That’s funny, I also thought the overall size of the XP-L2 same as XP-G2. Bringing this kind small detail is so educative. Footprint is the correct word, not die. So now I can say that XML has same footprint has XML2 but different die. Thanks for the reading!
In Cree parlance, the footprint is XM, XP, XR, XB, etc. The die size is L, G, E, etc.
So XP-L and XM-L2 actually use the same chip (the L2), but one is in the bigger XM casing and the other is in the trimmed XP casing (you can see the 4 “slices” taken off the dome).
2 Heads, one white, one with red, green, blue and amber LEDs, heads and color LEDs individually controllable.
The modified MCPCB with XP-E2 color LEDs, and my driver which is used in both heads. In the white head populated with FET + 7135, in the color head populated with 4 x 7135 for each LED. MCU is Attiny 841. Full ramping UI of course. The reflector bottom had to be grinded a bit to make room for the outer LED wire pad. Reversed MCPCB polarity (batt+ at the outer trace to keep grinding at a minimum).
Cut a solid 6mm brass rod and soldered a spring on one end in order to bring batt+ to the rear head. Used tape to isolate the rod and drilled a hole in the tail PCB.
The threads at the rear end of the battery tube are too short to reach the driver board so I made cut outs (for the PCB screws) to a copper ring and put this ring on top of the PCB.
Nicely done Mike, I was about to post up something but you made my little tinkering project look like a popsicle stick cabin job, Way to think outside the box, very sweet!
