Yep you can bypass all springs, even the center spring with out losing the motion to make contact with the other carrier and driver contact.
Melt down…
Added brass center screws… because I had them laying around doing nothing…
Just keep in mind, you want to keep the range of motion in the center contact springs so there will be no issues making contact, the GT could bottom out the center contacts when the battery tube is tightened, the carriers also have to make ground between the carriers and the driver board, if you do the bypass wrong and the contacts are too tall, you will not make ground.
It looks like they dropped it on hard concrete while the box was still wet. I’m guessing Neal will need to send you a new light engine, the lower half of the head.
Kawiboys situation is pretty unique with a fet driver and 6v emitter from a Lumintop SD75.
Still, if I were gonna do this conversion I would not use braided copper as I’ve burned through that at 18A before (maybe get the widest, thickest braid you can?). Would regular copper wire work?
You can send “Neal” a message on here, hopefully he gets back to you soon.
Martin sent out an email to everyone in the GB about a week ago asking if anyone had problems. Reply to that with your problem and it will get added to the list of issues Neal needs to take care of.
It seems that all those badly damaged cardboxes were from the same group of shipment. I noticed that they all have the “lumintop” adhesive tape.
Another group with only minor damages, or no damage, to the cardboxes was sealed with a translucent adhesive tape with no brand name.
Oh.
But you can already get it from mouser without any other contents…just the LED.
The discount from buying multiple units is very small, only a few dollars.
