Congrats! Good news. $25 is under the €22 Why on earth puts Lumintop $30 on my packet? Neal wrote me before shipping it's $25 With 30 invoice you have no change to slip through customs.
Almost all of the prototype lights suffered a piece of the centering ring being scraped off and landing on the LED and caused it to burn.
It looks like to fix this they decided to center the reflector to the mcpcb instead of the LED itself. Which is a good idea and something we considered when this started.
This works fine in the vast majority of cases but in some the LED will reflow slightly off-center and cause an issue like you saw. The good news is that yours is about as bad as it can get and sometimes reassembling the light can fix it like it did in your case. It also should not be enough to make any noticeable difference in the throw of the light.
Seeing as the LED burning would kill the light, I would say this is a worthwhile tradeoff to make sure that doesn’t happen and completely kill the light.
Not to worry, nothing to do with the light itself.
Also, there would be no need to file a paypal dispute, you can simply request a refund at any time before it ships and we will be happy to send a full refund.
It is not an issue. It is by design. The carriers must be pressed against the driver in order to complete the connection, so there is some extra thread depth to make sure that can always happen.
The black centering piece is machined from Delrin, oddly enough it isn’t perfectly symmetrical… if it’s touching the emitter it needs to be flipped around. All 4 that I have seen this has been true on.
I have paid on 2 dic 2017 03:37:29 PST time printed in the email from Paypal
The point of no return is 2 may 2018 04:37 PDT, frrm the transaction in Paypal
BUT…
I have paid the “reserve” on 26 ago 2017 13:18:53 PDT, the deadline is 22 feb 2018 12:18 PST
It’s been a while since I visited this thread, and even longer since i remember reading this but iirc turbomode is entered by double clicking and should be visibly brighter than the top of the ramp? Am I remembering correctly? If it isn’t (which is my case) any reason that you can think of? To head off the question im using the cells from Neal that i purchased with the light
Sooooooo…… I signed up for the forum after the initial purchase group. I have yet to receive an email asking for down payment, etc. So am I just wasting my time at this point? Thanks.
Visually the difference is very minor and hard to notice unless you are looking for it (which is why we set the ramp to stop at 2A).
If the cells are low or have excessive voltage sag, then turbo will not be any brighter then the top of the ramp as it would have already dropped out of regulation.
This is where high drain cells do have benefits, they voltage sag less and allow it to maintain regulation longer.
