does this make a sense?bad cooling…what do you all think about this new imalent? its crazy…lets say useless….or? btw.chinese new year is over?
Banggood say that the HR70 has been ship to me today. :sunglasses:
but I’m very confuse… one guy on reddit had the HR70 and it DIED in several day…!
Any chance of getting a code (better than 20% discount) on the following flashlight?
Astrolux S42 18650 Version 4xNichia 219C/XP-G3 2023LM USB EDC LED Flashlight + INR18650 30Q Battery
M4D M4X,
Now that CNY is over, any chance you can swing a code on a 365nm UV light? It seems people around here like the Convoy, I’m not sure what else is on the market.
i am already poking ...
Hi Martin, just ordered a Rofis MR70 at Banggood. :+1:
Is there any more information regarding the Lumintop ODF30?
Pm sent Martin…thanks
IMALENT DX80
8x XHP70 2nd Generation 32000LM
Outdoor Search LED Flashlight 806M
€U warehouse! (less than 100 available!!)
Code: GEDX80
price: € 178,98
Main features
● Using of high brightness 8pcs CREE XHP70 LEDs with 32000 max luminous flux
● Ultra clear toughened glass lens, the light transmission is up to 99pct with scratch and impact resistant
● Waterproof level up to IPX – 8 ( 2m submersible ) the flashlight can work normally even in heavy rainstorms
● The shot distance is up to 806 meters with wide beam range
● Built-in battery pack includes 8pcs 3000mAh 18650 Li-ion batteries with high discharge performance
● Intelligent temperature indicator, when the body’s temperature is up to 50 Deg.C, the LED display flashes 8 times for 30s to give a warning
● When the body’s temperature is up to 50 Deg.C, the light will automatically adjust the current to keep the flashlight to work under 50 Deg.C
● When the battery voltage is under 13V, the battery symbol will flash 10 times per minute to remind user to change or replace the battery
● 5 common mode: 120Lm, 500Lm, 1500Lm, 5000Lm, 13000Lm
● In any mode, double press the button to enter 32000Lm turbo mode, double press again to enter strobe mode
Hello my dear friends!
march starts with a groupbuy and some nice deals:
as always you can find the codes here: M4D M4X DEALS
Niwalker C11 $31.99 groupbuy
Niwalker MM18JR(72) US$ 155.99
2x XHP70.2+1x XHP35 HI 10000LM Brightness Triple Switch Design LED Flashlight
Niwalker BK-FA30S US$119.99
XHP35 HI 2200LM Triple Switch Design LED Flashlight 1600m Long Range
Sofirn SF36 US$16.36
XP-L V6 1100Lumens 4+1Modes Neutral White Tactical LED Flashlight
Miboxer C4-12 US$33.99
LCD Display USB Rapid Intelligent Charger For Li-ion/IMR/Ni-MH Battery 4Slots US Plug
Miboxer C2-6000 US$25.99
LCD Display Rapid Smart Battery Charger For Li-ion/IMR/INR Battery 2Slots US Plug
Miboxer C2-4000 US$20.29
LCD Display Rapid Smart Battery Charger For 16850 26650 Battery 2Slots US Plug
Miboxer C2-3000 US$17.99
LCD Display Rapid Smart Battery Charger For 18650 26650 Battery 2Slots US Plug
Miboxer C4-12 ordered !
Thanks
Rofis R2 presale for US$43.99
today i can offer you a new presale deal for the:
Rofis R2
XM-L2 U3 700LM Rechargeable Magnetic Charging Head Rotation EDC LED Flashlight Headlamp
Features:
-The head and body of the R2 flashlight are connected by a stainless sreel central axis,the head can be rotated and beam angle can be adjusted as well.(As illustrated in the picture).
-Accurate 45-degree inclined plane;90-degree and 180-degree position;Stainless steel center axis connection;10000 rotation tests.
-Angle surface with non-acute angle design,rotates smoothly;
-Ergonomic rotation design,one-hand operation.
-When R2 is used as headlamp,the user can put into silicone head caps without removing mental clip,which is easy to operate.It would work better with tail cap removed.
-According to the position of the switch and the rotation direction of the head,it is recommended that the user use right hand to press the switch(Put the switch stay towards right above and rotates head into appropriate position to procide lighting).
-With magnetic tail cap,metal clip and adjustable-angle head,it can achieve hands-free operation and procide accurate lightig.
-Battery power detection and low battery power reminder.
-Magnetic USB charging.
-Magnetic base connector supports cttachment to metal objects.
Package included:
1 x Rofis R2 XM-L2 U3 700LM 7Modes Brightness USB Rechargeable LED Flashlight Headlamp
1 x 14500 battery
1 x Headband
1 x Clip
1 x Charging Cable
1 x Lanyard
2 x O-ring
works with 14500 LiIon cells (included) and in case of emergency also with AA NiMh or Alkaline !
use my Code to get $15 OFF: MRFS2
Code for C4-12?
Got a code for LiitoKala Lii 402?
I forgot my pw to login to m4dm4x!
you got mail man! ;)
Martin, you're the best
C4-12 ordered!
Your Q8 code isn’t working now because light is on sale at BG for another day or so. Any idea if your code will work again after it’s off sale? Otherwise maybe I should buy it now…
i am quite sure (but there is no guarantee)
i have this code since the beginning
I was told Haikelight will of course sell their new lineup via banggood.
aaand my code still works :D
(please share my link also when you tell your friends...)
pe | Brand | model = my Link | Code | price (US$) | shop |
FL | BLF | Q8 | M4DQ8 | 46.50 | banggood |
