^ Makes sense. But I do notice with my Astrolux MF01 that batteries do drain quite fast if you use turbo (~10000 lumens) regularly. It’s a bit borderline whether it makes sense or not, but man it will look good. :partying_face:
the retail lights will peak on 7000 lumens or so… only a few sample lights dont produce more then 4000 lumen for some reason. As the light is 7500 lumens to Haikelite it would be strange it it peaks just half that, so no worry.
I think he’s talking about continuous output that the light can maintain, not max.
Please allow me a short note - I just found a possible error in the manual.
The LED in the switch which shall indicate the power level of the batteries is mentioned as:
- 100% to 50%: Blue LED on
- 50% to 9%: Blue LED flashes twice every 10 seconds
- below 9%: Red LED flashes twice everx 10 seconds
In fact, my XHP70-version shows more likely:
- 100% to 15%: Blue LED on
- 15% to 5%: Blue LED flashes every second
- below 5%: Red LED flashes every second
Regarding the 15 or 5 I have to add that I did not measure it - I just had the impression, because the flashlight worked for hours with the blue LED on, but after it started blinking it might have taken 20 minutes until it changed to red.
When this happened I just made a small test (yes, double klick still works, even though the “Turbo” is no real Turbo anymore, understandable…), took out the batteries and directly placed it in the MC3000, reading 2,93V.
Also: please do not drive it down to the end using unprotected cells - Markus from lilahand.de already found out that the Anti-discharge-protection of the MT09R does not work. With empty batteries the flashlight will enter some kind of “Moonlight”-Mode, where it stays for the rest of the battery-life.
He stopped it after 24 hours measuring 2,49V at all 4 batteries… at least it takes out the energy quite balanced…
Thanks. You might want to check whether the 35 shows same or similar behaviour (to see whether it is an isolated case or not). I’ve had issues with the battery indicator on my MT07S 70.2. It blinks blue, even though the batteries are full (close to 4.20V). I don’t know what will happen if I deplete the cells though. The odd thing is that I’ve done two driver swaps, and identical problem remained. On another driver the battery indicator does not work at all. So I have four drivers for the MT07S not functioning properly. The light itself works well though.
Your wish was my command.
While having another DT70 working with unprotected flat top, I used their batteries in the XHP35. The experience is similar & different:
- it’s similar, because also this one does not blink every 10 seconds, but like the XHP70 every second
- it’s different because it changes from “on” to “blinking” at 3,63V - so in this case the 50% seem to be real. Based on this also the last changing level (the above mentioned 9%) seem to realistic - after blinking red I measured 3,02V
Conclusion:
- the type of signal does not correspond to the manual
- the XHP70 seems to signal the levels wrong
- the XHP35 seems to signal the levels right
Regarding the XHP35 I just recognized another point:
While running at about 1.200 lm the MT09R gets hot - and I mean hot in a way you do not want to hold it in your hand. This is - from my point of view - interesting, because we talk about a quite low energy level. While running the XHP70 at the same level I did not even recognize a raise in temperature.
Hopefully this is just another indicator for a faulty driver…
Interesting. If the 35 gets too hot, it means the batteries are being drained, although the led is not getting the most of it. This could be tricky, but the batteries are not exceeding safe discharge rate and temperature as the Imalent cells are protected 30Q. But this driver is going to be replaced anyway. Thanks for the data!
Which from my point of view can be the problem of the actaully delivered XHP35-Version with the output at 3.500 lm and not at the specified 7.500 lm (or actually corrected 7.000 lm).
It seems like there is something in the driver that consumes the power instead of bringing it to the LEDs…
Nope, the IMALENT was running on unprotected LG HG2 - which in this case also do not have a problem with the current. And if you ask yourself regarding the DT70: it’s one of my last ones which has spring contacts in the tube - the actual versions run on protected AND unprotected cells…
When is it available for purchase? I haven’t been paying attention.
The MT09R is actually out for delivery.
Depending on the country you live you might check for the sales reps - for North America it’s Terry, you find him here as Haikelite USA official
Official GB shipped directly by Haikelite closed two weeks ago on 31/01/2018. See GB thread here.
Terry who now represents Haikelite in US and Canada may still have a couple of lights available for sales, but he only ships within US and Canada. If you are in US/Canada, you can order from his website, He Said She Said Sales.
Well I got two sets of 30Q charging; one set in the Zanflare C4, and the other in the VP4. Tracking says that my lights will arrive tomorrow, woot! :sunglasses:
Late to the ship. Anyway, if anyone has CW either blue or green light I wan to buy one.
Is this the same light that the GB just ended last month?
Yes.
What was the GB price?
It’s right there in post #1 of the Group Buy thread.
There is an odd bug on both my green and khaki 70 versions. I think (hope) it’s just a minor error in the battery indicator section of the programming firmware.
When batteries are depleting and battery indicator starts blinking blue, which means voltage is about 3.6V~3.7V, then the battery indicator blinks on level 1 till level 4, but on turbo the battery indicator remains solid. It behaves like this until batteries are depleted until ~3.0V and battery indicator turns to blinking red for all levels from moonlight to turbo.
Anyone with the same phenomenon on their 70?
There is an odd bug on both my green and khaki 70 versions. I think (hope) it’s just a minor error in the battery indicator section of the programming firmware. When batteries are depleting and battery indicator starts blinking blue, which means voltage is about 3.6V~3.7V, then the battery indicator blinks on level 1 till level 4, but on turbo the battery indicator remains solid. It behaves like this until batteries are depleted until ~3.0V and battery indicator turns to blinking red for all levels from moonlight to turbo. Anyone with the same phenomenon on their 70?
I will double check but I'm pretty sure about this.
Turbo is set up so that anytime it steps down you are able to kick it right back into turbo regardless of heat. Basically if you make it the light will bypass the heat and power output that goes with keeping it in turbo even after step down.
This is not a step down from turbo related phenomenon. It’s about what the battery indicator does as a function of cell voltage, and on what level of output you are. The battery indicator should be blinking blue below a certain voltage, but remains solid when in turbo. It’s supposed to be blinking too.
