[MOD] Astrolux MF02 NarsilM XHP 70.2 280kcd @8A 14V
24 posts / 0 new
Lexel
Lexel's picture
Last seen: 4 hours 9 min ago
Modded today a MF02 with XHP70.2 P2 5700K
just after the mod I realized that was a bundled LED to send someone with a driver while in that light should get a shaved XHP50.2 J4-1A Facepalm
still results show 282kcd at 8A 12V LED configuration, so over 100W feed to the LED
25mm DTP MCPCB
12V cut and solder points
added 12V mod bridge
Reflow time, of cours the bridge will unsolder again
Compared to old MCPCB and centering ring
first fit in the light, not as good as original PCB but it fits
I used the Dremel fron driver side to remove some material of the MCPCM and hole to get the thich wires through
Driver flashing, calibrating and testing
Soldering the leads, but the centering ring does not fit
using a Dremel to remove some material of the washers and solder spots to get the centering ring fit flat on the MCPCB
pinkpanda3310
pinkpanda3310's picture
Last seen: 17 hours 13 min ago
Nearly 300kcd from an xhp70 Shocked
Well done Thumbs Up
EasyB
Last seen: 29 min 55 sec ago
Nice result! Good to see these powerful buck drivers being developed. 8A has got to be close to “direct drive” so it wouldn’t stay in relation long, right?
Lexel
Lexel's picture
Yeah the driver changes to DD when the voltage drops
The resistance of the coil and FET in this case is pretty low with 27.4mOhms
As well as 28mOhms for the sense resistor
So at 8A the voltage drop of buck parts is only 0.44V which is good for 4S
The main advantage of the this regulator chip is the low dropout voltage of the boost part
EasyB
I would love to see what a good slice dedomed would do. Should see at least a 50% increase in lux.
Myers
Last seen: 9 months 4 weeks ago
Can you take beamshots? Original XHP35, this 70.2 mod, and sliced 70.2? Big Smile
EasyB
So I’m not up on you guys’ latest work on buck drivers. How much power can you send with a 4s setup? And what is the efficiency of the above driver?
giorgoskok
giorgoskok's picture
Last seen: 1 day 12 hours ago
Nice mod lexel !
I would be interested to see a rutime graph , 2s2p with dd driver VS 4s with this buck driver .
Lexel
Lexel's picture
The 4S goes into DD if needed
losses in all conductors are reduced
if we would say a DD light has 50mOhms total resistance 16A 12.5W loss
added Buck parts resistance to 100mOhms 6.4W losses when it gets in DD
I have no unmodded XHP35 to compare right now but working to get one
EasyB
What about when it is switching to reduce the output voltage? Say I have a 4s battery with a 9V emitter. What is the max current that could be sent to the emitter before burning up the driver components?
Lexel
Lexel's picture
8A is the max current I would go, basically the power loss on the driver should stay at about 4W
9V Emitter has the advantage to be in full regulation till the cells hit LVP
EasyB
What about 3s battery with 6V XHP70.2. What is the max current it could send to the emitter? Could it do 12A? Sorry if that is a dumb question but I’m not as familiar with buck drivers.
MRsDNF
MRsDNF's picture
Last seen: 2 hours 38 min ago
Very creative Lexel. Love your work. Thumbs Up
Lexel
Lexel's picture
8A is pretty much the limit, above that current the power loss on the shunt gets an issue, as well as the FET at
The Buck chip uses a special method to detect the current that is differential measuring the inductor ripple as well
I could get the shunt reduced as well as limit the 0-1.24V PWM input value, this needs also a new ramping table on the moon modes
On the other hand I would have to reduce the inductor value as well to get the ripple increased
Also slowing Buck frequency even more to get less switching loss on the MOSFET, for that I have to order bigger lower voltage capacitors
ramptosd
Last seen: 1 week 3 days ago
Lexel, do you know how many lumens you get with this 70.2 mod?
Lexel
Lexel's picture
The LED is at its max lumens so likely close to 9000 LED lumens that got tested by other members, lets say 12-15% losses in optics
Redlyne22
Redlyne22's picture
Last seen: 22 hours 31 min ago
Anybody jave beam shoots by anychane? BtW, lexel, track8ng says the driver just hit new york. Few more days until i get it.maybe I’ll be the one posting the beam shots.
Sometimes being a newb is the best part of a hobbie
Lexel
Lexel's picture
Ill do a wallshot when I have time
Working on some new things
Redlyne22
Redlyne22's picture
Beam shots...... I just now finished my MF02 70.2. If lexel was here I'd give him a huge hug Smile this thing is absolutly nuts. Running lexels amazing driver, SLICED XHP 70.2 P21A 12volts 8 amps 7450 Lumens after 10 seconds
VS
Mateminco MT35 with a xhp35 E21A 18 AWG wires, stock driver 2280 Lumens after 10 seconds
Distance is 55 feet. Pretty self explanatory. One pair of the beam shots is with manual seetings and one other pair witis with auto camera settings.
https://photos.app.goo.gl/PxbtUzXoWsjWErno1
Nicolicous
Nicolicous's picture
Last seen: 1 hour 35 min ago
Thanks
Ive been eyeing on this for a while and unsure if i want to mod them yet.
Very keen to see if it’s worth it.
Nico -.-
EasyB
Redlyne22 wrote:
Beam shots…… I just now finished my MF02 70.2. If lexel was here I’d give him a huge hug Smile this thing is absolutly nuts. Running lexels amazing driver, SLICED XHP 70.2 P21A 12volts 8 amps 7450 Lumens after 10 seconds
VS
Looks like an awesome combo! Can you take a lux measurement?
Redlyne22
Redlyne22's picture
Ya, I think I can, I have only measured LUX on smaller throwers from 3 meters away. I’m still a little confused what the proper/Ideal distance should be for large reflectors throwers (70mm in this case) I should be farther away from the sensor? 10 meteres? What’s the ideal distance for the BLF GT? I’d like to measure my GT before and after a (xhp35 E bin 6000k) swap also.
EasyB
I would guess you need 7 or more meters to measure the MF02. Not sure about the GT.
See here for some explanation of this concept: http://budgetlightforum.com/node/55428
ZozzV6
ZozzV6's picture
Last seen: 4 hours 43 min ago
With MF02 and GT I got best throw numbers at 15-20m
