Exactly. You still have a little gap, pfff… like a millimeter or so. If you want to get rid of that then you could look into a single piece 9 emitter design. But that’s most likely not worth it (besides looking darn good).
Any hind regarding the expected price for this monster light?
@M4D M4X: in the OP you state 7 x XHP70… but i count 8 in the pictures you posted.
Even at a conservative 3k lumen per emitter that’s no less then 24k lumen! This light will certainly peel paint and repel bears from a mile away!
The XD80 houses 8 70.2’s with a smaller diameter orange peel reflector pushing each emitter at 4000. The MF03 has a smooth reflector from what it looks like with a 35 HI centered. The MF03 should put out blistering numbers with slightly deeper and larger reflector with great range! This is very exciting and I cant wait for specs and beam shoots! Very interested in the UI. Lets guess at the output for giggles. I will say at its max somewhere in the neighborhood of 36000 What say you
How can you say that the reflectors of the DX80 are smaller than the reflectors on the MF03. If I compare my DX80 with the pictures of the MF03, the DX80 has bigger reflectors. The only advantage of the MF03, besides the XHP35 and probably higher output, is that the reflectors are not overlapping and did not have OP. And perhaps the MF03 has deeper reflectors because of the lower depth at the overlapping-areas. But with the diameter, the DX80 will win.
I want to know the battery configuration and the output-numbers of the MF03. Perhaps the XHP70.2’s are driven harder
That’s why I said from what it looks like, not is. I viewed pictures of people holding the DX80 and the Video of the MF03 and just made a guess. It looks larger to me. Just an observation and nothing else.
