Overly easy access to strobe in a non-tactical light. The Manker U21 has a very frustrating UI. Long press for on to anything other than moonlight, double click shortcut to strobe rather than turbo, click to advance between modes, and long press for off. At least they got rid of the double click strobe in later lights.
Thought about it some more. These are my deal breakers. In order of magnitude. No proprietary or glue-sealed battery designs = I must be able to replace a dead battery of common size/chemistry. I do not want to field re-charge a dead battery with a battery bank and USB cable. Totally impractical.
No CR123 only = Its 2018, I have been posting this one for almost ~15 years (!!!) on CPF well before BLF days. I can’t believe I still need to post this as a bullet, but none the less, there are still designs out there. If it only takes CR123 cells, its totally useless to me.
No 3AAA & 4AAA = Inferior in so many ways, although I would take a 3xAAA light (of comparable quality) any day over a CR123 only light.
Battery carrier/caddy = No thanks, just one more thing that can fail. Physically its another thing to get in the way when field reloading cells.
Mechanical power lock out = Must have, I have nearly burnt my hand on lights that were accidentally turned on for lord knows how long in my pack… annoying as hell
Low frequency PWM = I am very sensitive to this, although it can be fixed with a DIY driver mod. Still as long as I have a choice, I will pick a light without low frequency PWM.
Dislike a Long (3+ sec) turn on, long off doesn’t bother me.
PWM (bad PWM actually makes me feel sick)
Cycling through STROBE or even more than a couple of modes to turn off
Non hidden strobe and signal modes in general
High parasitic drain (most of my lights are on standby a lot)
Sharp blue or green tint
No lockout (prefer mechanical but will take electronic types)
If I have to choose, I want a light to turn on in the lowest mode, NOT the brightest
Shallow or tiny thumb buttons
Side buttons that you can’t find by feel alone
No low warning (a flash or whatever) before shut-down
Power/mode buttons that I cannot feel or see in the dark. :rage:
Imalent perfected that on the DN11 and DN70. Obviously not a single one of the designers ever tried to take the lights out of his pocket and switch them on in the dark /with gloves.
Nice lights otherwise, with an impressive design fail on the first and major feature of a flashlight. :person_facepalming:
Strobe being in the main sequence, as in L/M/H/Strobe/L/M/HStrobe
The very annoying “blink on low” convoy 3/5 mode lights use to signal when you can change modes to include/exclude strobe and SOS. I use low a lot and it’s a pain to have the light blink a few seconds after you turn it on
UI’s that take a PhD in rocket science to figure out / program
Gritty threads on tailcaps
Lights that come from China without instructions, usually received in crushed cardboard boxes.
Imalent had another massive fail… those electro-sensitive buttons (or how that junk was called properly) did not operate in wet conditions, even in rain or wet hands. There were videos of users unable to change modes or even turn off that damned things.
- Forward clicky switch with next mode memory - Using your light on low and turn it off? Next time it turns on medium, even if you want Low again.
Proprietary battery packs. Let me use multiple 18650s, that way the batteries can be swapped out when dead, instead of having to wait for the pack to recharge. Oh, and if that battery pack wears out in the future? Good luck getting a replacement. While with a multi-18650 light, you can easily get new batteries. I’m not buying a Nitecore, Fenix, etc. multi-emitter light if it requires a proprietary battery pack.
It ain’t the blink that bugs me, so much as the actual modegroup change.
I usually keep my lights on low(est) anyway, so if I’d just flick it on for a few sec to check out something, and click it off right as it blinks… oh, crap, don’t tell me… yep, turn it back on and cycle it through, and the damned blinkies are back. Then I gotta wait again for the blink to change it back, then go through another cycle to verify it.
And let’s face it, most times for a quick flash’n’dash, you just want the light on for a few sec to check out what’s in the closet, where you dropped that whatchacallit, etc. And it’s about the same time window needed for the damned mode-change.
And as for my most annoying feature, how about a lack of a feature: not having multiple interface buttons. Seriously, how hard is it to have one button for on/off (maybe with long-press or double-tap options for shortcuts to min or max power), then one button for “brightness +” and one button for “brightness -”? Instead, we keep getting Dilbert-style interfaces: http://dilbert.com/strip/2016-06-12
Then it’s getting to be 100% proprietary, no possibility of modding it. You’d have to be happy with the light right out of the box, else you’re SOL. Just as bad if not worse than gluing the crap out of the light after potting the innards.
Most lights with an e-switch on a board soldered to the main driver board are already nigh impossible to mod. With multiple switches, forget it.
Hell, I’m happy with a 1-mode ’502 for my EDC, but for other lights, simple modes (with memory) is fine.
Eg, my SP10B, I pretty much keep on firefly mode, so just turning it on will get me that without blinding me. But a quick doubletap for turbo gives me full brightness. Anything in-between, I turn it on firefly, then click higher as needed. Done. Then back to firefly before turning it off.
My Jet-II, same dealy, only it’s a twisty that always starts on low. Works for me.
SF31W, again, I always reset it to low/moonlight, then click higher as needed, then reset it back.
Some lights, like my C8Fs (old and new), Hell, I always keep ’em cranked up to 11. Otherwise, what’s the point?
Otherwise, just get a light like a DV-S9 with its slider, and set it to whatever you want. Parasitic drain? Uncrank the tail ½-turn. Done.
I agree with whoever said that he dislikes lights which pretty much require you to carry a book to work the UI.
Like, how hard is it to just reset the light to low/moon/firefly before turning it off? Why does there need to be separate shortcuts for each mode, like the 27% half-press, etc.?
A nice simple tail-clicky is always easy to find (hardly so with a side-clicky), so the simple on/off is the only way to control the light. That’s why I like the SF31W so much. It does pretty much everything with that nice simple interface. Just remember to reset it to low to avoid getting blinded at night.
