MF01 is out of stock right now. Chinese New Year is closing, not sure if there will be any more coming before 16th Feb.
MF01 is in stock. Please send me a code for a MF01. Thanks.
Mf01 nichia with TA driver and vtc5aās should be 17000 lumens on startup.
I just bought one with the Nichia 219c. Thanks for setting up the GB!
Can you send me the code please?
picked mine up at the post office this morning, going to play with it tonight thanks freeme :+1:
Is it possible to purchase the head only? I already have a MF02 and wanted a dual head light.
Iāve only seen the MT35/MF02 head sold seperately. I havenāt seen it the other way around.
Mine tops at 13-14k with 30Qs.
Honestly it is more then enough and probably way too much considering the heat and lack of deep fins on the head.
Bangood is now selling it for $77.95 without coupon. I bought mine yesterday with the coupon though.
+1
hiKARInoob, did you measure those values? So V2 is dimmer than V1? I just received my MF01 219c today so Iām assuming it is V2. Itās smaller than I expected and the tint is slightly less yellow the the 219c on my S42.
Ceiling bounce using the Meteor M43 as a reference. The beam profiles of M43 and MF01 are close to identical, so I believe absolute lumens are sufficiently accurate. Max output is also in concurrence with measurements of other members Iāve read.
Since V1 and V2 have identical beam, relative output is correct. So in my case V2 is slighty less bright than V1 with full cells, but V2 maintains higher output with depleting cells. Both are 219C.
I was just playing around with my new MF01 and after awhile, when I enable Turbo mode, it just turns off randomly and goes into lockout mode. I would have to hold the button 2 sec to unlock it. It happened several times. The batteries are VTC6. Itās not fully charged but the light indicator is red so that means thereās still charge in it.
Does MF01 have any protection mechanism that turns off and enters lockout mode under turbo mode when it overheats or battery voltage not enough?
Never read about it. There is thermal step down, so the light should not switch off or something. The indicator should turn red at 3.4V IIRC. And if Iām not mistaken this means at 3.7V resting voltage, if you go to turbo form there, you will have sag until 3.4V so red light turns on. This also means if you then go to a low output, voltage will rise again above 3.4V and light turns green again.
It sounds like a defect to me, but maybe freeme or anyone else knows more about this?
Actually I think it is because of the low battery. I put in full charged batteries and it does not automatically turn off anymore. Also I think it is more than 8000 lumens when running with fully charged VTC6. I get ceiling bounce of 1,220 lux whereas my Emisar D4 XP-L HI v2 4000k reaches 420 lux for 1st second and drops to 370-380 lux in 2-3 seconds. The D4 should be about 4000 lumens at max output. However, its strange my 1,600 lumens BLF A6 XPL V6 with fully charged VTC6 reaches 200 lux and Astrolux S42 219c 5000k gets 209 lux at startup. The BLF A6 is supposed to be 1440 lumens without sprint bypass mod.
I will do a few more ceiling bounce test to compare with other lights I have coming in when I get them, which includes the Manker MK34, Haikelite MT09R XHP70.2, and Noctigon M43, just to name a few. Yea flashlights are addictiveā¦
Understand it is Spring Festival / CNY now so shipping most likely wonāt happen for at least another week or two, but keen on this light if GB price is still available. Thanks.
Yes. I am asking for more comparisons, I am also just waiting for shipment Manker MK34 to compare with Astrolux MF01 Nichia 219c V1
Iād like a group buy code if itās still available please.
Thanks very much.
I have here a MF01 that was sent to me for mod, but I cant get the bezel off
I tried heat it to 150Ā°C without success
