Is it GITD paint? Or tritium?
Yes, GITD powder + tape and yes is the original driver.
So I really want to dip a C8 host (either black or clear) in lye and remove the anodizing after seeing an S41 stripped down that way. I bet it would look pretty cool with kiriba-ru’s custom head.
-I can not send pm to you
The VG10 drawing is good.
Please send me the paymant details :+1: -
edit
in the meantime, succeeded
I have ordered several times from kiriba-ru over the past couple months all packages have been packaged nicely and arrived in a timely manner. Machine work is great and prices are even better. Thanks kiriba-ru I will post some picture shortly.
Is the thread for the tailcap on the BLF Q8 one of the standard ones you can make, or would it be a special unit please?
If possible, I’d like to discuss making a custom tailcap for this light.
I had plans for custom Q8 tailcap, I wanted to make longer one to fit reversed tube in 2S2P mod. I passed this idea. Q8 tail is not something that I would like to made in small quantities.
No problem - thanks for the quick reply!
I finally had a chance to open the package I received a couple days ago, everything was very well protected as usual.
Very nice machining on the s2+ pill, and the thin retaining ring looks like it will have no problem clearing any spring-side component. The X6 spacer fits very snugly in the head.
I received my C8 “turbohead” the other day securely packed as always from kiriba-ru.:
I build it using Nichia 219C D240 4000K 90+ CRI emitters and a MTN-20DDm FET + 7135 Driver with Bistro.
I don’t have a Convoy V2 so I used a Sofirn new C8 host
I does work with the Mini C8 tube from Jax but I would not recommend it because the threads are shorter :
The machining and fit and finish is excellent :
The heat sinking is great, it’s cold and windy in Denmark these days, but I used it 10 minutes on high with a fresh VTC5A walking the dog without it stepping down.
We have a saying in Denmark that translates to something like : “More special than pretty” I think that describes the design very well, but I like it .
The tube with the best fit I think is the Sofirn, maybe I will strip the ano of the tube and tail cap, and bead blast it for a more uniform look
Very unique product thanks for making it avaible, it is by far the most “special” in my collection.
Edit :
I haven’t tested the water tightness other than I used it to break the ice on my dogs water bowl and accidentally dropped it in, so at least in shallow water it’s waterproof.
I received the s2+ pills yesterday. Thanks Kiriba-ru. The shipping only took a week and a half, I was expecting a month or so. Happy camper here.
Got my p60 neck with s2+ pill, p60 quad drop in, and couple s2 triple spacers yesterday. All look great.
Glad to have snagged the last p60 neck. Very unique piece and is going to make a great little (but heavy) light once I get the components in
Got my S2+ spacers today. Really fast with only 9 days shipping. Everything looks great!
This week arrived, as always everything was great. :+1:
Great service. Thanks. Much quicker than I expected and a great price.
Now you can get S2+ pill, P60 shelf or Mag D driver adapter with Convoy retaining ring cheaper than ever.
Do you have pictures, how to use this:
Safe way to mod Q8/SRK 2S2P or 4S DIY kit :
Tail+medium boards for 2S2P or 4S mod (both are oversized (47mm) so you need dremel to sand them down)
4 x brass buttons
4 x springs
8 x M2.5×6 hex screws
$1 set without wrench
$2 set with usa-made 1.5mm hex L-wrench
Recommended to use with a pair of 2.5mm positive driver rings (one goes to the medium board, another to the driver board. Please remember that in this configuration big brass ring is outer (negative) contact while positive pad is inside it).
Head side pcb should rotate together with tube. Driver backside should have same pads, negative contact trough sliding rings, for positive Ive add extra spring and brass button.
I have developed it to work with custom tail (extended legth) and reversed tube. It was wrong way so I stopped this project. I wanted to use tail spacer to make it rotatable:
G30 tail have retaining ring that cant screw down so far that it could disturb free rotation of tail pcb. For 2s2p or 4s connection you dont (Id say wont) use battery tube as electrical connection. My solution is defenetly too complacated. I think you can use pins mounted to tail pcb to fix this it from rotation in relative with cells. [image] [image] [image] [image] [image]
I still dont know what way is right, the only thing I know - I cant look at this q8 drivers with 4 cell pads on backside. In my opinion this is too dangerous even for high experienced modders. Some members suggested another way, when backplate is fixed in stock postion while medium plate is hold by pins that allow free rotation but can be easily removed for cells change.
Once again, I dont know right way, this kit is true DIY, not plug-and-play.
Got my order a few days ago. Great packaging as always.
Thanks! :+1:
Are you willing to supply the XP32 board? (You need them as well for the C8 V2+)
Still thinking about an EE6 triple.
