See this thread! Trevi_lux deals and coupons :+1:
I can translate it using the chrome browser. It’s a bit tricky to read, but you can make our the important stuff.
How long does the RJ-02 run on high?
Im guessing there is not temp regulator?
Vaguely recall it drew a smidge over 1A, so maybe 2-3hrs, depending on the cell.
I ordered these two BORUIT headlamps from Alie Express.(free shipping)
I ordered them on Jan. 20th and they just landed in the states yesterday. One of the fastest shippers I have encountered on AE!
Bought one for the heck of it
I hope Lightbringer gets his commission !
Only one? C’mon, the Bringer Of Light needs a new Q8…
I measured 1.40A on the Boruit RJ-02’s tailcap current with a freshly-charged battery.
If I recall correctly, the RJ-02 does not appear to have low-voltage protection, so it may run down the battery if left on. (maybe someone can confirm?)
That is the information I have. So it is recommended to use a protected battery so that there is no chance of an accidental over discharge.
Just got one, the led is not XP-G2, even not a cree led
The tint is acceptable(no horrible blue/green tint)
For 9$ this is a good light
Toldja.
Who told you it used a xpg2?
It’s some no-name led. A bit on the bluish side in my opinion.
How hacquable is it (D10, D25)?
Separate pcbs for the emitters? Driver board flashable? Etc.
you can change the emitter, I will make more picture/ dismantle when I will finish with the seller
anyone ever had the same lemon as me?
headlamp working only when charging?
The ’02 I leave alone because despite the generic emitter, it just plain doesn’t bug me. Quite nice, in fact. So dissecting it and risking having other components fall off the uniboard when trying to heat up (just) the LED doesn’t make sense to me.
But having multiple blinkies in the main sequence? Nope, not a chance, mmmmmmbuh-bye. Don’t care how nice it is otherwise.
At least if the charging board were independent of the driver, etc., then I’d risk it.
I have finally try the latest boruit
6.42€ 50% OFF|Boruit LED Mini Scheinwerfer Hoch leistung 3000lm Scheinwerfer 18650 wiederauf ladbare Stirn lampe Camping Jagd im Freien wasserdichte Taschenlampe|head lamp|led headlightlight head - AliExpress
I was pretty convince the first day…
https://www.youtube.com/watch?v=naizk_MDdjc&feature=youtu.be
only work when charging now… don’t know why……
There are other threads for the non RJ02 models.
Boruit D10 / EHL0628 [image] So I’ve come across this well-liked budget headlamp which I believe to be much better than the well-liked cheap Boruit RJ-02. The only review I am aware of posted on the web is a Russion review found here (translated via Google Translate). I decided this headlamp deserves its own thread, so here are some pics and a quick review. Doing some investigating I came to the conclusion this light is model #EHL0628 (EDIT - more widely known now as the D10), as shown in this…
It looks like you battery might not be making contact due to the green light coming on when the main light is off and usb is plugged in.
Then again, it might be something else. Have you contacted the store and asked for a replacement or refund?
What are you talking about here?
many thanks, I will repost here
Lightbringer:But having multiple blinkies in the main sequence? Nope, not a chance, mmmmmmbuh-bye. Don’t care how nice it is otherwise.
The other Boruits various people mentioned (by links).
Axed about the D25, etc., as to how hacquable they might be.
