I agree on the training wheels muggle mode. Should be easy to get acquainted with, and for those who have difficulty with it would act as a very simple on and off mode
I didn’t even know this was a thing (the blue and green humps). I guess I’m not sensitive to it or never noticed it. Are there any videos that show this?
I wanna change my votes! I want A, B, C, D blinks!
I was using my D4 and realized how much I rely on visual information given by the blinks! Please, ToyKeeper, add my votes also on A and B (as I previously voted on C and D only)!
Thanks! :+1:
Maukka’s reviews include data on tint shift at different power levels. I also showed the effect a while back on the BLF-A6. This clip shows an A6 switching between 150 lm on the 7135 channel and 150 lm on the FET channel, with each channel used by itself. The brightness stays the same but the color changes:
I took pictures at the time too, with white balance and exposure locked. Same light, same emitter, same brightness, even the same specks of dust on the lens, but different power channels producing different tints:
I’m pretty sure it’s that constant current is just that. The others using pwm are looking to be using 2 or 3, depending on the driver in the chart, current levels but is pulsing it to get the desired output…
Don’t think I’m explaining it very good, but hope the point came across lol
I vote the same… no blinks except for bottom and top of ramp.
I really like how the D4 resets to a fixed mode after you loosen and tighten the tail cap. It came up several pages back, but I think its a great option. I always figured the D4’s fixed level was 100% output on the 7135, and the FET turned off. (I may be wrong about that)
LED tint rises with current. More power = more blue.
With a 2-channel driver, it can only run at two power levels, like 350mA and 10A, which gives it two tints.
In the video, I used PWM to control the brightness, using only one channel at a time, to show the difference in tint. But in actual production firmware I use both channels simultaneously to help blend from one color to the other. Despite attempts to blend though, it still has a distinct tint “elbow” which is visible during use on a smooth-ramping UI.
With three channels, it’s the same thing… only with three colors instead of two. The more distinct power levels it can run at, the closer the curve gets to a true constant current result.
It’s running Anduril, with some features being decided by discussion and votes. Here’s the most recent UI diagram showing most of how it works:
