Cheers and don’t worry about this thread. Information is scattered throughout this forum; some people complain about their DX problem on Gearbest’s sales thread only. You’ve probably read this by now, but there is also a structural problem with the XHP70.2 emitters only lightening up partially, like only half of the emitter. It’s a really odd defect.
Cheers, ok I won't overthink it then lol. Yes, I read about the problems. I wonder if it is just a defect from Cree itself? But I don't think I have read anywhere of that problem with other flashlights using the 70.2
Exactly. The interesting thing is that it’s a problem (half lit emitters) only occurring with the DX80. If it were a bad batch of Cree leds, then surely it should have been picked up by led gurus on this forum, as well as reports found of other manufacturers suffering from this bad batch. This is not the case, so I suspect it’s Imalent not doing something right. Probably incorrect reflow procedure (of the leds to the led board).
I would suspect the same. They must be aware of it as it seems to be somewhat common with the DX80. I thought they got a new manufacturer for the updated version but maybe they didn't. Maybe it's as simple as turbo mode creating too much heat and as a result all odd problems start surfacing. I've seen the youtube video where the DX80 in turbo mode sets paper on fire almost instantly.
My take on the entire DX80 thing is that this is very high performance light.
As such, not only are high quality components critical, BUT,
The workmanship during assembly has to be painstakingly and fanatically excellent.
Anything short of that will lead to failures.
Lessor workmanship would get by with low performance lights, but not this one.
I suspect the flaws come from poor assembly practices.
I agree and failure rates have to happen on anything, especially something like this because one way or another humans are involved. I've scanned youtube and the web and still I don't see too many people saying they have problems with the DX80. Curious six more months from now what pops up. I've been lucky so far that none of my flashlights cheap or high end have had any problems yet.
That was a good find on the taschenlampen forum about the short. That is possibly the guy that posted in the banggood forum that I quoted in my first post when I started this thread. I translated a little and here is what he said how it happened.
"The dx80 was not turned on at all. The flashlight was not hot. As it happened, I mechanically locked the light when it was turned on in mid or high mode, then I unscrewed the battery compartment after a second to reset the mode memory, and there was a quick flash and pop then smoke."
Then further down the thread he said he was sorry and that he unscrewed the battery a little "whilst the light was on" so maybe he just did a no no. That is a real long thread and a detailed one and it will take time to read, but from what I read so far, it is suggested never to unscrew the battery pack with the light on and one guy said his shorted but his light was off and in lock mode and he was wondering maybe not to lock it when unscrewing the battery. Lots of really good info there I must say.
Even though i cant read & understand the test parts, the It looked like a trace blew out from the photo, (at 16 volts and high amps a blown trace can arc like a welder and do some damage. Concidering the battery pack is designed for high current & volts to drive that wattage, it can likely blow out a small trace easily if surged when on turbo and unscrew the body to cause a surge.
EDIT: i just looked at my DX80, and the one i have has a different driver cover, ( without those three openings showing the driver back.
DBSAR, google translate does a great job when reading that forum. If you have google chrome, just right click anywhere on the page and choose "translate to english".
For safety, it just make sense that the light is always off when unscrewing the battery pack. Maybe in newer versions, Imalent may take that into consideration and have some type of fail safe protection if unscrewed when the light is on for newbies. If you have a different driver cover, maybe its a newer and better driver too hopefully.
I did use Google translator after to read some of it. He indicated he did unscrew the body when it was on. A bad idea in any light of that magnitude with high current & voltage. I even avoid that with smaller lights, ( except single cell 1.5 volt twisties i have.
If you have google chrome, you can also right click any page and choose "Translate to English" and will translate the whole page which makes it much easier to read a thread. I fully agree and that is why I started this thread in the first place. Now we know for sure it is a bad idea, especially with the power of the DX80. I've never done it on any of my lithium lights ever.
If i get the time i may do a amp load test (using a shunt-type amp meter with #10 gauge wires) to see how much the DX80 actually pulls from the battery pack on turbo after a full charge.
Different light, voltage and current, but it’s normal routine for something like a Convoy L6. The clicky switch does just that; it cuts off and connects power.
For a light like the DX80 there should simply be a design feature to handle manual cut off. Lot of electrical devices don’t like it when you just unplug the cord, but it is the same thing when you have a power outage. It’s not like your fridge or TV goes poof when the power comes back on. Manufacturers of course are aware of this, hence make sure it’s not a problem.
Especially when it puts out that amount of power. Another thing I noticed is that the holes in the side of the DX80 head exposes the heat sink as you can see it. Makes me wonder that it is not really waterproof and I did read somewhere, maybe even here at BLF, that someone dropped it in shallow water and it died.
I was tempted to try to take apart the head of my DX80 to see how the heat sinking is actually set up. I tried using a pair of magnifier glasses and a inspection light, and it is still difficult to see if the driver is exposed or not through those cooling fin openings.
I keep thinking that there are two big gaskets on each side of the huge heat sink; one on the led, and one on the driver side. If a gasket is misplaced, and sits not properly in its groove, then bye bye water resistance. I’m sure most of us have seen one of those Skyray King clones where part of the O ring is sticking out from the side of the lens.
