Speaking of idjits and F1s, I made the mistake of getting 2 more F1s. Flash price was 20bux… for whatever reason I thought it was 10bux each or 20bux total. Talk about idjit…
Anyway, ordered 2 of the same, whatever they were supposta be, whether both CW or both NW.
Zanflare F1 is very good light. It is very simple UI actually. One tail switch to turn it on, another side switch to set mode. Those single switch lights are more complex if you think of it this way.
That happened to me a couple times with the F1! Click the side switch, nothing… screw and unscrew everything… nothing… until i remember there are two switches!
I’ve no recollection of having lost part of my brain though… i guess that’s the idea behind the procedure? lol
Biscotti has a mode group with the maximum output limited to 50%, so you could get an 8 chip model for maximum output when you’re using it, but limit it to the equivalent of a 4 chip model when you lend it to someone.
If you order directly from Simon on AliExpress you can get Biscotti on any S2+, just make a note when you place the order.
Just like a supervillain from an alternate universe, wanting to create a weapon capable of tearing holes in spacetime and destroying our universe! :smiling_imp:
Ok, but how about one that doesn’t require a near infinite amount of money and power? You still get to use some sharp stabby things for those occasions when the urge arises.
Nitecore HC30
Much smaller and lighter than most other options mentioned (particularly the A6,S1,S2+)
5 well spaced modes, starting at 1 lumen.
Great throw/flood combo.
1000 lumens max, well sustained, never gets too hot.
NW option.
Great headband - can be used as headlamp or not.
Mine have been used extensively without a problem.
$35 with coupon
Thanks for the suggestion. I did end up ordering a headlamp, but went with the Skilhunt H03 on impulse without doing much research. Hopefully it does what I want, but if not I’ll be looking at the HC30.
