Eheh, no no - at least not that I know of! I just used the because there are several stores with these 1200 (un)protected Keeppower, I keep them under sight in case I need more to replace or add to the Aspire IMR18350 1100mAh I bought when they were still produced!
And because I use a lot of smiles on my messages :person_facepalming:
Thank jon_slider Apart from 2 Panasonic 18650, I don’t have protected Li-Ion cells, but I am aware those are normally longer and thicker than the non protected :+1:
Also, didn’t check the shipping from that store :person_facepalming: But there are some other stores that have those and that probably ship to the US
surprisingly, to me, the 16340 protected and unprotected are the same length (in inches), or 0.25 mm longer for protected.
The 18350 difference is much greater (IF the linked specs are accurate)
This store is currently shipping the Keeppower UH1835P to Brazil and I imagine other countries where shipping is often unavailable, I’ve bought keeppwers from them before (currently unwrapped and returned to unprotected panny-B state)
These cells are now in stock from nkon.nl, a highly reputable European vendor (no affiliation).
They do however state that the cells are 39 mm long. Which makes me wonder if they’ll fit properly in my Emisar D4?
The springs should have enough play, but I’ll hold my order until I at least get home and try to cram a measured battery with a spacer in there!
Or can anyone verify that these cells will work in a D4?
HKJ states 35 mm though, and “highly reputable” is the least of his accolades. But different batches, different specs? Fake cells? Or just misspelled on nkon?
I’ll be back with a solution to the conundrum when I have it, unless solved by another.
Nice cells, allowing small lights with multiple emitters to shine, the closely resemble the Vapcell 18350 purple.
Still, the Aspire cells were even better but extremely hard to gome by………
The Aspire, Vapcell, and this Keeppower are same cell, all made by the same factory. Yongdeli New Energy Battery. Tony, the owner of Aspire E-Cig is part owner in the battery factory. At least he was a year ago.
I have now received my five batteries. They are indeed about 35 mm long.
The measurement of 39 mm corresponds to Keeppowers protected 18350 cells, so the error was probably made by looking at the wrong specs, but has since been corrected.
The cells arrived in retail boxes of two, including a case for two 18350 or 18500. With a bit of cutting they can be made to fit three 18350s though! (And the fifth cell came in another of the same case, even though I ordered several other cases, one of which was used to package the two HG2s I also bought).
Furthermore, the Keeppower case for one 18650, which is apparently made with protected cells in mind, can just about fit two of these cells, with a very thin insulator! With a little bit of cutting it should be possible to fit a somewhat thicker piece of plastic in between, making it a very compact case for the job!
No, I’m more after a “spacer”, or something to hold the cells in place, as the case is on the large side and they will rattle and move if there’s only one in there. Yes, “insulator” may have been a bad choice of word, but it was natural in the circumstance.
