Acebeam L30 or Thrunite TC20
Imalent DN70 fo $60 or on a budget, the c8.2 from KDLitker from Kaidomain. Another excellent choice would be the Sofirn C8F sold on Amazon.
Thrunite TC20 will give you 1800lm sustained for nearly 1.5hours, There was a coupon for less than $70. I can’t think in a better choice
Imalent DN70 will stepdown to 900lm in less than 3 minutes
Zebralight SC600 MkIV Plus
It uses a XHP50.2 emitter, for lots of flood. 2200 max lumens, iirc. Lots of modes, down to several moonlight levels to choose from.
Tc20, perfect! :heart_eyes:
While the EC4S was my favourite to consider, it seems there are potential hit or miss flaws like high standby drain and problematic tailcap, where the threads can be stripped easily and even with current coupons the price seems too high.
The TC20 seems interesting, I especially like its ability to run in high mode for long time. Can you recommend me where to buy from or where to get coupons? BG and GB doesnt seem to carry the Thrunite brand
I don’t know how much you’re looking to spend…but I had the Acebeam EC50 Gen II for a while and really liked it’s features…especially the really even beam pattern. I got a deal on it from a fellow BLF’er. Very compact for a 26650 light IMHO. Good mode spacing. Built in USB charging. Very good “yard” light. Felt really good in the hand. Up to 3000 lumens on Turbo. Also worked superbly as a room light, tail-standing when the power was off.
There’s a Gen III out now that supposedly has a bit more turbo output and newer XHP 70.2 LED and more “aggressive” bezel.
Hkequipment have a good service, but seems the coupon not arrive yet
Should be a budget friendlier option, as I have already other lights and I prefer trying different LED emitters. So far I have none of the XHP family in my collection. My preference of the XHP50 over XHP70 is due its smaller size, i want also some throw, not an all out flooder.
The KDLITKER seem like great choice, my only complaint is the perceived lack of some “aesthetics”. If it would look like Skilhunt S3 Pro, I would go for it immediately.
Acebeam also looks interesting, but out of my price range. I heard there are some password protected coupons, do you know what it takes to be invited?
Thanks for keeping your suggestions going!
M4dm4x have a site with good amount of codes and freeme too….
If you want the code faster pm them with the light which you want and they will sent :+1:
+1 for Acebeam L30 !
The L30 looks great, but still on the pricier side. Will check with M4DMAX what can be done about it. Other way would be the KDLITKER C8.2. with XHP 50.2
Can someone tell me what type of beam to expect from XHP 50.2. and SMOOTH reflector? I searched for beamshot videos but found next to none. Would expect medium throw with wider hotspot due to emiter size.
Thrunite TC20
Not a big difference but I’m pretty sure coupon price is slightly over $70, I believe it’s $72
Rofis MR70 3500 lumens + 200 lumens side NW light usb charging + power bank+ 5500mAh battery included :+1:
GB18LED code for 12% off
I dont know if haikelite has solve those issues with warranty, so, I’m still in “no recommend mode” with them….
The mt01 is very good, I can use the highest level till the batteries sag :innocent:
Mt01 is outstanding light but if I would choice between tc20 vs mt01 I certainlly take tc20
You guys are awesome for keeping the suggestions going :+1:
To move forward I have for now excluded the L30, not only due its price, but the 200 lumen low mode is somewhat a deal breaker. TC20 is still considered, but I would probably go for a budget option. As I dont know most of these budget brands, it would greatly help me if you could share your experience with these models. Also many of the specs descriptions are far away from complete, there are missing size specs, power levels, runtimes etc, which impacts my decision. So here we go:
1, KDLITKER C8.2 XHP50.2 - I like it, and price is great, just for some reasons the 2 deep circular grooves on the handle tube are in my opinion potential weak points, wouldnt like to get the flashlight snap there in case I drop it
2, Kaidomain KF8 XHP50.2 - also budget friendly, just smaller reflector. Looks beefier to me. Would really like to see some beamshot comparison with above C8.2.
3, Kaidomain K5S XHP50.2 - very similar to above, but runs on 26650 battery for longer runtimes, similar price.
4, ROFIS MR70 - again bit pricier than the KD lights, not really happy about the 2 LED setup, due to potential future issues
5, JAXMAN X1 - not sure about the description, seems the XHP 50.2 version must use long tube with 2x26650? That size is already too big even for cargo pants or jacket.
6, Haikelite MT01 with XHP50.2. - one of the very few soda can designs which I barely find likable. Like the 3x18650 battery setup. Have no info about this brand reliability, or build quality, or runtimes. What was the issue with customer service? This brand looks to me like something homemade on the knee, but I might be wrong.
Feel free to respond inline my list with your experience or keep coming with other models.
I did read some threads which some users had issues with your lights and HaikeLite do not prompted to solve in warranty. I did not seem those threads again……
So, mt01 is good, I cannot tell about others lights in your list, only mt01.
After some hours today I realised which this light have a high parasitc drain, I’ve used few times after changes the batery set and the low voltage protection kicks in…… :person_facepalming:
I still think the tc20 is a better chioce and in almost budget if count the point which the light comes ready to work with batteries and not need the charger
Hi Franz, so if I understood you properly, the MT01 has also high parasitic drain? I like its low price and beam profile, but there is nothing special about it. It also seem to have a problem with turning off, when the light is bumped at the tail. This is due to either weak springs or missing spring at the top… so MT01 is currently at the bottom of my interest list.
