Yes, indeed. However, if the restock date will be kept the first two tints should arrive in 3 days, then four tints the next day and the rest two days after that.
I don’t know how big the shipment will be so keep an eye out
Don’t agree. For the price build quality is decent. The UI is the typical cheap one though: high, low, strobe, off. I consider this light a good modding host, I am working at a replacement driver.
Use coupon code 280c58 to lower the price from $249.95 to $142.47 (-$107.48)
uses 4 Cree XP-L Hi V3 LEDs
3600lm
1003m (1097 yds) range
5lm lowest setting
252000 cd peak beam intensity
direct access to both ulrta low(5lm) and turbo (3600lm)
built in voltage indicator accurate to 0.1V
max runtime of 610h (~25.5 days on end)
5 constant modes + 3 hidden blinkies (Strobe, SOS and location beacon)
PRO TIP: As this light features tail tripod mount use this $1.33 attachment to affix it to your keychain.
Your quest for ultimate keychain light is now over
Was able to get the Convoy L2 (neutral/warm white) thanks to petemer’s code.
Convoy L2 = forward clicky switch
low, med, high (consecutive half-press to go to next higher mode, but not too quickly as to register as a double half-press); then fully depress turns on at the selected mode
to get ‘strobe’, (double-half-press quickly), then fully depress turns on at ‘strobe’ mode
Unfortunately, since it’s a forward-clicky, once the mode (eg. low/med/high/strobe) is selected, to go to another mode requires fully depressing the button to turn off, then do the above again. Has Mode Memory though (I think Strobe is also memorized).
Half-pressing the button while the L2 is already turned on appears not to do anything — is this always true of forward-clicky switches? since this seems to be my first forward-clicky flashlight.
Regarding quality: the fins part (head of flashlight for heat dissipation), anodization seems not too well done, after testing out the flashlight a bit (I haven’t dropped the flashlight; though I may have the flashlight ‘bump’ very slightly with another flashlight since I was comparing the beams with my other flashlights with my hands full; the other flashlights anodization is still intact no scratches at all), I notice the anodization starts to “fall off” (becomes tiny aluminum-white scratches) in the fins portion already, but the rest of the body appears to still be OK (still black).
try double half press, that sounds like the same UI as the S2+, after its on for a few seconds it does that, when you first turn it on you can single half press to switch modes.
The switch is called forward clickie because it reacts to half presses only when off. This is the expected behaviour. The L2 is a very nice light, particularly as a modding host for a handy thrower.
Don’t get me wrong, genuine Convoy lights usually are of good quality, I bought (and modded) a lot of them but it makes no sense to compare non existing lights.
Hello guys, do you know if Bang Good is usually accurate about restocking? i'm so enthusiast to order the BLF Q8 but they are currently out of stock in the Cn warehouse.
Depends… if the lens is cracked all the way water might get inside. No other adverse effects. Contact BG for replacement. When you open order details there’s orange button with “Repair & Refund & Resending” caption - follow the instructions and attach picture of cracked lens. They should send you new lens and if that will be impossible to acquire alone - whole flashlight.
