Ummm, have you walked into a CVS or Walgreen’s lately?
Probably not. But it’s what it does to the little bugs infesting your system that matters.
Silver interferes with a virus’s ability to replicate. It effectively turns off the mechanism which knows where to slice RNA. Kinda like taking a printer with fanfold paper, and screwing up the linefeed count so that each “page” straddles 2-3 pages instead. No (correct) RNA replication, no more virus.
Bacteria, I think it interferes with its metabolism, ’though I don’t recall details offhand.
Hell, for a long time, no one thought there was any use for Se (selenium) in anyone’s body, yet a Se deficiency can be rather nasty. It’s needed in the thyroid, albeit in only trace amounts. A few Brazil nuts could fix it, and then some.
Then again, too much Se can mimic radiation poisoning!
Likely because “doctors” were so ingrained to believe what the mainstream believes, that Ag is quackery.
It’d be nice if there were some open-minded enough to give it a shot. Just have them talk to some doctors in burn-wards…
Thanks for those links about silver dressings. Although you may be tempted to believe that they work because they exist, there is actually mounting evidence that these dressings have no effect on wound healing or infection rates. Here’s a review:
Not to dispute silver’s antimicrobial properties, of course.
I’m a biologist, so I can verify that this is supported by research. However, these experiments are performed in vitro. A test tube environment is not a proxy for testing in vivo effects—living bodies are too complex.
This was discovered in 1957. Suffice to say, science has caught up.
Actually, if someone wanted to perform a blind trial with a sufficient sample size and statistical testing, it would be wonderful. Science can be done by anyone (although the experiment should be ethical). Personal anecdotes are dismissed because they’re just that—anecdotes. They don’t control for confounding factors.
Zinc is an essential element for humans to stay alive, unlike silver. Even so, the evidence on whether zinc lozenges actually do anything is mixed.
Actually, a while back, I had some stitches split open (don’t ask) only 15min after getting sewed up. Didn’t realise it at the time, as cauterisation before and a pressure-dressing after kept me from leaking all over my car-seat. Still, by the time I went to get (what was left of) the stitches taken out, I had a rather deep gaping hole that had to heal from the inside out. To restitch, a plastic surgeon would’ve had to cut even more to make a fresh cut to be able to restitch it, and still there’d be no guarantee they’d hold.
So, a whopping 2mos (8wks) went by, and I still had a gaping hole that I had to dress daily with bandages, and only a month into it was written a scrip for DuoDerm patches. The wise-ass I went to laffed when I was frustrated enough to ask if it’d be another 2mos ’til it closed up, saying it’d be longer. F that!
After taking off the 2nd DuoDerm (about 1wk a pop), I made a batch of c-Ag, and the black ick on one of the electrodes, whether AgO, Ag2O, AgH, nano-Ag, whatever, I slathered into the hole and onto the DuoDerm, and slapped it on.
After 1wk, the hole that was the size of a quarter was now almost a pinhole. Another patch, 2-3 more days, it was completely closed up. Had a black “tattoo” in that area of skin for a few years, but that’s it.
No one is going to tell me that Ag doesn’t promote healing. And that wasn’t just The Power Of My Mind, either (though that’d be pretty kewl…).
Thankfully. Else they’d still be drilling holes in peoples’ heads to let the evil spirits out, or bleeding people to “release the heat from their veins”.
Yaaaay, science!
I know, but was just illustrating a point. Okay, so early cars were feared, “because at speeds more than 30mph, people wouldn’t be able to breathe”.
Yet some people swear by them, and they do seem to work. Me, I never even tried any. I’d rather go for Ag right off.
But if you take Zn supplements, balance them with Cu, and v/v.
I suspect Zn is a “poor man’s Ag” when it comes to colds, etc. Might not kill the little bugs, but makes them quite uncomfortable. Never looked into the purported function of Zn in that regard.
I am trying to accomplish something that is important to me.
And all there is is assorted flavors of rant and BS about something completely irrelevant. I am on one side of that discussion (the rational one), but you are destroying the thread. And if one of you should meet the others on the street and one is a light bluish green, you will have your answer.
And Silver does have a recognized use as an external antibacterial agent. I just remembered. I believe Silver was pumped up urethras to combat STDs. Sort of internal. I believe it was unpleasant.
You need to be careful with the terms far UV or far UVC. Mostly people talking about far UV for these things are actually thinking about 254 nm and above. The effect I am talking about I believe needs to get down into the 207 range to work properly. There is a particularly good absorption window at 207 that optimizes the killing effect. My original post said 207 - 254. I have learned more since then. Some earlier work was done up at 220 - 254, but 207 turned out to be a sweet spot for deadly absorption.
Aside from not hurting eyes and skin, the light should not even be visible to most people. It is outside the visual spectral range of our eyes. Some insects and animals can see it (e.g., bees). So it should not be distracting to anyone working in a area lighted with 207 nm. Like a surgeon looking for just the right place to cut; or having to suddenly find the right place to stick a thumb while yelling for a nurse.
What I need however is diodes that will work at 207 nm. The wavelength is quite specific. This is the particular sweet spot for killing pathogens and not harming humans in the same space. 207 nm emitters are tough to find. I received some feedback from the people trying to qualify this radiation as a human safe source that kills bugs. This means the whole bunch of crap the FDA requires. The research showing the effectiveness of this radiation is, I believe, at least 5 years old. And it is definitive. This should be something on the FDA fast list. Relatively inexpensive. Immediately reducing a 10% infection rate to zero. Vast reduction of insurance payouts and lawsuits for letting the patient get the diseases in the first place. Using 207 nm UVC throughout the hospital could pretty much eliminate infections within the hospital. In the kind of volume this technique could create (hospitals, homes, any building, automobiles, airports, all other public spaces, food handling sites, etc.) this could drive serious production of the required LEDs and associated hardware with a rapidly declining cost.
The kids will not bring the plague (or other diseases[small pox, whooping cough, measles, flu, etc.]) home from school. Taking an Uber does not give you the flu. Touching things in the supermarket does not give you (fill in the blank). And so on.
Potentially way more effective at thwarting the spread of flu than continuing the years long effort (and cost) of developing and distributing flu vaccines. And all the other transmissible virus, bacteria, and fungus. How can this not be an emergency priority effort by the appropriate agencies, researchers, and manufacturers?
The discovers have done experiments which, in my opinion, should be enough for the FDA approval. The numbers I have seen are that about 10% of people having surgery (particularly within the abdominal cavity) wind up with a hospital provided infection. Since antibiotic resistant bugs are most common in hospitals, the scenario gets worse. Survival rate from Hospital Acquired Infection ((HAI) is not good. Current technology simply does not fix this. The UV they use is not permitted with humans in the room.
A POSSIBLE >= 10% REDUCTION IN HOSPITAL INFECTIONS - THINK OF THE HUMAN LIVES AND COST TO EVERYONE.
I am trying hard to find a way to eliminate the 10% risk for surgery. I am old, have a seriously nasty “rip my abdomen open and muck about” problem with a high likelihood or recurrence.
And this solution is plodding through acceptance tests.
Sorry to read about your condition and thanks for bringing up this matter. Quite an interesting read.
One thing i would actually worry about is over using this kind of technology though. If you grow up in a sterile environment you are likely to get sick with about anything if you wander into the ‘real world’… But of course it would be a big improvement for a lot of such applications. I hope it starts to get deployed in hospitals soon.
Yes they make UVC lamps for hospitals. But they are probably working around 254 nm. This is dangerous to people. My understanding is that 207 use is not yet approved by the FDA.
However, a significant factor in preventing surgical infection is the fact that the UVC will blow things out of the air.
In a surgical situation, most (if not all) of the tools and materials being used have been sterilized. More UV can’t hurt, and could improve the results. But a major element of contamination is airborne. Even with air filtration and sterilization protocols. Or a few contaminates from someone’s hair, nose, shoes, fingernails, breathing, and on and on. All these things can be a useful attack vector for UVC (207 nm).
The other application is to provide a localized source to protect the patient from pathogenic crap to be imported by nurses, family visits, food delivery persons, stethoscopes, the bed linen, water cups, blood pressure cuffs, IV insertions, not always really effectively washing hands, unfiltered air in the room, contagion of linen (e.g., would you like a blanket?), bed pans, just touching the bed or tray, and any other material effectively exposed to the surgical site. The potential contamination from just a few little tiny microbes can kill you. The personnel, equipment, the environment are simply not suitably disinfected.
Thinking how to create a completely sterile environment can hurt your head. But it is unlikely will you will figure out and block everything that is trying to kill the patient. And a hospital room simply cannot protect you.
You should consider 222nm lamps for a variety of reasons. We are working towards FDA approval for cornea disinfection.
Also show 99.99% air disinfection “kill-on-the-fly” single pass in an HVAC unit. UVC get’s less than 1%.
Good luck.
Just a note. As noted by Far-UV, I believe 222nm is going to be the target. I have not seen any useful semiconductor products at that frequency That certainly does not mean there are none. Or won’t be. The technology seems to be plasma discharge. This requires high voltage power supplies.
Far-UV. I am curious why the 222 nm radiation has to be approved for such a specific use. From what I have seen there is quite enough research to validate that the 222 nm radiation causes no harm to human surfaces. There are commercial devices outside the US. Why should it have to be approved for each human part in the US?
I am so excited about this technology. Here is a company claiming to have UVC LED capable of emitting any “single wavelength”. optical bypass filters can also be used to narrow wavelength to the desired frequency long as it emittes uv within the range one is looking for. The other factor to control is the intensity of the UVC.
Hi. I have been unable to get my computers to actually work for the last month and a half. One working. Go Microsoft; or simply be sent to Hell.
I am not sure if you are talking about another source or what I have posted. If you have new information; please post a link.
There have been multiple situations with hospitals hiding the fact that dangerous biologics are loose in hospitals (secure treatment areas, simple hospitalization and homes). Bad air is a significant component of spreading the diseases. No satisfactory methods are available for protecting patients, visitors, bed components, room contamination, nurses and other workers marching through the room touching everything. It goes on.
We are activity causing the propagation of human death so pigs and chickens can get big and inexpensive.
Was googling for affordable 222nm bulbs. Most are 254 nm and the search landed me at this forum.
Wan’t going to reply because I need to create a new account.
Then I realized that you did reply to a 2018 thread in 2020.
Anyway, I created the account so that I could reply with this link:
They have a 222nm uvc lamp, but I think their business is to sell expensive products, so it would be costly.
Hope it might be helpful, and hope your health is better now.
Still searching for 222nm products that I can DIY. The 254 nm ones are quite affordable, but I have to be out of the room to be safe.
