Quick question Lexel.
On the BlF GT driver for the MF02 there is one pad for the led on the driver for the switch but there are 2 leds on the switch… So do I put both on the same pad or just pick the color I want to use and go with that one?? Thanks in advance.
I sold one 8A Buck driver for the TN40 that got modded with XHP35s
So the TN40S can be modded as well to 12V Emitters
I guess the carrier needs to be modified to 4S did not find information about it
I have let made 4S boards with last PCB order
You can choose 1 color on the board without modification
Green and red have different LED voltages so only red will light up if you add both
I made new 2x2 LED Boards
you can have 2 LEDs one on Power and one from MCU
Lexel i am interesting for the whole package for MF 02 with stock emmiter (NW)
I want driver for 2.5 amp, cutted battery pcbs (any posibility to send me the battery pcbs with buttons and good quality springs ???) and two color switch correctly wired to the driver)
thanks
The MF02 carrier MCPCB and springs are pretty good quality
It is easy to mod those 2 in less than 5 Minutes
I measured on another Manufactor for the carrier rods diameter for the MCPCB holes and those do not fit the MF02 without drilling holes, but this is reducing the 4 main viases making electrical connection less good
I never had a MK35 light so hard to say if it would fit without getting the driver out and take measurements
technically it is possible to get the brass ring and button on a 46mm MT07S board, but if te inductor and other stuff fits in the head idnk
Hey Lexel, just got around to putting the MF02 driver in, that lame MF02, kicks some ass now, very nice work on this great upgrade of a driver! Makes me want to possibly keep it……
Naw just upgraded the driver in the MF02 to a 4S running a K70 4S carrier I had to shave down the diameter of the PCB’s to fit the battery tube of the MF02.
I have (way too) many 70.2’s, the 1-BLF GT, 2-Thrunite TN42’s, 2-Lumintop SD75’s, 3-Convoy L6’s, 1-Convoy L2, 2-Jaxman X6 Hunter’s, 2-Surefire M3 Combat Light’s, 1-Surefire 900A, 2-Surefire M3 Combat lights I custom made, 2-Surefire 962’s weapon lights, 1-Thrustfire T90-2, 1-Yezl Y3…just off the top of my head, got enough 70.2’s! :person_facepalming:
