What did you mod today?
8693 posts / 0 new
Flashy Mike
Flashy Mike's picture
Last seen: 30 min 3 sec ago
What the origin of the name ‘Foybezel’?
Goshdogits lights look very nice but there is a disadvantage with the flat bezel: you don’t notice when the light is still on after placing it on the head. Well, actually you will notice somewhat later when you smell the smoke … Big Smile
djozz
djozz's picture
Last seen: 5 min 23 sec ago
Flashy Mike wrote:
What the origin of the name 'Foybezel'? Goshdogits lights look very nice but there is a disadvantage with the flat bezel: you don't notice when the light is still on after placing it on the head. Well, actually you will notice somewhat later when you smell the smoke ... :D
Foy is a BLF member (who has not logged in for years now) who was famous for his very enjoyable style of posting, and for his love for Solarforce flashlights. He did not like strike bezels and started to flatten them, claiming the proces in general by calling it Foybezeltm  Party
Flashy Mike
Cool, thanks!
goshdogit
goshdogit's picture
Last seen: 8 hours 11 min ago
Thanks everyone! I really like the look of the Q8 with the flat bezel.
I sanded one as a test and immediately thought, “Dang, now I gotta do the other two.” LOL
Big Smile Very true! My friend, who also owns a Q8, had a similar reaction:
“Very refined, but if you set it face down, you won’t know it’s on until it burns a hole into the center of the earth.”
My other scorchers, a D4 and two Meteors, have flat bezels. Besides, I tailstand my lights. Silly
Flashy Mike
I’m still trying to do that … Big Smile
goshdogit
goshdogit's picture
Touché! Big Smile Big Smile Big Smile
DB Custom
DB Custom's picture
Last seen: 56 min 25 sec ago
Foy was probably most notably known for his unique sign offs, he’d run everything together with no spaces between words. And he gave his “Foy Approved!” on his favorites.
WemissyouFoy!
gchart
gchart's picture
Last seen: 46 min 2 sec ago
I’ve considered doing something similar with my stainless bezel lights but oddly have never seen it mentioned until now. What’s the best process to keep it nice, smooth, and even?
DB Custom
DB Custom's picture
Lathe. Big Smile
lotec25
Last seen: 2 years 2 days ago
Edness,
Where did you get the white surround piece for the 70.2?
gchart
gchart's picture
DB Custom wrote:
Lathe. Big Smile
Kinda figured Tired
Now that I rudely asked a question without first searching for the answer… off I go to see the history of the FoyBezel!
Edit: found a nice post from Foy
Foy wrote:
I recommend not using something high speed and/or overly hard to do this mod. A grinder may speed things up but the heat might discolor stainless. It gets hot enough just using an orbital. My best success is when I sand them down on the orbital starting with 100 grit. Then lightly sanding (with the orbital) with 220 grit, very lightly. Then, and this is key I believe, I use padded 150 grit and spin the bezel without sliding/moving it in any other direction, just spinning. Finally, I repeat the spinning/sanding on 320 grit padded sand paper. I believe the padded sand paper makes the bezel outside edge look more finished/professional. With regular sand paper you get a sharp edge and it would be more difficult to to smooth it evenly. All this sanding/spinning is why I use an L2r; its long body is a perfect hand-hold. I end by lightly rotating the finished bezel on very fine steel wool. I tried this because of a suggestion from someone here and it works quite well. (can’t remember who)
goshdogit
goshdogit's picture
DB Custom wrote:
Lathe. Big Smile
Big Smile While standing at the belt sander, I kept thinking, “I wish I was friends with a machinist.”
gchart, I removed most of the metal using a belt sander with a 40-grit belt, and it’s slow going. I moved the bezel side-to-side across the belt, and regularly rotated it to prevent uneven wear.
I love this quote by ‘old4570’ I found in this thread while reading about grinding/filing/sanding stainless bezels:
old4570 wrote:
Stainless steel is hard, so accidents are hard.
I surprised myself by managing to keep all three Q8 bezels very flat and even. I left them installed while working so the light could act as a handle and heatsink.
What lights are you thinking of altering? Perhaps you could start with an easily-replaceable (and available) bezel in case it doesn’t work out.
gchart
gchart's picture
No Q8 here. Just a couple smaller lights like the ThorFire TK15 and Sofirn SF36. If those get damaged, I’m really not out much.
goshdogit
goshdogit's picture
I read up on Foy’s methods too, and started off with an orbital sander and an 80-grit disc.
I got impatient, and I have a belt sander, so… Big Smile
I allowed the lights to cool once the heads got hot to the touch. The bezels never got anywhere near the point of discoloring the stainless.
goshdogit
goshdogit's picture
I say, “Go for it!” Party
I don’t own either of those lights, but I looked at some photos.
It looks like the SF36’s bezel might end up rather thin along the outside edge after knocking down the high spots.
FWIW, my Q8 shows about 1.50mm along the outer edge after sanding.
Be sure to update us if you end up Foy’ing anything! Smile
DB Custom
DB Custom's picture
I’ve done this sort of thing too many times with a belt sander and a file. I still do some things that way, believe it or not.
I personally would rather add crenelations than remove them, as I head stand all my lights and like being able to see if I’ve left one on in moon mode or something.
MRsDNF
MRsDNF's picture
Last seen: 5 hours 32 min ago
It’s good to see some old customs brought to life.
Yokiamy
Yokiamy's picture
Last seen: 1 hour 56 min ago
I am planning my first ‘Foybezel™’ with a stainless C8 bezel after reading and seeing these beauties and informational posts
Pulsar
Pulsar's picture
Last seen: 3 months 1 hour ago
djozz wrote:
Flashy Mike wrote:
What the origin of the name ‘Foybezel’? Goshdogits lights look very nice but there is a disadvantage with the flat bezel: you don’t notice when the light is still on after placing it on the head. Well, actually you will notice somewhat later when you smell the smoke … Big Smile
He was a good guy, shame he up and left again…
comesayhifoy
gchart
gchart's picture
I haven’t really posted a mod in this thread in a while. Simple mod, but I swapped the LED in my ThorFire TK05. The stock “neutral white” XP-G3 was as blue as could be. I bought some Samsung LH351D 5000K from DigiKey and reflowed one onto a filed-down copper dtp board. Took some pics while I was in there, then put it back together.
Nice, truly neutral light now. And a lot more lumens. By my estimate, 50% more while in turbo and 33% more medium. Just as long of a runtime, too. More pics and details in this thread, but I’ll share a few here.
click for larger images
Beamshots [before], left to right: ThorFire TK05 (XP-G3), Klarus Mi7 (XP-L HI), Convoy M1 (XP-L 5000K)
Beamshots [after], left to right: ThorFire TK05 (LH351D 5000K), Klarus Mi7 (XP-L HI), Convoy M1 (XP-L 5000K). I apologize for the white balance difference between this and the last shot. But in comparing the three LEDs, you get the idea.
Runtimes. Disclaimer: the TK05 was tested with a Wuben-wrapped 600mah 14500. The Mi7 was using an Sanyo 800mah 14500. I need to retest with like cells.
Pulsar
Pulsar's picture
Swapped the driver in my s41s to the x5/x6 driver, and swapped in a lighted switch. Both from BG.
Would like a better lighted switch than a single LED, but it works.
Loving this driver
Hemionline
Hemionline's picture
Last seen: 2 weeks 3 days ago
Astrolux S42 with lux rc 334 module Wink
Charging and 2color button is also working here
LEDs are Samsung l351D 5300K 70CRI
Agro
Agro's picture
Last seen: 1 hour 4 min ago
A nice one…must be very efficient?
Hemionline
Agro wrote:
A nice one...must be very efficient?
I don't know yet, but shape of the beam is beautiful. I didn't like the original optics and UI
Edness
Edness's picture
Last seen: 7 months 1 week ago
Interesting…did you have to sand down the driver or optics to fit into the S42?
Hemionline
Edness wrote:
Interesting...did you have to sand down the driver or optics to fit into the S42?
Everything fits exellent, but i made a copper  2mm spacer, because original optics a little higher, than carlco.
Edness
Edness's picture
Gotcha. I don’t like the beam pattern of the s42 optics with xp-l hi and maybe this is the solution. I think using the stock mcpcb as a spacer might work. Have to sand it down to expose the copper obviously.
koef3
koef3's picture
Last seen: 1 year 1 week ago
After several hours my first real Mini C8 mod is finished. Smile
The JAXMAN M8 (formerly known as Mini C8) is one of my absolute favourite light still today.
A long time ago I got some of these cheap LED bulbs at the german Aldi Süd (12 V GU5.3 with 38 ° beam angle).
This mod features this large coin spacer with 62 grams weight. Smile
Some days ago I noticed that the lens of it fits perfectly in the M8 head and I got the idea of a Nichia triple for floody high CRI light.
It looks small even in comparison with a Thrunite TiS / Ti3:
The beam pattern is beautiful, with flood everywhere.
The saturation is incredibly high, even higher than of the Lumileds Luxeon MZ 5700 K 90CRI I tested recently. In direct comparison the tint of the used Nichia 219BT-V1 R9050 sw57 is a bit rosy and more on the blue side, but not too much. The XP-G3 shown here is definitly warmer than the stated 5700 K (and a lot greener!) despite it was ordered at Mouser:
The M8 is powered by a good old 105c, with custom firmware (3 modes + 1 moonlight), with 2,800 mAmps current. I didn't want a dragster, but a useful and durable light for everyday use and I have the option for increase the current sometime. But I'm satisfied with that, and on highest mode (no stepdown) the battery lasts for more than one hour.
Moon 1.5 Lumens + 3 cd
Low 17 Lumens + 30 cd
Mid 208 Lumens + 400 cd
High 890 lumens + 1,700 cd after 30 sec.
Also very useful as photography light. Smile
My LED tests: Cree SC5 based LEDs (WIP!)  ---  Nichia 319AT 83 CRI - Optisolis (3000/5000 K) - Lumileds Luxeon LXML-PWD9 - Luxeon MZ 5700 K (90 CRI, 3 V) - Luxeon V (CSP) 4000 K 70CRI - Luminus SST-40-W (+ dedomed) - Cree XP-L2 (+ High CRI variant) - XHP35 HI - XHP70.2 - CXA1304 COB - OSRAM OSLON Black Flat HWQP - SYNIOS DMLQ31.SGLE UW Q8WP - unknown 5050 LED ---- finished: JAXMAN M8 (Mini C8) HighCRI Triple
MRsDNF
MRsDNF's picture
Nice build koef3. It reminds me of an old Lumens mod. Question
Edness
Edness's picture
Well thanks to BLF. More interesting mods. S41 triple with 219c that came out of D4 v1. 5000k 80cri.
Used a 20mm Tpad mcpcb as a spacer under the noctigon.
