’ of the *‘engine’ in PADDED vice jaws. DO NOT tighten hard. Tighten just enough to hold it firmly & keep it from turning.
  • Grab the head with both hands and twist it off the *‘engine’ that is being held in vice jaws. If you can’t get it with both hands use a strap wrench placed around head just BELOW the bezel.
  • The top part of the head should come off in one unit containg bezel, lens, & reflector as one piece.
  • Cover hole in reflector to keep dust or any crap from entering the reflector. Then secure this complete unit in a safe, clean, & dry manner/area.
  • You will now see the easily accessible MCPCB & LED.
  • Un-solder Red & Black wires on MCPCB, being careful NOT to damage LED
  • Remove both Phillips head screws from MCPCB
  • Remove MCPCB
Note: …‘Engine’ = Part that houses driver, side switch & MCPCB w/LED*
That is it…. :slight_smile:
Installation will be the reverse of these steps with the EXCEPTION that new Thermal Pasted will be used under the MCPCB. This is AFTER you have removed and cleaned the old thermal paste from the MCPCB mounting shelf of the GT.
Also…. IF you ever do need to take a bezel off, get a piece of rubber bigger than the bezel .
Place it on a sturdy flat smooth hard surface, then put the bezel face down on it.
As you push with downward pressure twist the head of the light to loosen and remove the bezel.
The GT bezel can be difficult to remove.
Hello, sorry for uploading a flashlight production video, which is not LT, but you can have an idea of the process, partially, greetings.
Teacher makes it sound EASY to remove the head from the pill, and of course it is… if you have the right tools. Without a large enough vise (with soft jaws) and strong enough reinforced strap wrenches of sufficient length, well, good luck!
I have the set of tires removed from my diesel VW before the big scam/buyback stacked in the garage, I found it relatively easy to remove the bezel by pressing it into one of these Continental Extreme Contact DWS mounted tires and twisting. Access to the emitter is fairly easy due to the sheer size of the now open space (reflector removed).
Do take steps to keep the reflector clean, of course. I simply place it upside down in the bezel, atop the lens, and that suffices for the amount of time it takes to swap the emitter. Ambient conditions and presence of children are key factors involved in what measures one must go to. Pelican cases used to warranty their product against virtually anything, excepting Acts of God, Grizzly Attack, or Small Children… take heed! :laughing:
Nice Olight video, you get the picture here how they produce flashlights. I guess this is one of the best facilities. Not every production facility looks like this in Guangdong region. This video shows that the reflectors are milled out of a cylinder of aluminium. No pictures of the coating process. Thanks for sharing.
Thats a great tool you have there! All sorts of fun you can have with that.
I am also glad to see proof that what I have been saying for years is correct, that the sun is around 5000k.
Also good to see proof that the tint does get cooler as the power increases. I think some of those saying it is too warm are looking at it in low modes, where it is quite warm indeed. At full power it really looks much better.
They are using a billet to machine the reflectors almost assuredly. The cost to make a mold and cast them would be way more then it is worth for a production run this small. Plus the surface finish would not be as good with a cast material.
From the outside you can see the material quality is much too high for casting.
:smiley: . :smiley:
Wasn’t trying to make it sound easy… though it was.
I just did not want to dissamble the head unless I needed to.
More things taken apart, more chance for something to get messed up.
Have not reassembled this one yet, so not sure if I will have to loosen the bezel or not to do it properly. That remains to be seen.
I am thinking go slow & easy………
…………making sure all is line up properly, it will be NO.
BUT you have done the reassemble Dale…. what says you. :slight_smile:
The light is well made Teacher, reassembly with the Bezel still snugged down is painless.
However… I find it more optimum to NOT have the bezel so tight. I also removed some material on the underside of the Delrin centering block, it was cupped underneath and held the reflector a bit too high for my liking (agree with Kawiboy on this). Putting the bezel back on it seems to do well for the definition of the hot spot to not snug it too tightly. [my Delrin block was 2.8mm thick, apart from the centering ring section, and flat across the top both in the block face and across the ring. When I got the base flat the block ended up 2.5mm thick.]
/\\\ … Thank you sir…. :+1: … Good info.
Glad you mentioned the Delrin centering block too. I had forgot what KB had said about that.
The reflector is loose and sort of floats in the head, the centering ring aligns it when the head is tightened down. :wink:
/\\\ . That is what I was thinking / hoping. . :slight_smile:
I keep checking back :slight_smile: … any idea when they are likely to be sent?
Not sure why this never include the 3rd round of PM’s have not been sent out yet … PEBKAC I expect…
