they replace the washer in the tail, you need from Convoy a set of transparent switch covers
Simon sends them for a small compensation to you if you message him on Aliexpress
Any color combination you want is possible
I have also a 4 LED side switch version for the L6
I also have 4 LED boards for side switch on the L6, so always one switch is lit
L6 as e-switch light has limited current on the tail one as the bleeder resistor needs to to be pretty high (0.15-0.3mA)
Ill get in next days a L6 to mod then I can test the driver, the L2 driver has an odd behavior that you do not need a bleeder as the driver bleeds already to an LED Tail board
Looks very nice Lexel! I have a hard enough time matching same color LEDs and experimenting with resistor values in my lighted tailcaps, let alone the complexity of what you have done. I admire your ingenuity. :+1:
I did today more testing with my Convoy L6 drivers and illuminated tail caps
Final result is that with the parts I use on the driver I can feed up to 1mA to the tail cap without using a bleeder resistor, so there is no standby drain from a bleeder at all when the light is switched on over the tail switch
This is likely due to the voltage regulator I use that is so friendly and bleeds for me to the tail cap
The rainbow board is designed to light up equally bright even with the cell voltage dropping down to about 3-3.4V depending on brightness and Bleeder resistor values
