Lexels driver compilation
249 posts / 0 new
Lexel
Lexel's picture
Last seen: 11 hours 37 min ago
TA drivers:
http://budgetlightforum.com/node/59724
12/15mm
17mm Programming Key and new LX
new 17mm for 2 S eliminating AMC7135 dedicated indicator resistor and pad
2 channel (Narsil with indicator)
3 channel (Bistro HD)
17mm 10 AMC no FET
17-19mm
20mm
new 1S/2S combination from my LX driver
Astrolux S42 20,5mm (kind of obsolete with S43 now
C8F 21700 20.6mm wide copper ring
21mm
all old designs replaced with new all in one 1 and 2S
21mm for example for Skilhunt H03
20-22mm
new version with 1S 3 channel AMC and 2S dual MOSFET
22mm 13AMCs
24mm 16AMCs
24-30mm
v3.1 with a little bug fix
new 2S version without AMC for more reliability, also added 2 switch LED support
30-33.5mm LDO small current FET 1-4S
38,5mm Cuoroi D01
42mm TN42&Niwalker BK-FA-30 2S/2P DD
46mm 2S/2P MT03
new enhanced version no more AMC7135
3 step filtering to get the ringing from PWM under control
46mm 2S/4P SRK
47,5mm Astrolux MF01
47,5mm BLF Q8
Buck drivers:
Input 6 to 25V
Output 1-8A as requested
The Input and Output voltage defines the switching frequency, so they have to be set for the light
I have calculations for various options
20mm For Convoy L2 or similar
22mm
new more efficient MOSFET and minor changes
23mm for Klarus XT11/12GT running 2 18350s for Oslon BF or other 3V LED
28-30mm, 30mm cheaper but bigger inductor, new 30mm for Convoy L6 more efficient MOSFET
30- 33.5mm SD75 8A 2-4S buck
Acebeam K30
42mm TN42
new version up to 8A also for TN40S mods with XHP35s
42mm Niwalker BK-FA30 v2
47,5mm MF02
new version MF02/04S
46 mm MT07/MT07S
new version a lot more efficient MOSFET
46/47,5mm 2S/2P or 4S/1P AstroluxMF01/ Haike LiteMT03
MF01 v2 in 3S/6P LED Board mod, driver has 4S input 3S Output
MF01 v2 3S 14A dual Buck driver with new MOSFET and now single sided
Acebeam K65 the latest gen with programming port
Acebeam X45 the latest gen with programming port
BLF GigaThrower driver
XHP70.2 or White Flat up to 8A
Boost drivers:
still under development
1S or 2S Input
6V 6A or 12V 2.5A output
also made a programming adapter for my future drivers
order in 2 Oz from Oshpark that gives 0.8mm thickness
Fits those Pogo pins from Banggood
https://www.banggood.com/100Pcs-P50-B1-Spring-Test-Probe-Pogo-Pin-Dia-0_...
Edited by: Lexel on 11/28/2019 - 15:32
djozz
djozz's picture
Last seen: 9 min 16 sec ago
Shocked wow, well done Lexel! As I said before, your work and offerings are a great asset for BLF.
polarweis
polarweis's picture
Last seen: 16 hours 50 min ago
Thumbs Up
"It wouldn’t be so bright if there wasn’t a shadow every once in a while." - Jason Mraz
KawiBoy1428
KawiBoy1428's picture
Last seen: 22 min 48 sec ago
Very nice! Thumbs Up
KB1428 “Live Life WOT
lightlight22
lightlight22's picture
Last seen: 6 months 1 week ago
If I were to swap the current driver of the Q8 to one of these Lexel drivers, what would I gain?
Don't give up on your dreams,
Keep dreaming.
Sirius9
Sirius9's picture
Last seen: 1 day 11 hours ago
XD9
XD9's picture
Last seen: 2 months 2 days ago
Super saiyan powers.
lightlight22
sigh……. i wanted god powers
Keep dreaming.
AlexGT
AlexGT's picture
Last seen: 6 hours 44 min ago
What is the advantage of the BLF GigaThrower Treiber XHP70.2 or Oslon Black Flat up to 8A over a modified GT driver with resistor mod?
What we really need are DTP copper MCPCB’s in XHP-70.2 format! Love
Lexel
Lexel's picture
The Buck driver would support XHP35s, but also the tail board has to be modded to a fixed position as well the tube secured on the head
The Q8 driver is good, it is still possible to get the one with 16AMCs for regulated output up to 5.6A, the MOSFET I use is a bit better than the original, but mst gain comes from taul spring bypass
Newlumen
Newlumen's picture
Last seen: 3 days 6 hours ago
Nice lexel.. you are adding more new driver..
Newlumen
Newlumen's picture
Can you guys tell me estimate lumen and lux for thr blf gt? Xhp70.2 and oslon black .. jason, we need you!
MRsDNF
MRsDNF's picture
Last seen: 15 hours 4 min ago
Excellent work Lexel. Thumbs Up
CRX
CRX's picture
Last seen: 5 hours 19 min ago
Thumbs Up
PH_Oton
PH_Oton's picture
Last seen: 7 months 4 weeks ago
Amazing amount of effort and contribution for BLF! Thumbs Up
thulfiqar
thulfiqar's picture
Good Job!
Pöbel
Pöbel's picture
Last seen: 1 week 1 day ago
Hi Lexel, do you have any Eta on the 22mm buck driver?
Lexel
Lexel's picture
I will order first prototype boards this weekend
I make them 4 layer for better heat dissipation, but this also makes the order in china expensive and I just odered a bunch of 4 layer 2 weeks ago, so I need to fill the 10×10cm with more boards before i do a new order
Lexel
Lexel's picture
20mm Buck driver added
for Convoy L2
Satan@103TFS
Last seen: 9 hours 44 min ago
for Convoy L2
How many Lumen/Kcd can we expect for L2 with XPL hi with 1/2 LK50 ?
Lexel
Lexel's picture
That Buck driver is targeted to drive XHP50.2 basically in that light
for throw you will have to wait for the Boost driver for XHP35 at 2-2.5A
this Buck should do fine up to 7A output but is limited to 2S input
DoNkEyConN
DoNkEyConN's picture
Last seen: 3 hours 30 min ago
Nice one Lexel,
how much are the buck drivers for the L2 / Xhp50.2 ??
WTF
Last seen: 5 hours 14 min ago
Can Bistro be used with these drivers?
Lexel
Lexel's picture
sure it is designed on Attiny25/85 based footprints
Lexel
Lexel's picture
first driver that was requested for special 48A Output on good efficiency
vinte77
Last seen: 6 hours 6 min ago
Looking forward to the 20mm/22mm buck drivers. I got Jaxman Z1 and a Convoy L2 that could use the drivers.
Lexel
Lexel's picture
New Boost drivers:
Order with those boards made today
1S or 2S Input
6V 5-7A or 12V 2.5-3A output
17mm
20-22mm
23mm special for Klarus XT Series
24-30mm
New generation of high current Buck drivers
up to 40A CFT-90 for BLF GT
up to 33A CFT-90 for TN42
up to 25A 6V v1 or 20A 9V v2 MF01/MT03/MT09R
KawiBoy1428
Lexel wrote:
New Boost drivers:
1S or 2S Input
17mm
20-22mm
24-30mm
!{width:50%}http://www.metronixlaser.de/bilder/flashlight/MF01,MT03,MT09R_Synchr._Bu...!
Outstanding! Way to GO Lexel!
Agro
Agro's picture
Last seen: 1 min 54 sec ago
Supported firmware?
Price?
And where can I buy them? Big Smile
vinte77
Agro wrote:
Supported firmware? Price? And where can I buy them? Big Smile
I second this request
Lexel
Lexel's picture
Firmware as usual NarsilM v1.2 Gigathrower
ramping to 100% also possible
Bistro HD OTSM I have to look into to modify the firmware to have right modes
Prices:
for the Buck 20 and 22mm will be 17.5€
for the 17, 20-22, 23mm and 24-30mm Boost I have to calculate when they are fully tested, but parts costs about 5€ more than the LM3409 buck
for CFT-90 drivers 75-80€ depending on additional current and high current parts
this is not a cheap one just the parts cost more than 35€
