Thrunite TC20 - XHP70 - 3800lm
Received a NW yesterday, awesome flashlight! It’s a little hand grenade!
I’m happy with the tint, the snow all melted here so I took it out on a walk and the tint is perfect for me, beautiful neutral color rendering. I don’t notice any of the tri-color rainbow that’s visible indoors on white walls, but it’s not going to be used indoors anyhow, and don’t think I’d want the tint any colder.
The switch feels fine to me, I see how its been described as “mushy” it has some extra spring travel before it clicks, but I guess I’d call it a bit “springy”? But hey all switches aren’t created equal, maybe it could be more precise but it doesn’t bother me at all. It might even help for prevention of accidental turn on, seems like you can depress it very lightly without it turning on. Although you can just do a mechanical lockout by a slight twist of the head. (unscrewing)
I really love the aggressive knurling, it rivals the knurling on my HD2010 and DQG 18650 tiny V1, which have best knurling of all my lights. I also love the “single click-on/off” (Olight) UI. Overall I’m very happy with it, @3800lm it’s the brightest rated light I own now, tomorrow night I’ll take it out again with some other lights and compare brightness.
Ow God, please, stop…. Did I told I’m trying to resist? :cry:
MUST RESIST!
is there any way to lock out the button?… prevent accidental turn-on?
thanks
Yes, mechanical lockout by a slight twist of the head. (unscrewing)
I also added that info to my previous post about the switch.
Sorry!!! :smiley:
Oops I missed that… cool then thanks!!
Does Thrunite charge up front for pre orders of this light???
TC20 battery came fully charged, slightly disconcerting. 4.19 according to lil500. Never had a brand new battery come from factory fully charged. Paranoia big destroyer!
Has anyone tried unprotected flat top high drain batteries in this light? I want to have spare cells for this light.
I tried Keeppower IMR 4200 and worked fine.
Great thanks!
I will also be running a shockli 26650 imr flat top… a light like that should deserve imr in my book.
Works fine with an Efest IMR 26650 4200mah 40amp battery (purple)
LiitoKala Lii-50A 5000mAh unprotected Flat Top IMR also works fine.
What batteries do you have?
I have some 18A IMR efest 5000 mah on the way.
Every once in a while the switch doesn’t respond. It’s only happened a few times. Has anyone of you experienced this?
No, I’ve been using it a fair amount and I’ve not had that issue at all with mine.
It hasn’t happened since my post. Maybe the switch contact was bit oxidized?
Well hopefully it doesn’t keep acting up.
Personally I really like the action of the switch on this. I think there were some complaints it was “mushy” or “sloppy” or something, I think I said this before but to me it seems like a just a longer “throw” than other side e-switches that feel more “precise”
I think why I like it is that it takes less effort to use. But interestingly it seems more effort for accidental turn on.
Owned a D4 XP-G2 model and now own the XP-L HI model…I’d be surprised if I could hold either of them more than 15 seconds on FULL brightness without gloves (which I rarely wear). Their highest levels are definitely for “show” or for quick scans of an area far away. If I were interested in sustained brightness to a larger area at some distance, I always picked up the Acebeam EC 50 Gen II that was mentioned here earlier (excellent light I sold recently to fund something else). This Thrunite definitely looks like a nice blend of features and power to me.
