You could pin it if you wanted I guess but it won’t move without some abuse. A drop of blue loctite on the joint would provide ease of mind if one was worried I guess.
Well put sir. The only change I can foresee is blending in the boss for the mounting screw which will cost nothing. It looks like the only thing left to do is a time study and to lean on the boss for a good price. Then the fact that I would need to come in on my own time as I now have at least a month worth of work that is needed by Feb 12. When I can make some time I think I want to make a small batch of just brackets (let’s say 20) and see where it goes. Anybody with a drill, a #7 drill bit and a 1/4-20 tap can make about anything a handle.
ARsee, it’s copper that makes the hands stink, not Aluminum. Lord knows I have barrels of Aluminum shavings that can attest to my experience with Aluminum making black hands but not stinky ones.
FWIW, copper is antibacterial, the smell when you handle it is the bacteria on your hands dying off. Smell the copper before you handle it, then after. It’s a product of your hands oils coming into contact with the anti-bacterial.
My chemistry is different. Bare aluminum stains my hands like lead. Lighter. With me, it has a warm, sterile odor.
Copper, is another story like you mention.
Love the look and have a friend that DuraCoats which might be a great solution for this. Quite likely I already missed the info, but in looking I couldn’t find any reference: is there a plan in place to get these produced and to Market? I would definitely be in for two so as to outfit both pending GT’s.
This must be either raw aluminum of a very soft alloy. These are 60-61 T6 which I have handled a great deal for over a decade. It absolutely will not stain your hands or cause any sort of odor.
My experience come from handling old lawn chairs, rolled sheeting used as roofing and side panels sections on utility & travel trailers, older power tools (cast? Not (carbon) worn brushes) so that makes sense. Anodize and extruded has no affect. Sheet goods, most does not bother me. I still wear gloves if I have to handle bare aluminum more than open/close the truck box type. For years I would not drink soda or beer from the can. It was always from the bottle. It tasted better in glass containers anyway.
Though it looks very sturdy indeed, I’m wondering if the handle were able to recess into the 4mm wide heat fines a bit whether it would be even more sturdy or probably not worth the extra work.?
I am definitely interested in possibly 2.
Next we have a new feature I found tonight that I’m sure I must have been secretly planning for months and hiding it from myself.
The “peanut” can simply be flipped aside and lightly tightened and in the hand it’s almost like it’s not even there. Sure as hell doesn’t add and weight to this monster.
Edit: This is also the first and last polished version y’all can figure that stuff out yourselves if you want shiny.
Hey folks, be forewarned… if you are planning on radiusing and polishing this bracket you need to spend some quality time at the gym until you get it, take your Vitamin C and be on your A game, because this aluminum is some seriously tough stuff! He must have used 7075 here, I’ve got very little experience with the top grade alloy but I have a lot of experience with 6061 and 6061 this is not! I used my belt sander with a 150 grit belt and this was like carving on a piece of steel, slow and monotonous! Sanding it down by hand after getting a pretty good radius cut, the resulting powder tells me this is some very hard aluminum! It does polish nicely though with some Mother’s Billet Polish, but getting it down to that final stage before polish is a chore!
I’ve been sick over a week, am definitely not on my A game, so I’ll have to revisit this later and try to finish it up, but just wanted y’all to know this bracket is as overbuilt as the GT itself!
