Reasonably priced LED yard light ('wow')..any others out there?
…is that ‘about’ where LED bulb technology is at right now when considering a reasonable price range for multiple bulbs in a retrofitted fixture …1600 lumens/15 watts/5000K or so?
I ask due to a person armed with some fixture and/or socket pricing possibly being able to glean some kind of initial project direction from what has been offered up here to date.
(Obvious warning: Bypass the ballast when using many of these bulbs on certain applications)
This is the basic type of indoor fixture (or even more enclosed) that I’ve been looking at for these corncob bulb options.
The problem seems to be that any 10,000 lumen+ (usually 175 watt max. rated) converted LED fixture needs to be near ‘free’ or these bulbs don’t make sense (price-wise) even with a decent Kelvin rating.
….18,000+ lumen Chinese origin light in post #1 still going strong in near zero temps. and sub zero wind chills (price went up at least $10 or so on Amazon). Still looking for a better value out there down to 10,000 lumens(+) at 4000 Kelvin or less.
An outdoor rated light capable of illuminating half a football field (or more) shipped halfway around the world then (re)shipped/handled yet again from right here in the U.S. for less than $200…how does one compete with that?
“…Still looking for a better value down to 10,000 lumens(+) at 4000 Kelvin or less….”
$165 for 10,000L @ 4000K (outdoor rated/adjustable/dimmable):
https://www.amazon.com/Morris-71831-Panel-Trunnion-Bronze/dp/B0758286XD/ref=sr_1_1?ie=UTF8&qid=1515116539&sr=8-1&keywords=morris+lighting+71831
Nothing else?
Thought that I’d check back in after a few months of nightly use in fairly cold temps.
Still…‘wow’.
I saw a house out in the country today with a std. yard light mounted up on an old tower where a windmill used to be located.
Mine is tucked way back under a flying gable maybe 4 feet.
I can’t imagine it uninhibited by shielding or simply glaring down from on top of a high pole.
Wish that someone else used these to confirm that this light’s current performance isn’t indeed a fluke…
2900 lumens; 3000K for $73 shipped (or less?)…who else is offering these?
I’m still holding back on their 4000K/100watt/12000+ lumen version as I (still) can’t believe that they’re the only ones out there dominating the lower Kelvin scale market…
For the past 13 years I have been nursing this old lamp post fixture along. Although not a yard light, I had it rigged up to throw a lot of lumens. Originally it contained a single E27 socketed bulb. I at first upgraded that to 4. Here it is some years ago with 4 - 800 lumen LED bulbs. Over the years it developed “body rot” and I kept trying to shore it up and keep it from leaking. I really love this fixture, but I just couldn’t keep it going. It needs a complete rebuild. A friend has offered to help by first sand blasting it, much of it is painted copper.
Here it is with 4 bulbs, then lately with 5.
A couple of years ago I found a commercial fixture at a ReStore for only $10, probably a $300 fixture originally
It was meant to run a 275 low pressure Sodium bulb. I stripped out the socket and ballast to make room for the 5 socket E27 setup I had installed in the old fixture above.
I didn’t get any in between pictures during the conversion but here is a picture of the installed light. This time I used 5 - 1600 lumen FEIT 100W equivalents at 3000K for a total of 8000 lumen. I tell myself this fixture is just a temporary fix until I can get the original rebuilt. We’ll see……………
(Don’t worry about the neighbors, we are set well back off the road. :stuck_out_tongue:
Good God… that thing could attract Mothra! :smiley:
Trunion mount version still working. Looking to install another unit (pole mount) on the rear of the house in conjunction with a HD antenna (I’m looking for a 26’ - 30’ pole of 4x6” lumber or laminated which I can’t seem to easily find). This quote came from MegaDepot today:
Morris Products, 71853 FlatPanel Series Pole Mount Lamp, 150W, 18,486 Lumens, 4000K Bronze
Net Ex-Works: $192.60
Shipping / UPS Ground: $17.92
Shipping Adjustment Discount*: -$17.92
Total FOB : $192.60
My next pipe dream is an easily adjustable shade or ‘tack on’ pieces which would block some of the 180 degree you-have-to-see-it-to-believe-it lumens from certain vantage points.
I wish that I had this light a long time ago yet I obviously couldn’t have afforded to buy one or operate it in the first place.
…btw, dchomak…love that original light fixture. I can see why you babied it along as you’ll probably never find another (its replacement is sharp as well). It’s no wonder that they get so much for the old fixtures nowadays.
I just noticed our neighbor has a smaller version of that same styled light.
I asked him where he got it and he told me found two of them in the basement when he bought the house!
He rebuilt his back then and it’s been find ever since. I noticed he had a “filament” LED in his, looks real nice.
I know all of this is sort of off topic, but at least it is a bump for the thread :wink:
Our replacement fixture is definitely commercial and it is wonderfully made. All pieces are cast aluminum and the top is even hinged for easy access.
Here is a peak inside looking down on 5 - 1600 lumen bulbs
The old fixture at our front door bit the dust too. Solid brass, someday I will strip it of paint and polish it up. The socket went bad along with the wiring. To the right, the old post light.
Awhile back I caught an awesome deal at Lowes for a light fixture of the same style as our original post light and I grabbed them all. I used 1 to replace our old front door fixture. I think they went on clearance because they took candelabra style bulbs and nobody wanted them. I know I didn’t back then. My intention was to convert them over to E27 sockets.
That all changed when the new “filament” style LED bulbs came out and I was able to get some at Costco in candelabra style. Here is a cheap Lowes fixture with 2 LED’s at our front door. Same style as the post light. I was even able to get a matching style light for the alcove. It can be seen hiding in the corner of the picture.
Anybody that knows me, also knows that I have the tendency to over buy when I come across a deal. Out in the garage I have a stack of 3 more of those fixtures. The arrow on the right pointsto the price I paid, $5, no wonder I bought all 4 they had.
…I tell you that you’ll probably never find another…and you come back with the fact that your neighbor has two…and that you bought a whole slew of them for $5 each… :slight_smile: I have never seen one like that of solid brass although we had a black one at our house growing up exactly like yours.
My problem with the 150 watt Morris light (above) now is figuring out how to wire the ‘dimming’ feature that supposedly is part of the inner workings:
Dimming - PWM/TIME/0-5V/0-10V
…not to mention sourcing a ‘dimmer’ I’m guessing at an industrial electrical wholesaler.
This application won’t be under a flying gable where it is much less obnoxious. I’d like to be reasonable in terms of what this thing will look(glare) like 25-30 feet in the air where I’m second-guessing that side shades won’t do me any good.
I just couldn’t pay the same amount of money for less lumens as I don’t believe that they cost much less (ok, I just couldn’t bare to have any less light than I have out front and you just have to see 30 years of pitch dark turn in to day to believe it). :wink:
I ended up at ProBuild (great service) and ordered a 28’ x 5 1/2 x 4 9/16 laminated (untreated) post for $157 OTD/delivered. I’ll try the old method that we used when putting up lights outside the commercial buildings we built: two short poles set in the ground with concrete straddling the middle (main) pole set on the ground with two threaded rods drilled through all three (one for the pivot; one for the ‘lock’).
If I could figure out the Dimming feature included in the ballast– “PWM/TIME/0-5V/0-10V” I could probably find a schematic somewhere to add a long range motion detector and a dusk to dawn control (wish that they sold all three as a package).
“…You have to be smart than what you are working with…” the old geezers used to say. :wink:
…woke up in the middle of the night worrying about beam adjustment using the pole style that I picked and overhung weight versus the trunion mount version 28’ up. It turns out that they are the same concerning the latter. There is no adjustment on the pole style yet I don’t see anything else that is (cough) ‘outdoor rated’ so we’ll just have to see how this one holds up to mother nature with a little silicone everywhere to help.
Back to bed…
Welllll….I’m back to the original (adjustable) trunion mount after finding out that the pole mount is obsolete and will be replaced in 60 days. At least this company is advancing with next generation models which is always a good sign. I found another light with similar or even better specs. (3000K) yet it is over 8# lighter and doesn’t look like it has the more defined cooling fin design of the Morris product. https://www.superbrightleds.com/moreinfo/led-flood-lights/150-watt-high-power-led-flood-light-fixture/3568/#tab/Specifications
you led wall mount light looks impressive. it would be perfect if they are compatible to motion sensing and solar power units
I’m guessing that any solar (battery driven) unit which could maintain 150 watts would work. As for motion capability I’m guessing again that I will be able to study any common wiring setup of at least the same wattage and swap out any detector to adapt. A lot of guessing…yet my main concern is finding someone who can explain the dimming system to me (above) so that I can incorporate a dusk to dawn accessory as well.
My ‘unicorn’ seems to be a plug and play, long range (preferably) motion detector with dusk to dawn sensor and compatible dimmer which doesn’t seem to be possible given the feedback here to date.
I’m a little surprised that more aren’t in to high lumen/low Kelvin lights of this size as they are the tiny ones costing much more. :wink:
Check out this recent thread. There seems to be some posters that know what they are talking about.
LED Panel Dimming help please
Thank you so much my friend. After struggling with MegaDepot to (finally) get this light ordered today, your help will (finally again) allow me to finish this project less the long range motion detector.
RAB used to make (stupidly expensive) detectors which I swore by until every single one of them eventually failed/took out the (500 watt halogen) lights with them. I’ve never ran in to anybody else who used these and hate to throw them away lest they be fixable (100 foot range believe it or not). :frowning:
Morris has obsoleted a number of their lights of late and has moved on to mounting configurations requiring a second accessory mount to be purchased. :frowning: The good new is that they are apparently trying to improve what are some very low Nema beam angle numbers in their area lighting line.
Whether this will translate in to significantly higher prices is anybody’s guess. The first lights will(?) appear in May with higher NEMA numbers and supposedly be followed with even higher angles by the end of the year.
I’m happy with the promised improvements yet didn’t realize how low that these Nema numbers were in the first place due to where my first light was mounted under a flying gable.
I think that they told me a ‘4’ by May and a ‘5’ by 2019 yet I need the latter (minimum) up on my 28’ pole and will probably start looking for a ‘7’ if I can find one in 4000K or less.
Have any other free world or overseas (reasonably priced) lights made this far of a jump yet(?)…or is Morris the only one out there plugging away with (lower bean angle) high output/low Kelvin lights for the common man?
(beam angles explained): Beam Spread & NEMA Types | Flood Lighting Technical Application Data – Expert LED Lighting
