Donāt know for sure. This seems to be an older batch (Version 2015) and at least the 2014 version was too long for this light. 2016 should fit but donāt know for 2015. And they donāt say anything about the trip current (when protection kicks in), this should be 10 A which is sufficient.
Edit:
found some older posts which said the 2015 version is already the shorter one.
I understandā¦itās simply that a couple of months ago I spend a lot of time seeking a 7-led TIR optic that would have a diameter of 32 mm or less. I failed to find any. I guess the actual optic is like 34-36 mm. I may be able to find itā¦.
Anyone having issues with parasitic drain while the DQG Tiny 26650 III is in standby? I now unscrew the tail cap when not using because it ruined a newer Basen 26650 after a couple weeks of not using the light. The battery dropped way down to around 1.6 volts and I wasnāt able to bring it back. I put in a different fully charged battery and did not use the light, just let it sit overnight. Next day I could measure the drop to be about .2 volts. Curious if this is just my light or others have the same issue.
Ok, thanks. Probably just mine then. Iām trying to be careful to always unscrew the tail cap when not using it but Iām sure eventually Iāll forget and lose another 26650. Overall itās a nice light, but agree with others about the button hard to locate the button at night the sharp edges on the lanyard area. This light has been out a while and I hadnāt seen anyone mention the parasitic drain before so I thought Iād mention it.
I notice something initeresting or disappointing. I did a ceiling bounce test when I got this light brand new and it registered 384 lx at startup. I used it once extensively and redid the test with fully charged cells of the same kind and got 351 lx at startup. Seems the LEDs degrade significantly with initial use.
BTW, my ceiling bounce test on other flashlights are 99+% consistent between tests when using same fully charged batteries even if I store the lights away for months without use.
I finally got one of these, and iām pretty happy with it. The price was too high at Banggood, but i got it anyway. the Neutral-White is nice, a little on the warm side though. The interface is very nice compared to the POS that was in their early 26650 Triple that uses long-press for on and for off. That was one of the worst ever, this one is a dream in comparison; even if they did copy a lot of Zebralight.
I really wish it was not a battery crusher design and they used springs. for a small savings in length over their previous dual-spring light itās not worth it. Why they had to be so hung up on creating the shortest light by a few mm at the sacrifice of good design is beyond me. With a large protected cell, there are only like 1.5 threads to catch on the tail-cap. I need to test a few other cells, and see if I can find a protected one thatās a bit shorter. Having used DQG lights since their first lights, I donāt trust them enough to use a non-protected cell.
Iām happy to have another 26650 light that should be useful.
If anyone is interested in the Gray NW version, GearBest is currently selling it at US$49.58 before shipping. Because it has not been categorised as a flash sale, you can use your GB points. After using 743 GB points (discount of US$14.86), the price drops down to a very cool price of US$34.72.
