Convoy
Eagleye
Thorfire
Zanflare
Sofirn
KD lights
The key to not receive latticebright LED flashlights is to not buy $4.99 flashlights with 20,000 claimed lumens on ebay or aliexpress.
Convoy
Eagleye
Thorfire
Zanflare
Sofirn
KD lights
Jaxman
Sounds like you are itching to buy…
You can’t go wrong with a Convoy C8.
You have the advantage of LED choice & some customization, when ordering through the genuine Convoy sore, plus the BLF discount, if you message the owner, Simon.
I would drop the maglite from the list. They’re still made very solid but way under-powered so far. When they catch up I’ll buy one for old time’s sake.
PS - welcome :+1:
BLF A6, and a lot of other lights made for BLF.
I picked up a Thorfire TG06S last week. I think it was asround $11 on Amazon. Fantastic little light.
+1 nailed it right there perfect list.
The only reason to buy a cheap light like the 501, or 502 is for a host. But for about 5 dollars more $10 11 dollars you can get a quality convoy host from mtnelectronics
One thing about the Zanflare though, is that it’s a really good budget light, if you wait and use a good discount code for it. For example, the F1’s MSRP is $40. Standard Gearbest’s discount code today reduces that to $24. But the last couple of months, the price went down as low as $13, and even $10. :heart_eyes:
… We’re talking seriously good value here. :sunglasses:
I still think Convoy offers the best value for expenditure.
I don’t care how much you pay, you’re not going to beat the quality of an M2 or an ‘S’ anything, or an L6. More money might buy you something fancier, but it won’t buy anything any more robust or functional.
Of course, the ‘big brands’ are good too, and more prestigious if that’s important. I have Olight, Thrunite, Fenix and several others - but the Convoys still impress the heck out of me, and they’re a delight to mod any time I feel like upgrading drivers or emitters.
Can’t forget about solar force if you are looking to have a p60 host.
Astrolux, emisar, utorch to name a few more. Some of the older trustfire and ultrafire lights were solid, bit have no clue about now.
Yep, the L2M is quite nice, too. Forward-clicky switch, convertible from an 18650 to 18350 with the 2-section tube, nice and flexible.
Wotdahell… 2nd post that didn’t “stick” after hitting “save”.
Anyway, the ’502 is an awesome host, and I still EDC one every day.
You can build whatever kind of drop-in you want, change them on the fly, and the ’502 is a little beefier than the ’501 and conducts heat better. Great finish, buttery smooth threads that are dead silent, not a hint of scratchiness to them.
Dunno the quality of recent ones, but the quality of those ’502s from 2-3yrs ago were almost Convoy quality. Back then, they came with genuine Crees or at least good LatticeBright clones. The switches were solid, never even a hint of failure in my EDCed light. And they were hella bright, at least 500lm or more. Of course, they were always H/M/L with damned blinkies, so the first thing you do is toss the emitter/driver and use the rather beefy pill for the emitter/driver of your choice.
Then again, generic C8s were similar, decent emitters (’though CW), solid hosts, beefy pills, good switches, etc. Then quality nosedived fast in just a year or so. Then, they started coming out with fake LBs, barely an XP-E sized chip, making at best 2-digit lumens. Seriously, a nice tight hotspot due to the smal emitter, but barely 70-80lm. Plastic reflectors(!), scratchy threads, thinwall battery-tube, pure garbage through and through.
So, you might luck out with a good ’502 to use as a host, or you might not. Worst case you spend 5bux on a light that you can give to someone you hate.
But the ones I have… flawless.
Plus, I love the design of the ’502. Perfect feel and balance. Try one (or more).
Don’t forget Klarus, and the very good quality smaller lights from Jetbeam and Utorch. I have an Mi7, Jet-U, and UT-01. Quality performers each with unique characteristics. Nitecore are not often budget, but the keyring models are fantastic, particularly the Tip.
BLF A6
Emisar series
Haikelite
Yeah, the TR3T6 was my war tank for 2~3 years with 6 hours per day average. The only bad thing is that not water proof, a simple whash can fill the reflector, mine occured that and even with water drops growing up through those leds the light still worked for a long time until the driver burn, after that it run in direct drive without driver, very bright and alot of heat
I cannot has luck anyore with trustfire after that, TR-J12 worked few months afet I shaked hard that pulling some cables, TR-T1 I replaced the driver 2x it only need a little fall and the driver break :person_facepalming: , TR-A9-2 CRAP :cry:
I decided not buy trustfire anymore after that, but TR-J20 still have my attention, if the price was lower…… :weary:
Darkus? No this brand not suposed to be in reliabe list….
I need to thanks my friends here specialy FlashPilot to help my problem solve :+1:
So, budget and reliable for me is Thorfire for sure, my S70 still works after almost 2 years and tons of hours of ceiling bounce and “high falls” :innocent:
I have a pair of Singfire flashlights. SF-348 AAA light and a SF-75B 18650 light. Both nice stainless bodies and both came in cheap, <$5 an <$10 respectively. I would rate them as exceedingly adequate!
Hello
I also want to buy the Thorphire TG06S for $ 11
had a discount or a coupon ???
thank you for the reply
The UTORCH UT-02 is an absolute bargain along with the Astrolux MF-02 which for the price with coupons is quite unbelievable value for money
Jetbeam has some very nice budget lights with good quality
Or Sofirn
Astrolux S41 over app or with coupon is a steal
utorch UT-01 is a great $10 light, small, very bright, good UI
Astrolux S1/ BLF A6 is a great light, great UI, about $15-30, uses 18650 for good run time/brightness
