Although I have been here for a short time, I will allow myself some attention: are the BLF rules? Are. Why are there no group purchasing rules? Why are those who paid many months ago still waiting? If there is no control over the way Lumintop sends it, I understand. Each company has its own internal policy. I believe that certain rules can be agreed together, since we are voting on what shade the diode should have. It has no effect on many factors. That’s clear, but any general rules can be accepted. As for me, I can wait and half a year because I am 1514. Ok. I suggest setting and voting on group purchasing rules.
I have not even received my PM yet. I guess I will have BLF GT by Christmas. I am ok with the long wait. I rather have a perfect BLF GT instead of a BLF GT with problems.
I ran across a 2 piece set of rubber strap wrenches for $5 at my local Northern Tool store.
I removed the battery tube and the side switch ring and clamped them lightly in my vice using some thick leather welding gloves to provide cushion.
I made sure to loosen the bezel before loosening the upper head as it’s easiest.
The head was actually tighter than the bezel in my case, but I got them both loose. I hope this helps someone.
Ps, The bezel has 2 o-rings. The one on the side, below the threads, is well lubed, but the one between the glass and bezel is dry. I think this is the one making it so hard to loosen. I added a bit of lube between the bezel and o-ring and this seems to help some. I tightened them back up hand tight.
It’s a thing we learn in the deep South G0OSE, the floor is hard and prone to damage the light if it falls. This way, we can jab a bare foot under it and keep the concrete from denting it if it falls.
Also I would imagine it is a bit warmer in Texas than it is here in the UK.
I don”t like to walk on my stone tiled kitchen floor barefoot this time of year yet alone outside.
Hi everyone, I just received mine from FedEx (order placed said DHL). This thing is HUGE and carrying it is more like carrying a dumbbell
Thank you all for contributing to it. This is the largest flashlight (heaviest) I ever own, love it very much.
Note: Mine come with bigger than LED black gasket, however it is well centered. There are some uncoated area (10mm square), four marks, at the edge of the glass. And when max out the light, there is an off-center-oval-shape-corona slightly brighter than the adjacent observed on the beam (it is not able to be captured by camera). Another thing is the BLF GT box has been taped all over the place with FedEx stickers and when being removed, the box’s wording and “skin” are all gone :cry: . What a waste, they should wrap with protective layer before sending to FedEx…… To me all these are still acceptable, but just want to highlight that compared with my flawless TN42, Lumintop needs to keep up a bit more
BLF GT (4000 K?) on the left & TN42 (5000 K) on the right
today I received the first of my two GTs.
DHL shipping, no batteries.
Neal no sent the GTs in the order they had been paid, but was doing miracles with customs.
I did not have to pay anything, THANK YOU NEAL.
