It is indeed identical to the XP-G3 MF01, other than the branding. See here for pictures: https://imgur.com/a/doRA2 I’m struggling with removing the bezel on this one—I’ll take another crack at it later.
I’ll second that the Amazon “MF01” SEEMS to be identical to a Astrolux MF01. I was lucky to get it for 49.99, ordered last night, free same day shipping, got it today. So I got my original MF01 under the original group buy (XPG3) so it is the first version of it. I compared the lux (ceiling bounce test with Samsung S8) with the Amazon MF01 and these were the rough comparisons:
How long does it stay in Turbo before it steps down? I noticed both my Nicha and Cree V2 versions step down in under a minute. It’s kinda lame if you ask me. No sure if I need to take them appart and replace the thermal material with some Arctic Cooling MX-4?
I could have bought it at $47, but chose not to. I would install a new Narsil based driver regardless. What worried me was the rest of the light. What if it used low grade crappy emitters (fake xpg3) or had an aluminum mcpcb? I would not feel so lucky then.
Exactly. If this light indeed takes shortcuts, I imagine that $49.00 would easily cost you more than getting a legit one. You would be spending money on medication needed for the headache you’ve endured. lol.
Now that 911 light is $71. It seems to be slowly creeping up in price. Maybe they are trying to figure out how high they can go before people stop buying it.
It’s like they are evaluating the market. Maybe SM WORLD is Mateminco’s sales department collecting market research?
HAHAH, yes I do feel lucky. Feel bad for some of you guys who couldn’t get it for under $50 Since Amazon has great return policies, there was almost no risk involved.
To compare with some other lights: (all on Samsung 30Qs)
BLF Q8s (Spring bypassed) couple of them - All within approx. 2000-2250 lx
Sofirn sp32a - 528 lx (Turbo)
BLF A6 (1A) - 497 lx (Turbo)
Some quick differences notes, my MF01 has a single driver spring, that is off center, actually looks sloppy. The 911-L1 is a double driver spring that is perfectly centered. My original MF01 came with a scratch on the lens, the 911-L1 is flawless. Also, tail cap on 911-L1 is fully anodized, whereas the MF01 tail cap has the bare aluminum exposed on the inside ring.
Saw the video, They are both basically the same product, Wish I had jumped on the $47 price, it is now $71 and climbing! Will just keep using the Q8 as my flooder…
As far as I know, the mode 4 and turbo specs of the 911 coincides with that of MF01 V2, relative to that of MF01 V1. The “problem” with mode 4 of MF01 V1 is that it’s ~5000 lumens, and is going to step down quite rapidly to ~2000 lumens, even thought the body of the MF01 should handle more heat/lumens.
The mode 4 of MF01 V2 is ~3000 lumens, and the light is able to maintain this output continuously, at least when I tested it a couple of months ago. So specs wise the 911 (or MF01 V2) has lower output in mode 4 than the MF01 V1, but it is a much more usable output.
I have also tested a turbo output of ~9000 lumens for V2 compared to ~10000 lumens for V1 which again is in accordance with the relative specs of the 911 compared to the MF01 V1.
Time on turbo depends on cell voltage, as turbo output reduces with cell voltage. All I remember is that it steps down quite quickly, something like a minute or minute and a half. If you really want more precise figures, give me a beep, and I’ll fully charge some cells and do tests on both V1 and V2 of MF01 tomorrow, both with Nichia 219C emitters (I thought XP-G3 runs cooler for longer runtime on turbo).
