I've said this before somewhere… how about setting an inductor in series with the emitters? This can reduce emitter current to some extent, while at the same time filters and increases efficiency for PWM modes.
Teacher, this Sofirn C8 is what Convoy shouldv’e done years ago, after all the triples I’ve built using the Ledil CUTE-3 optics this reflectored version really rocks! The side switch really steps it up as well, you DO know they’re offering hosts for like $14, right?
I built up a host with 3 different colored XP-L’s, I think 1A, 3D, and 5C, and the output is fantastic! About 3800 lumens from a FET driver with TK’s ramping firmware and ramping UI. Not the simplest of builds, what with the side switch and it’s wires to get in the way, probably the MCPCB screwed to the reflector and then the reflector screwed into the head make an impact on the ease of build as well, but all in all it’s worth the effort, the supplied e-switch is on a pcb with lights already installed so if a lighted switch is one’s thing then that too should be pretty easy.
After the initial fiasco with the first version of this light (without direct thermal path board LoL) they probably decided to play it safe with these higher Vf XP-L emitters, which have a nice tint btw.
Just curious, can you elaborate about the “initial fiasco” without direct thermal path? Sorry I hadn’t read about it. So did the LEDs overheated and burned up without it?
