Still works! Just tried it!
Thanks!
Please bring back Ultrafire COB Light in the future.
Need to check the innards
for future bulk purchase.
I picked up 2 Ultrafire F13’s, Thanks Bilakos10.
The S2+ code is not working. Could I get that? code was bilakosf27 link: https://www.gearbest.com/led-flashlights/pp_44144.html?wid=21&lkid=12980137
Much Thanks Again
Notice: In order for Gearbest to credit my sales, the products must be purchased through the links provided through this topic.
If you have already got a product in your cart and want to use one of my codes please remove it and add it again using the links that are available below.
Active Deals
15/2/2018
Available for these countries:
HK,US,CA,MY,TW,GB,IE,AU,NZ,IN,SG,ZA,PH,GR,NL,HU,SK,CZ,HR,BG,SI,RS,TH
Where are you from mate?
I got a code but it’s only applicable for just 4 countries!
Please code for LK 100, thank you.
Code for xiaomi 70 was F53 (not 52). Says expired now. Was it valid?
There you go Gregor :D
You are correct, the correct code was F53. According to the usage report I was given by Gearbest the code shouldn't be expired, but it seems that it is...
Thanks for noticing it, I have now removed it :)
Thank you.
Ordered 2 x LK100
Tomorrow I will make sure to post some convoy deals that are limited to US, CA and a couple more countries. Make sure to stay around!
Will do, Thank You
Hi Bilakos10,
Can you include the Netherlands (NL) in those Convoy deals?
Hoping for a cheap S2+ deal.
Thanks alot!
Best regards
Hi Gijs, did you try to buy one of bilakos’s deals? I got at least 8 deals from his codes last month.
@bilakos, received the Xiaomi WOWSTICK today and it is really neat, thanks for the code again.
May I request a code for
UltaFire W-51 COB 180-Degree Rotating 5-Position USB Magnetism Work Light
Getting an error code is expired.
Thank you
You are welcome my friend
Enjoy your new tool!
Hi SpAwN,
Yes, I tried both the S2+ for 6.99 and the S9 for 12.99. But I guess I was late, codes are expired.
But now I will check the board more regularly so I won’t miss the next one.
Cheers!
