My little project for today
16 posts / 0 new
charlestt
Last seen: 1 year 12 months ago
Well just for Al here's my latest led project..
For those who don't know these are philips lumileds 1w so  thats 3 per side :)
A little bright Smile
Installed sorry for the poor iphone pics.
 http://i776.photobucket.com/albums/yy41/charlestt225/Sig/A1200023-1.jpg" width="159" he
Edited by: sb56637 on 02/14/2012 - 08:18 Reason: sb56637 replaced budgetlightforum.cz.cc with budgetlightforum.com via Scanner Search and Replace module.
Don
Don's picture
Last seen: 2 years 1 month ago
Did it take long to build?
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
alfreddajero
alfreddajero's picture
Last seen: 1 year 6 months ago
All i can say is WOW......that sucker is bright.
With Darkness, there will always be Light.
charlestt
Hi Don once i got all the bits together i'd say about an hour. unfortunately the heatsinks were too high so had to cut them down to get them to fit..
Don
Don's picture
Which is why my favourite tool is an angle grinder...
alfreddajero
Mines a Dremel with a sander barrel at the front.  Hmmmmmmm that sucker is bright, you might think of just using one led per side.
charlestt
Unfortunately i have neither so a junior hacksaw is my friend :)
Al you can never have too much light...
They are much better in real life my phone over exposes a fair bit.
Don
Don's picture
So bought an angle grinder. Just remember to wear eye protection.
Iron filings in the eye rust and stick to the eyeball and have to be lifted off with a needle. This is about as little fun as it sounds.
Believe me, I know.
alfreddajero
Okay......they just look bright.  Is there any way you can put a colored filter over the leds.  Might be awesome if a color were to show.
charlestt
No reason why you couldn't put a colored filter behind the lense..
Don
Don's picture
Construction and Use Regulations?
My father has a copy along with the essential commentary on it produced by Grampian Police and issued nationally. I have a feeling that for road use lights for number plates have to be white. And not bright enough to upset speed cameras. Will check. Which is a tedious business as it takes 22 pages to say that on traffic lights, the red light goes on the top, the amber one in the middle and the green one on the bottom.
charlestt
True but a filter on them would be ok if used for show purposes..
I need to re-look at the heatsinks i had to cut down the ones i used buy about 1/4 so im afraid that wont be sufficient, I have some iron bar in the garage about the right size anyone know if that would be ok to use..
alfreddajero
You might want to find some aluminum.....
Don
Don's picture
Power shouldn't be a problem - attach a suitable sized fan to the heatsink. What sort of temperatures are they running at? Try to avoid little fans - they are annoyingly loud.
Does the hot air have anywhere to go? Ventilation (in a way that doesn't allow water to get inside) might be all that's needed. Or a bigger resistor - turn the current and brightness down a bit, less heat to lose.
In still air I've run a rather inefficient 5W led on the heatsink of an old Pentium chip with no forced cooling.
charlestt
Hi Don the air is still as its inside the bootlid/tailgate there is quite a bit of air in there though but theres not really anywhere for it to go.
I thought about adding a fan but again i have run into space issues.
BTW the lights are outside of the main body and the heatsink is making some contact with the boot lid.
Charles
Don
Don's picture
If you can get thermal contact with the boot lid, you have a most excellent heatsink of rather enormous size. I'd be tempted to cut the fins off and get the heatsink as tightly in contact with the boot lid as possible. Using a thin layer of heatsink goo and some means of holding the LEDs in place.
Actually, I'd probably just use it to see what happened, easy enough to fix later if need be. As long as you can keep the LEDs below 70 centigrade not to much can go wrong.
