Oh, um, we’ll probably make a team account at some point, and chown the thread. There just hasn’t been a huge need for it yet, since production is still probably months away. There are still several things which need to be done before then… off the top of my head:
Host design needs some updates and at least one more set of prototypes.
Some internals need adjustment, like the brand of 7135 chips.
Emitter type needs to be decided.
I should probably finish the firmware.
Lumintop is busy with other projects.
Figure out logistics for purchases and shipping and such.
Agree with team account!! When the project gets on full speed, if The Miller keeps absent, it will be good to have several members that can pass “structured” information to the interested members!
BTW, this is the list on post #1. Probably it needs to be updated.
And I would add a pepinfaxera as part of the team - if he agrees to!!! - , because of the efforts done so far in keeping the list updated and verified!! He deserves an honorable mention on this too!
Two questions for you:
What are the differences between Anduril and Narsil?
What diffuser are you using for your Q8? (got one made for Fenix but it sits really loose. One medium shake and it comes off.)
Quite a few. The general concept is the same, smooth ramp plus mode group plus extras, but beyond that it’s pretty different. The code is completely new from scratch, ramping and mode group share a single UI, the mode group uses whatever parameters you want, the blinkies are more numerous and adjustable, thermal regulation is faster and too smooth to see, config options are mostly attached to the modes they affect instead of being all in one place, etc.
Dale sent me one made by ZozzV6. I don’t really know the details, but Zozz would. It’s a very tight fit; I actually had to sand it town a little to make it easier to put on.
The switch LED has three states — high, low, and off. During use (when the main emitters are on), it runs at high or low to match the brightness of the main emitters. While off, the switch LED uses user config values to decide what to do:
Regular “off” mode: High, low, or off.
Lockout mode: High, low, or off.
Other modes with an “off” state (momentary, muggle): Currently just off. (might change)
To change the switch LED config, go to lockout mode. It then has a few available actions:
Click or hold: Momentary moon.
Two clicks or click, hold: Momentary moon.
Three clicks: Change lockout mode switch brightness.
Click, click, hold: Change regular “off” mode switch brightness. Let go when it reaches the desired level.
Four clicks: Exit lockout mode.
So… if you want the switch to stay on most of the time (while off) but want it to turn off sometimes, you could set regular “off” to “low” and set lockout-mode “off” to “off”. Then simply lock the light with 4 clicks when you want the switch to turn off.
I’m # 796…and that’s the only place I see me…I had mentioned getting 2, so I don’t know if that would be 2 different spots or just the one…oh well…the Miller said “it’s done when it’s done”
