Maybe I’m missing something but what other tint options are there with this light? It seems like a lot of these “new and improved” LED’s” ARE improved with better runtimes and more brightness but still are hindered with tint problems just like the old days.
I really had high hopes for this but alas, it has some teething problems like most new lights nowadays.
Hey, I’ve got an idea! Let’s just buy them anyway and spend extra money for better whatever this or that and many hours to make them right!
Again and like always, some folks will be fine with these tints and nothing wrong with that. I just wish I could be.
One of the things I like a lot about this flashlight is how FireFly and Turbo are hidden.
What I like less is the spacing of the outputs. I would prefer: Medium = 650lumen.
Does this flashlight has a ATtiny?
200% more lumen, 90% runtime in Turbo compared to High? How realistic are the run times?
-Turbo (3800 lumen; 130 minutes)
-High (1800 lumen; 145 minutes)
@robo819 THAT’s the info I was looking for!
Do I have to wear gloves for Turbo mode?
So after 3 minutes on Turbo it steps down to about High (1800)
Do you have a similar table for the High setting? The specs state 145 mins on high. I guess that should be read as 145 mins @1300-1800 lumen?
The charts are the only testing I have done with the TC20. Had 3 lights come in for review at once and have 2 of them done so haven’t had much time to do more testing with it.
I think if started in High mode though it would probably get 120 to 140 minutes as my best guess.
It gets hot at the 3 minute mark but not blister you instantly hot , as you could probably grab the head for a couple of seconds before you get burned.
Ok I went out and took a few shots with the TC20 I did my review on. Taken from 22 Feet away at a WHITE garage door , paint is a semi dark beige and the trim is a rust red.
Did this so those asking about the tint on the cool white can judge for themselves , as to whether they like the tint this ONE particular sample I did the review on with the COOL white emitter.
I’m not seeing the “sickly greenish’ tint reported by Gebe in an earlier post for the CW version, so he may have got a loosing ticket in the tint lottery. I can’t even notice the tint shift in the photos. But for me the real test is when it’s beamed at some leafy greens, trees, shrubs etc.
Not sure the CCT of the CW version but personally I most likely wouldn’t be happy with anything 6000K or higher. It’ll be interesting to see what abglenn has to say, soon he’ll have both tints.
Interesting beam. It’s bright, very bright, no doubt about that.
For me the first picture is the most visible one. In the last picture I see one big bright white area. In the first picture I see what the garage door actually looks like. The best part, for me is in the spill.
I even have that problem with my 650lm flashlight. Lot’s of lumen is great when lighting up an large area. But when detail is needed, like reading the label on an paint can in the basement it blinds me.
If the OP deems this question off-topic then I’ll start another thread…
What can be done to make the whole garage door as visible as in the four corners of the first picture? Less lumens? More floody? Different tint? Higher CRI? Maybe a different color like green? Something else?
Sounds like what you’re describing is the hotspot “washing out” the subject. You need a triple, quad, or multi-emitter in a TIR optic, (pure flood - no concentrated hotspot) Astrolux MF01 219C maybe?
I recently got one of these with Nichia 219C 5700K (tint is pure white) 720lm so no where near as bright as this TC20, but it’s no slouch either, and great for reading those paint cans JAXMAN-E2L-3LED-TIR-LENS-flashlight-18650
@beam0
I saved your post for later reference. I’ve learned something. For my use more LEDs is best. Astrolux is to big. I certainly want to stay below 60mm. 40-50mm is what I think is ideal for my type of use. Do certain types of lenses reduce/remove the hotspot?
The Gen III is not out yet, but judging by the only picture I have seen, it will have a smooth reflector. Most likely the tint shift will be much worse than the TC20 but slightly better than the K30. I doubt they will make many other changes; just a new reflector and a new emitter, probably driven harder, to stay in the lumen race.
Gen III?? My apologies, oops! Thanks for pointing it out, I didn’t know GEN III existed, guess I wasn’t paying much attention since SKV89 did write “3,850 lumen” and “XHP 70.2 emitter” both of which I knew the EC50 II was not. :person_facepalming:
Now I’m also very curious about how it will compare! For one thing the Thrunite TC20 is 13mm shorter, and to me that’s a lot.
As far as the tint shift with SMO reflector… We possibly could look at the Acebeam L30 (4000lm XHP 70.2) I’ve also been considering that one lately, there are several reviews on it but I don’t recall if any reviewed the NW version.
For the L30 Acebeam lists in the features: “Smooth reflector for max. light output” however in one of the photos they have “Moderately Texturing finished reflector” so i’m wondering if it’s actually Light Orange Peel and maybe the EC50 III will have the same.
I forgot about the L30 [Review] ACEBEAM L30 - XHP70.2 - 20700 Looks smooth to me. And a rainbow on both CW and NW. It’s just a feature of the emitter.
You might be right about the EC50-III. The K60 has an OP reflector but they went for LOP on the K65.
