Yup, they are just like that, accessible but hidden They will not interfere with regular modes!
Hum, I can’t do those measurements, but it would be nice to get some numbers when you can
I couldn’t try TIR optics as the ones I have (for the S2+) don’t fit. I would have to sand or filled them on the edges and it would ruin them. Maybe others, slimmer, can fit!
I will use the plastic until I get something decent for it! I works well
My opinion is that unless super bright or super low modes are needed, the 5 existing modes are good enough, well spaced and provide good illumination at a “close range” (meaning: I don’t think it will be very powerful if you need good illumination after 20 meters).
Some beamshots, from highest to lowest. (not the best, but maybe enough for an illustration)
Yup, I tried without the plastic holder. Those are too large for this light! They have to be thinner and shorter than those you linked.
As reference, here are the reflector’s measures:
Hmm, I’d swear it was mentioned in one of the Russian threads (there is another I didn’t link) that it accepts optics and I guess I assumed they were the widely available ones.
Those I have don’t fit, but there may be others! To fit the “bezel” the lenses must be less than 18.8mm, just measured!
The ones I have are larger than that
Why do you say that?
One click on, one click off.
Press and hold to cycle through 5 brightness levels.
Plus hidden strobe, SOS and Beacon using a dbl click.
What’s wrong with that?
Wildcat, so that the Convoy TIRs fit, you had to cut them, right? Cause the ones I had didn’t fit, but if I file the edges they will probably fit.
Unless my headlight has some difference from Garry’s, because it was not bought as “Boruit” but in Shuolide store. I don’t think they differ, but I may be inducing people in mistake… I hope not!
I guess the 17mm TIR will fit more easily due to the internal measurements of the bezel!!
Yes, you just need to file the edges that the TIR entered the bezel. With any 3535 LED (xp-g, xp-l, nichia 219, samsung lh351d) TIR rests directly in the star. It is only necessary to add an o-ring between the TIR and the bezel for tightness.
Thanks again Wildcat Gonna test the difference between the TIR and the simple diffuser over the lens to see how it works and then check the one that will fit better on the healight!
The Medium > High is only possible in a short time window.
If a click isn’t done quickly (within 2 seconds), it will be Medium > OFF.
BUT, from Medium, through press and hold you can reach the other levels from Medium > Low > Lower > Highest > High > Medium >…. . After stopping the ramping, and after 2 seconds, a fast click turns it OFF. Within the 2 seconds period, a single click leads it to Highest mode
So it is easy on this to access to other modes
And, as garrybunk and JasonWW said, blinky modes are well hidden :sunglasses:
Sorry for the stupid question - are the ramped modes memorised? Do both the modes ramp or just medium/first mode? For example, would it be possible to ramp up on the medium (first mode) to make it higher than the second mode, so it’s essentially high mode first?
When you click to turn the light ON, it always starts on Medium. From then on, to ramp, you press and hold, and the output levels always go down: Medium > Lower > Lowest > High > Medium High > Medium.
So the only memorized mode is Medium, no mater in what level you turned it OFF!
BUT, if you turn it ON and the make a single click from Medium (within 1 second), the level you get is HIGH! And from then on, you can ramp it down in the cycle I mentioned above.
Through press & hold, you always go down. Through single click, in that short period, you can go up.
Whenever you start to ramp down, if you make a single click (within 1 second), the light will go to High. Always within 1 second. After that period, the light shuts OFF.
Hope it helps
EDIT: I tested it again and the period is shorter than 2 seconds, maybe 1.5 seconds, but if you want to take it to High right after turning it ON or starting ramping down, it is better to be within ± 1 second!
