21700 tube light
22 posts / 0 new
pinkpanda3310
pinkpanda3310's picture
Last seen: 13 hours 47 min ago
21700 tube light
I didn’t take any pics during machining. It’s not finished yet but soon. I need to remake the bezel and finish installing the driver. Driver is this one Reflector and lens are stolen from an old uf2100. Led is xhp-70, hopefully the donut hole won’t be too bad because the reflector is op. Total length of the light is pretty long but otherwise I like the size.
….and the really funny part is…. I don’t even have a 21700 cell..!!!! Big Smile LOL Facepalm
raccoon city
raccoon city's picture
Last seen: 9 hours 31 min ago
Looks beautiful!  :LOVE:
Is the body stainless steel?
If so, I don't know if that's a great idea using an XHP70...
pinkpanda3310
No it’s only aluminium. Thanks racoon Beer
raccoon city
pinkpanda3310 wrote:
No it's only aluminium.
Okay, good.
Very classy looking.
ZoomieFan
ZoomieFan's picture
Last seen: 1 week 3 days ago
A shiny shiner Smile
I have a 18650 and 26650 light and would like to try a 21700 as EDC. Looks like an ideal format.
Pity it’s long (how long is long) but the diameter is great. I like lights with a minimum diameter head and body.
Chargers: 1xBasen BD01 5/5, 1x Gyrfalcon All-88 4/5, LiitoKala: 3x100 3/5, 2x202 3/5, 1x402 3/5., MiBoxer C4-12 3/5.
Flashlights: DQG Tiny III 26650 5/5, FiTorch MR35 3/5, Haikelite SC26 HD 3/5, Lumintop Tool AA/AAA 4/5, Nitecore LA10, Sofirn C01 BLF 3200k/5600k 2/5, Zebralight H600Fc 3/5.
Powerbanks: EasyAcc 26800 mAh 3/5, Xtar PB2 4/5, Xtar PB2S 5/5
Waiting for: (DQG Tiny) 21700 EDCs.
ZoomieFan
ZoomieFan's picture
DavidEF
DavidEF's picture
Last seen: 3 days 17 hours ago
Nice one! Are you going to test it with 18650 or wait until you get a 21700? I’d like to see the beam shots!
- The YKK Philosophy
pinkpanda3310
Diameter is 25.5mm , length 133.5mm Here is a comparison shot (it looks extra skinny because it’s shiny)
Yes I do plan to test it with an 18650. In fact, I might even hold off remaking the bezel to see if I like the beam first. That way if I don’t like it I can make a new bezel to suit a different reflector.
DavidEF
DavidEF's picture
In that shot, it looks a little like a SF (or BLF) 348.
derfyled
derfyled's picture
Last seen: 2 weeks 6 days ago
Nice ! Now drill some tiny holes in the fins, you will be able to insert some tritium tubes ! Practical and awesome…
CRX
CRX's picture
Last seen: 4 hours 48 min ago
LOL
Very nice though Thumbs Up
eas
eas's picture
Nice! And great to see someone building 21700 lights Smile
ChrisGarrett
ChrisGarrett's picture
Last seen: 14 hours 44 min ago
Very nice.
“I’d buy that for a dollar”
Chris
moderator007
moderator007's picture
Last seen: 40 min 14 sec ago
Nice job pinkpanda3310, time well spent. I would be interested in how the driver performs.
MRsDNF
MRsDNF's picture
Last seen: 10 hours 34 min ago
What can I say but Wow. That is some sweet machining. What pitch threads did you use and how is the driver held in?
pinkpanda3310
Thanks guys Beer
The thread is only 1mm. I previously said to myself that I’ll try larger threads but when I started this build I already had some tube to use for the body. I was thinking the smaller thread was probably better on the thin wall but now you made me think about it I could’ve used courser threads in a shallow square cut profile. That’ll be a lesson in itself (learning to cut square threads Grad ).
At this stage the driver is planned to be a press fit. If that doesn’t work out there is enough space to cut some threads and use a retaining ring.
I might get time tonight or tomorrow to fit the driver and wire it up for testing.
MRsDNF
MRsDNF's picture
Thumbs Up Thanks. 99% of my threads are also 1mm.
pinkpanda3310
I got this thing up and running today and time to celebrate it worked first go Party Crown Innocent The press fit driver seems to work fine.
Some quick beam shots with my phone. It did some auto correcting as indicated by the fading sky in the background. The beam does have a donut hole but only if you’re looking for it. Pics from low to high
I like the mode spacings too. The pics above indicate they are close together but in person they more evenly spaced. I took some tail cap measurements with a 30Q. I think it measured just under 4v when I started the test. Just bare in mind my DMM is a cheapy Wink
Very low – 0.01a
Low – 0.48a
Med – 2.05a
High – 6.70a
I noticed it got warm pretty quick so I did another highly scientific test
Ambient bench temperature was 27 celcius. Adding some black tape to the head increased the temp reading by about 3 degrees. The light already had some use so the starting temp is higher than ambient (I’m far too lazy/impatient to wait).
Starting temp – 31C
10 seconds – 36C
30 seconds – 44C
50 seconds – 52C
60 seconds – 56C
I’m not aware of the driver having turbo timer so this light is definitely not for muggle use Steve One other point that is a minor negative is the driver changes modes from off position. I’m not sure how to explain it properly but it’s like the opposite of next mode memory. If the light is on – 2 taps are needed to change to next mode. A quick double tap will put it in strobe. On the upside it does have mode memory.
Overall I’m pretty happy with it Davie
moderator007
What I have done a few times to get the driver a good ground connection is machine a thin ring of brass or cooper to press fit down in the heat sink. Cutting a small shelf for the driver to fit down in flush with the top of the ring. That way the driver can be soldered directly to the ring. Looks like you might have been tight on room but might still work if a little was filed off the driver ring. Maybe yours will work fine the way it is.
This is similar but it needs to be cooper or brass, I made this one out of delrin so that there wasn’t a connection back to ground besides the light tube contacting the driver ring, its a twisty light. Head has to be twisted all the way down to contact to turn on.
Takes a lot of work to make your own light, Great job! Thumbs Up
MRsDNF
MRsDNF's picture
So I guess this ones a keeper. Smile
Whats next on the build list?
pinkpanda3310
Lol, like many people on this forum there’s always something rattling around in my noggin. Don’t know which one will make it to fruition.
007 I considered a press fit retaining ring but thought it has limited benefits over the current set up. As it is the driver is a firm fit so ground contact is good. If I make a retaining ring I’ll definitely go for threaded.
moderator007
The reason I mentioned it, is I have Had a few drivers that didn’t make good contact to ground. The light would flicker, not light up unless bumped or change modes on its own. The driver your using looks to have a way better ground ring than any I have used. It may work fine, but if you use something like a amc7135 105c driver it may give you problems. At least it’s a simple fix. Wink
