*** NEW *** Haikelite MT09R Monster lights *** Update *** 2018-07-03
When is it available for purchase? I haven’t been paying attention.
The MT09R is actually out for delivery.
Depending on the country you live you might check for the sales reps - for North America it’s Terry, you find him here as Haikelite USA official
http://budgetlightforum.com/user/27241
Official GB shipped directly by Haikelite closed two weeks ago on 31/01/2018. See GB thread here.
Terry who now represents Haikelite in US and Canada may still have a couple of lights available for sales, but he only ships within US and Canada. If you are in US/Canada, you can order from his website, He Said She Said Sales.
Well I got two sets of 30Q charging; one set in the Zanflare C4, and the other in the VP4. Tracking says that my lights will arrive tomorrow, woot! :sunglasses:
Late to the ship. Anyway, if anyone has CW either blue or green light I wan to buy one.
Is this the same light that the GB just ended last month?
Yes.
What was the GB price?
It’s right there in post #1 of the Group Buy thread.
There is an odd bug on both my green and khaki 70 versions. I think (hope) it’s just a minor error in the battery indicator section of the programming firmware.
When batteries are depleting and battery indicator starts blinking blue, which means voltage is about 3.6V~3.7V, then the battery indicator blinks on level 1 till level 4, but on turbo the battery indicator remains solid. It behaves like this until batteries are depleted until ~3.0V and battery indicator turns to blinking red for all levels from moonlight to turbo.
Anyone with the same phenomenon on their 70?
I will double check but I'm pretty sure about this.
Turbo is set up so that anytime it steps down you are able to kick it right back into turbo regardless of heat. Basically if you make it the light will bypass the heat and power output that goes with keeping it in turbo even after step down.
This is not a step down from turbo related phenomenon. It’s about what the battery indicator does as a function of cell voltage, and on what level of output you are. The battery indicator should be blinking blue below a certain voltage, but remains solid when in turbo. It’s supposed to be blinking too.
I know my order was shipped 2 weeks ago. I have the tracking number. How do I track it? Where do I go?
I guess you open the google, paste the tracking number, then search…
You can use this one for example.
Thank you. I didn’t know it’s coming from the Netherlands.
Is Charger going to ship out soon?
I hope so, but I do not know. Perhaps Terry knows more.
If you are in Turbo at cell levels low enough to already be giving a warning, then chances are you are also kicking it back into turbo past the 55 degree C stop down. (Not saying you are just that there is a good chance of it with most) It will allow you to bypass that feature including any power requirements needed. That I am aware of it will not flash at all in turbo. If the cells are already low enough begin flashing, then you are below any level that should be attempting to hit 15 to 16 thousand lumens.
So when I said it will allow you to keep kicking it into turbo until you either can’t stand the heat or you kill your cells I meant that literally. It was designed to use turbo ay anytime… And if you are getting a blue flash you are between 50 and 9 percent. Why try to go to turbo once that warns you that you could possibly be as low as 9 percent already.. This would mean it is time to stop and charge or change the cells.
The instructions even tell you that it will not ready correctly in turbo.
Nothing will ship out until after the Holiday.. I will ask for a more detailed answer later when I talk to Dale..
