Thank you Dale. I am following in your footsteps with a UV light build in this nice host. Will post details if I can get the thing working right. I wanted to start slow with a cruddy battery since I am not quite sure how the emitters will handle full power.
UV emitters are typically much lower voltage/current, like 700mW or 1000mW, so if you aren’t taking precaution to keep power level to their requirements you’re gonna blow 3 UV emitters in a big hurry.
I reviewed one of these and I am in contact with Dale comparing notes a lot of times also.
with everything as the light comes out of the box , I would say 8.5 to 9.5 amps would be a good average to expect from the included cell or a quality high drain cell.
Hello friend! Began to collect a flashlight sent from Sofirn and found that the electronic button does not have a free wheeling and is not pressed. That is, it stands in one, jammed position. What to do ? Where to buy a similar button? Maybe she understands? I wrote to the seller, I’ll see what answers.
That is some fine machining johnkey! Those switches can be found easily, I’m on my phone now but I will get you a link later.
Why did you choose for a TIR optic?
I can understand going to the Noctigon for it’s 3 oz copper traces, have no idea why the awesome reflector was cut into a spacer in favor of the boring CUTE-3 optics though. The triple reflector is what makes the Sofirn a game changer. Much tighter beam from the reflector. But then, I’ve built so many dozens of CUTE-3 optic triples…
Just goes to show, different strokes for different folks!
