The XHP70.2 4000k and 5000k MT09R and Acebeam H15 5000k XHP70.2 and none of them had as much greenish yellow as the TC20. The 4000k 80CRI on the MT09R had much better tint. But don’t get me wrong, the TC20 tint is not ugly. I’ve seen much worst. It’s just not as ideal as I hoped for. I still really like the light because it can maintain the high lumens so much better than other lights making it my most practical portable light.
I’m size sensitive - the larger a light the less likely I am to use it. But of course I like large output, and decent runtime. D4 size is great, but runtimes seem absurd, just can’t justify buying it for such a short wow time. I’m guessing that until there’s another large leap in LED efficiency the TC20 is the current king of output/size with high output runtime that’s longer than a joke…
With today’s offerings it can be difficult to choose the right light for balance, we now have choices that skew the parameters far and wide so coming back to a happy medium get’s complicated.
The problem is that for most people only lumens are important. Manufacturers wanting to “meet the requirements” of these customers, install P2 diodes because they are the most efficient. Of course, the color suffers. There are XHP70.2 diodes which have 5000K and CRI 80 and 90. They are N2, M4 and M2 models, but for comparison their performance:
P2 CRI70 1830 lm for 85 degrees
N2 CRI80 1590 lm for 85 degrees
M4 CRI90 1480 lm for 85 degrees
M2 CRI90 1380 lm for 85 degrees
Knowing me, as soon as I get N2 I will make a change
I look for M4, but hardly available to buy.
Mike
Only probably not available from stock. In addition, I see 12V and in TC20 is from what I know 6V
That’s why I wrote “hardly available to buy”
I have a problem with turbo. All cleaned, it drops from circa 8A to 6A in 1 sec.
Any clues?
Mike
12V is merely a matter of which board it’s on and how that board is set up. The XHP-70.2 can be set up to run in 6V or 12V, it’s the same emitter either way.
The chaufer in the study.
Oh, sorry, what multimeter or clamp meter are you using to get that 8A reading? If a clamp meter, what gauge wire for your loop? What cell, and is it fully charged to 4.20V?
Great news, I will be hunting for a super hyper pure white LED
I like the Noctigon or MaxToch 6V MCPCB’s for their heavier trace in the 6V configuration. Since we like powering these emitters up, a heavier trace to carry that current just makes sense… SinkPAD also has a nice 6V version of the XHP-70/70.2 MCPCB. You should even be able to get similar directly from Simon at his Convoy store on Ali Express.
Cell fresh from charger. I use DMM with thick cables I used to measure different 8A+ lights. Only this TC20 show me this amperage drop.
Other cell is on slow boat from China, maybe I will try with 18650 30Q cell I have.
Mike
Mike, I have yet to see a DMM that will accurately measure amperage over a few amps. The UNI-T clamp meters that were in a group buy a while back are good meters and the idea back then was to have as many of us on the same page as possible so current readings would be more standard across the board. I can’t say it’s a fault of your DMM that current drops as you’re describing but at the same time I don’t think I’d trust the reading from the DMM, even a Fluke can’t accurately measure with the stock leads and even if you use heavier gauge leads the sheer length of most attributes to incorrect numbers.
If the long heavy leads are adding to the resistance through the cell then the cell will drop voltage faster than it would tend to in the light, I’ve found even a 6” 12ga lead as a loop in use with a clamp meter causes a drop in lumens on the light box, so every little thing comes into play on these.
Keep in mind that on any cell the driver is boosting the available voltage to the emitter’s requirements, pulling 40-50% more from the cell than goes to the emitter. So a 10A pull to provide 5A to the emitter will definitely put a hit on a smaller cell, any cell for that matter.
I’d like to stress that all lumens readings and all current readings, ALL of them… mine, robo’s, lexel’s, all of them, are the numbers we got at the time from the specific cell to the specific emitter through the specific driver on a specific day. It will change almost every time you take the readings as the cell loses life capacity, as the emitter deteriorates in it’s own life cycle, as heat robs efficiency and so on and so on.
If we got 100 members to order 100 consecutively made clamp meters and 100 consecutively made cells and 100 consecutive made lights and we all also ordered 100 consecutive made chargers… we’d have readings that varied a surprising amount when we tried to compare. Natural variance. It’s unavoidable.
So when we see numbers posted it’s not hard and fast concrete evidence of exactly what you should expect from yours, it’s an estimation of what to look for. Slight variance is expected, large variance can be an indicator there is a problem that needs to be rectified. Sometimes even large variance cannot easily be overcome. It’s the nature of the beast…
Dale, I measure mine triple nichia S2+ and shows 9A on the same DMM, no drop. TC20 drops after 1s after switching turbo on.
I can see and measure light intensity drop with or without DMM involved.
The question is: is it a torch or battery related?
Mike
That sounds like what mine was doing after I cleaned the light contacts and cell ends the first time.
Go back and reclean the cell ends really good and also any points of contact such as the tube ends , brass ring inside the head , threads , springs , and rub the mess out of them. I was surprised to find what the second really good cleaning did on my light.
I can almost guarantee that a clamp meter would show significantly higher current readings than your DMM. Seen it hundreds of times. I soldered 12ga leads into the V sockets of my DMM to make it impossible to use my DMM for current. lol I have 2 clamp meters now, they are both usually virtually spot on with each other on current readings.
Try like robo says and double check your cell contacts, you’ll probably find gains by doing so.
Dale, I measure light drop (I see it also) on turbo without any DMM connected.
Just tested with 30Q cell, drops too, so cell excluded.
It is not go from turbo to lower mode, just dims.
Mike
I bought two LEDs from Simon and I was satisfied so I can buy something from him again.
