Help me pick my next light (cheap 1x18650 throwy)
The c8 is the obvious choice for a $20 thrower, but if you don’t like the shape and size, maybe try a BLF x5. You can’t really tell by the pictures, but this is a much smaller light. I don’t have one but it seems to kick a lot of but for it’s size.
https://m.banggood.com/BLF-X5-XPL-HI-1400LM-EDC-LED-Flashlight-14500-p-1031451.html
I do love my convoy c8 though, the quality is really really nice and it throws like crazy with the xpl-hi.
Thorfire C8 is my go to right now.
Gonna mod it? As-is, the Ultrafire F13 is nice and throwy, I like the design and feel, but the come-with UI just pisses me off. I swapped in 1-mode 22mm drivers for nice dedicated throwers.
I like the U-Torch UT-02 and the X-6 eagle eye.
the c8 is so ugly
I got a Sofirn SP31 (no battery) for $13 USD, free shipping (from China).
It’s since risen $1, and a $1 shipping fee was added, but it’s still available.
https://www.ebay.com/itm/Sofirn-Tactical-1021-Lumen-XP-L2-V6-4-2-Modes-EDC-LED-Flashlight-Torch-Aluminum/132433245361?ssPageName=STRK%3AMEBIDX%3AIT&\_trksid=p2057872.m2749.l2649
The Sofirn lights are really well made (I was surprised at how good it was), and has a slim profile, dual buttons and is very bright for it’s size. The clip is nice and sturdy, with little flex. The knurling and anodized finish are satisfying. Definitively a very, very good deal, as long as you don’t mind waiting. You’ll want to get a High drain cell, and it can be flat-top because of the dual springs.
Now, you want throw. This thing will throw 300+ feet (100M). The beam widens, and isn’t as narrow as a C8, etc, but still travels far.
Brinyte B158 If you want to add $5 to your budget. That light was real popular around here for awhile. Easy to mod too
Eagle eye x6 you’ll love it. It became my edc I use for work daily. 3.5 am turbo for 3 mins. For a decent 20 buck light doesn’t get much better then that. I have like 5 x6 and 5 c8 or something now. I make brothers of each kind. Fet driven xplhi v3 well have to build x6 the same way. Need a couple more host. Time to make a couple with the new sst40 led
Edit for around 20 you can put your own light together. You’ll feel great the first one you do. Convoy host $10, led 3 to 6, driver 4 to 10 dollars.
The new s2 has a smooth reflector but a tube light only throws so much. The convoy m1 is the best all around light I’ve found. Mine has xpl2 w2 2b emitter making 1800 lumens. And it throws plenty and lights up the area. My second pick would be the eagle eye x6 with the same emitter Fet driven. Amazing light output. And with a little mass takes awhile to really heat up.
Richard at MTn has some lights ready to go.
If you buy the parts and pay shipping I’ll put a light together for you.
Since the Eagle Eye X6 was mentioned, would the Astrolux S2 (aka BLF X6v2) be considered a better version of the Eagle Eye X6 or is there still some pros of the EE X6 over the Astrolux S2 (BLF X6v2)? The Astrolux S2 is around $23.95 during “promo” sale periods (which seems to happen relatively frequently).
I like my Astrolux S2 when I need more throwy situations while being a relatively compact portable light — being FET-driven (Bistro firmware), it seems to be at least as throwy as the Convoy C8 XP-L Hi (which I also got) and they have also nearly the same weight (the Astrolux S2’s head is quite heavy), but Astrolux S2 is slightly smaller.
The convoy c8 with xpl hi got a really nice beam
free image hosting
I know you said you didn’t like the look of the C8, but it really is the best budget choice. The silver Convoy C8 is a good choice (don’t get the other colors of Convoys, because their UI isn’t very good). For a few dollars more, there’s the Astrolux C8 which has higher output and throw. I reviewed it and compared it with the Convoy here:
https://budgetlightforum.com/t/-/48738
how can you not have BLF A6 or Astrolux S1?
wle
Id say that, and theres good deals going down on them here on the forum
$28.99. I would go with the 5000k tint. Its probably my favorite tint I have right now in all of my flashlights
The UI is good on it, but I would love to have the same UI as the GT on this light
I just bought the EE X6 from GB with a coupon from bilakos
From reviews i read, the EE quality is better then the Astrolux
I’d like to know some more about your UF13 mods.
Have you also changed the emitter in your UF F13 w/22mm 1-mode?
Crappy pix, but yeah:
Everything’s a variation of a theme, nothing terribly different if swapping for a 3D, 5A, etc.
Only the driver was a little tricky, that the wires had to be “unlooped” to not bang on the shelf above it. Plus, I used one of those PET insulating discs to further insulate it from the shelf, just in case.
Other than that, it’s a straightforward mod, nice’n’easy.
The 3D is (to me) a bit on the cool side, rally should’ve tried the 5A/5D first. Well, that’ll learn me…
Thanks, interesting light, almost bought one about a year ago.
I was thinking an XHP35 and one of these:
http://www.kaidomain.com/p/S026504.H2-C-22mm-1_5A-1-or-2-cell-5-Mode-Boost-Driver-Circuit-Board-for-Cree-XHP35-XHP50-12V
~~http://www.kaidomain.com/p/S025124.FX35-22mm-1A-1-Cell-3-Mode-Boost-Driver-Circuit-Board-for-Cree-XHP35~~
What are your thoughts on that?
EDIT: Don’t like the modes on that 2nd one.
I did my research a while ago, ruled out all those multimodes as annoying.
If you can deal with them, hey, go crazy, but not for me.
In particular, I don’t like that “150” mode. No such thing. Call it 100 that steps down to 67% if you have to.
Well at least the H2-C has hidden strobes, so basically a 4-mode ML-L-M-H, but I could do without the ML (0.01%)
Too bad no one makes one of these with firmware like the Dr. Jones Guppydrv, I have a few 17mm FET drivers with Rev1, they can be set to various groups, including single mode 100%, for an emergency light.
The thing is I can’t seem to find any other “off the shelf” single cell 12v boost drivers for XHP35, this is the only one I know of, do you know of any?
Not offhand. Got some from FT for a MT-G2, but didn’t try it yet.
MT-G2 was another one I was thinking about for that F13. If I see it come up on a flashsale or coupon deal I’ll probably grab one to mod.
