I’m starting to look for a replacement for my Nexus 5X. This 5T looks interesting, but unfortunately it says it’s not compatible with the Verizon network. I’ll have to keep looking.
Oh, I suggest you should try using its Dash charger technology instead of the usual slow or 1A charger. It’s NOT only for convenience. Here’s why?
It’s like this: In OnePlus’ website about this technology, there is some kind of circuitry in its original charging cable that though the charging is fast, the battery does not heat up because that special circuitry routes the heat back to the power supply adaptor, INSTEAD of the battery. Have you noticed the phone barely gets warm when its original charger set is used?
I bought several micro-usb-to-usb-C adaptors connectors just in case the original usb-C cable malfunctions. I tried it once (used my iPhone’s USB adaptor with a good micro-USB cable and put in the usb-C adaptor) and the phone’s back portion heat up a lot more with the slow or low charging rate!
At the upper-left portion of the phone, the is a led that glows purple when Dash charging (original adaptor/red cable should be used) and yellow if some other charger is used at a slower, ‘normal’ rate.
And it’s been a well-known fact that heat is one of the major factors that brings lilo to its earlier demise.
I have charged my 5T with the Dash charger and it does charge fast, but I’m not so concerned about speed. I’m more concerned about convenience. I’ve done some google researching, and the general consensus is it’s ok to use a no-oem high-quality charger like an Anker. Also, I have portable chargers from Xiaomi and Anker I want to be able to use in case of a power outage. All I care about is that these aftermarket chargers won’t damage my new phone. From what I’ve read they won’t.
LMAO sorry.... It is a laser ranger finder.. I have wanted one for a while but any that go out to a decent range get stupid expensive... This one was not cheap but reasonable... And just from goofing off with it today reasonably accurate.
A new camera; Panasonic ZS100!
1” sensor, 10X optical zoom, Program, aperture or shutter priority, manual… An electronic viewfinder as well as the 3” display.
