Here’s what I’ve found with alot of cells. They always test higher then there rated capacity. With a few exceptions. Every 20r, 25r, he2. He4, VTc 3 4 5, the 26650 liito kala cells. That I have purchased and tested. Only the hg2 abd 30q test around 2900-3000 but there typical capacity is 2900 Even the 5200 Evva cells tested at 5500 and the 4200 version was over 4500. It gives them a safety net. If you say 2000 mah cell and it test 1900 some people will complain even though the typical capacity is lower then rated capacity on some cells. It’s better to under rate your product. Like lots of businesses do. How many times have you ordered from Walmart online or another retailer and it says 2 week delivery and it arrives in 4 5 days. You are happy it arrived early. Had they said it estimated delivery is in 4 days and it takes 2 weeks your gonna be pissed. You don’t over promise to your customers. Just like we see on here especially thorfire underrated there lights. The original s70 was putting out over 4000 otf lumens but rated at what 3000 lumens Same with the vg10 and other manufacturers we have seen this with. You don’t over promise and under deliver it’s bad business. Doesn’t matter if you have 99 100%happy customers. That 1 customer who isn’t happy can cause a world of hurt to your company and sales. Bad news travels faster then good news. Shockli and all the big 4 battery makers would be stupid to switch in a lower performance cell. Look at all the flak Efest has gotten through the years for their shady practices. They know their market is mostly technology freaks with equipment to test their product. And most people test their cells when they first get them as soon as a inferior cell would be switched in it would be found as soon as that batch ships. As what happens with efest and imren rewrapped cells. With those two you might get a good cell or you might get a 10 amp or laptop cell with a wrapper saying 20 or 30 amps
Yeah, there are normal variations between batches or even individual cells and it would be bad if they sold a battery as 5900mah if half the time it doesn’t get that.
Also different devices measure the capacity slightly differently, or down to different discharge voltages, or using different discharge currents, so saying 5500 is a safe bet when it can definitely do that or more.
The PLB discharged the battery with 0.2C (1.1A).
With such a discharge, the battery delivers nearly 6000mAh (5900mAh)
The 5700 - 5800mAh, therefore, is not strange to see someone with such discharges.
But above, I saw battery measurements with Opus.
The measurements, however, were during charging.
Opus during charging measures the total current flowing from the circuit.
For the result to be right, it should be subtracted ± 300mAh.
The most accurate measurement to look at battery capacity should be made by discharging.
Hi, I bought these batteries Shockli 26650 5500mAh (top button) a few days ago and I tested them on my 3600 lumen (each) underwater torches. Preaviously I had “common” batteries that didn’t run the cree led (3x XM-L2) at maximum capability; now the difference is clear. I am very happy for the results and I can confirm the very good drainage capacity. These is a real high current cell with very good capacity!
Many thanks to Simon (Marketing Director) for availability and professionalism shown!
Received my Shockli IMR 5500 FLAT top after about 3 or 4 weeks (to arrive in Italy from China).
They were perfectly boxed, with a double battery case and two little magnets to use them in series!
I tried them on my TC20 and worked greatly, now I’m waiting the Acebeam EC50 gen III to be back in stock and try them with it (Acebeam original 26650 battery is not good enough for a 1500 lm or more flashlight…).
P.S. I noticed that they works also in series without magnets :+1:
Capacity test of the Shockli cell I just got from MTN Electronics. Not sure if it’s the same cell as HKJ tested since the wrapper is different. Discharge current: 500 mA.
Thanks. Yeah, the older label looked more professional, IMO.
Also, the mfg stated max charging current is only 2A, so that’s only about 0.35C. Seems a bit low, given the cell’s low IR and overall capacity. Are there safety concerns about charging it at a higher rate, say 3A?
Or is the 2A rate given to maximize the cell’s life?
