M4D M4X deals NEW: Amazon deals // Astrolux FT03 Mini $30.99 + accessories // FW21 PRO
5137 posts / 0 new
M4D M4X
M4D M4X's picture
Last seen: 6 hours 34 min ago
i work on that Wink
 all new deals are posted here:
deals.m4dm4x.com
ask MARTIN@M4DM4X.COM - i will try to save you money!
Wrathbringer27
Wrathbringer27's picture
Last seen: 2 days 1 hour ago
Thank you Martin! Smile
Words can be broken,
so can bones.
vinte77
Last seen: 6 hours 2 min ago
Martin, is it possible to get a code for the Manker U12?
M4D M4X
M4D M4X's picture
i  negotiating with them to find a wa
deals.m4dm4x.com
scrumpypaul
scrumpypaul's picture
Last seen: 11 hours 2 min ago
Hi Martin, are you able to get a code for the Klarus Mi1C in copper please?
Paul
M4D M4X
M4D M4X's picture
i have one since the light can be bought Wink
mail me if you want it for 36.82 Wink
deals.m4dm4x.com
doubleone44
doubleone44's picture
Last seen: 11 months 5 days ago
Any update on the colored astrolux S1?
vinte77
Thanks, Martin.
M4D M4X
M4D M4X's picture
deals.m4dm4x.com
M4D M4X
M4D M4X's picture
Hello my dear friends!
do you know and follow my facebook pages?
i run two giveaways there and you can participate in both ONCE PER DAY to increase your winning chances Wink
GAW on M4D M4X Deals and Reviews
GAW on M4D M4X Gadgets, RC and Home
GOOD LUCK!
deals.m4dm4x.com
scrumpypaul
Thanks for the code for the copper Klarus Martin – ordered and shipped!!!
Paul
scrumpypaul
Martin,
Are you able to get codes for smart watches such as the Amazfit Bip?
Paul
M4D M4X
M4D M4X's picture
i get codes for nearly everything sold by gearbest and banggood Wink
just mail me the link
martin@m4dm4x.com
deals.m4dm4x.com
CoolJB
Last seen: 3 months 2 days ago
Grabbed a second Imalent HR70 using your deal M4D M4X. Thanks again!
M4D M4X
M4D M4X's picture
deals.m4dm4x.com
M4D M4X
M4D M4X's picture
deals.m4dm4x.com
M4D M4X
M4D M4X's picture
deals.m4dm4x.com
vresto
vresto's picture
Last seen: 7 hours 36 min ago
these Basens are good? quality…looks like Litokala..
EDC...no one yet
Headlamp-Thrunite th30
M4D M4X
M4D M4X's picture
deals.m4dm4x.com
M4D M4X
M4D M4X's picture
new Fitorch deals: M30R & P26R (with free cell)
i managed to get two new deals for Fitorch flashlights:
Fitorch M30R
XHP35 HD 1800LM 6Modes Dimming USB Tactical LED Flashlight & Mobile Power Bank
find the deal here: M4D M4X DEALS or ask me…
(pictures links to the shop for further info and specs)
Fitorch M30R XHP35 HD 1800LM 6Modes Dimming USB Tactical LED Flashlight & Mobile Power Bank
Fitorch P26R +Fitorch 26650 Battery
XHP70.2 3600Lumens FCD Rechargeable Portable LED Flashlight +Fitorch 26650 Battery
CODE: MIHB2 drop the price to US$59.99
Fitorch P26R XHP70.2 3600Lumens FCD Rechargeable Portable LED Flashlight +Fitorch 26650 Battery
deals.m4dm4x.com
Timeey
Last seen: 11 months 3 weeks ago
Interested.
Code
- Skilhunt H03F RC , H03R RC
- HC65
- P26R
Please. Thank You.
Flashlight
M4D M4X
M4D M4X's picture
today i got a not deal for a great multi purpose light:
Rofis R3  only $56.99
XM-L2 U3 1250LM Magnetic Charging Adjustable-angle Head LED Flashlight Headlamp
Brand
model = my Link
Code (copy/paste)
price (US$)
Rofis
R3
0cad0e
56.99
Features:
-R3 is an innovative multifunctional magnetic charging LED flashlight with adjustable-angle head.
-Utilizing the XM-L2 U3 LED,it delivers the max output of 1250LM whten using 18650 Li-ion battery,compatible with 2*CR123/RCR123A battery .
-The head rotation structure combines with non-acute angle design stable and reliable,the head can rotate freely.The flashlight designs with magnetic tail cap and mental clip,it is conwenient for multifuntional use.
-With compact size.it can be used as headlamp while using with headband.
-The head and body of the R3 flashlight are connected by a stainless steel central axis,the head can be rotated and beam angle can be adjusted as well.
-The hard surface is made of aero grade aluminum alloy,premiun type III hard-anodized anti-abrasive finish.
-When R3 is used as headlamp,the user can put into silicone head caps without removing metal clip,which is easy to operate.It would work better with tail cap removed.
-According to the position of the switch and the roration direction of the head,it is recommended that the user use right hand to press the switch(Put the switch stay towards right above and rotates head into opproprate position to provide lighting).
-Angle surface with non-acute angle design,rotates smoothly;Ergonomic ratation design,one-hand operation.
-R3 comes with a detachable metal clip,combining with head rotation function,which enriches its usage scenarios.
-Powerful magnetic tail cap,can be attached to metal object,combining with head rotation,the application scenarios of R3 is greatly expended.
-With a set of high efficient constant current circuit,constant brightness,no flicker.Automatic contral of turbo mode,prevent from overheating.The built-in circuit has overdischarge function so as to take full use of battery capacity.
-The brightness range from 0.25LM~1250LM.It will meet the brightness demands in different environments.
Charging Indicator:
-Red light keeps on,means charging.
-Green light keeps on,means charging is completed.
-Red and green light blink alternately,means incorrect battery installation or no battery exists.
USB Magnetic Charging Funtion:
Parameters:Charging current:1.5A.
Charging time:about 3.5 hours.
(Note:Built-in ROFIS 18650 3400 mAh lithium-ion battery)
Battery power detection and low battery power reminder:
-Battery power detection:
After installing battery and screwing on the tail cap,R3 will automatically detects remaining battery power.
The green power indicator keeps illuminating about 2 seconds,which means that the battery power is more than 40%.
The red power indicator keeps illuminating about 2 seconds,which means that the battery power is less than 40%.
-Low battery power reminder:
With the light on,when the battery voltage is low,the red indicator will blink every second to alert user that the battery power is close to depletion and we suggest to charge battery promptly.
Package included:
1 x Rofis R3 XM-L2 U3 1250LM USB Magnetic Charging LED Flashlight Headlamp
1 x 18650 battery
1 x Headband
1 x Clip
1 x Charging cable
1 x Lanyard
2 x O-ring
Rofis R3 XM-L2 U3 1250LM Magnetic Charging Adjustable-angle Head LED Flashlight Headlamp
deals.m4dm4x.com
M4D M4X
M4D M4X's picture
deals.m4dm4x.com
CM2010
Last seen: 7 hours 15 min ago
K30 ordered, thanks.
Timeey
Interested L30.
Flashlight
M4D M4X
M4D M4X's picture
NEW code available for
another 10 USD drop Wink
deals.m4dm4x.com
Timeey
Interested Acebeam X80 , L30 , K30
Thank you.
Flashlight
M4D M4X
M4D M4X's picture
I got new (lower) prices for them
I pm you asap
deals.m4dm4x.com
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 11 hours 25 min ago
Hi Martin,
Do you see any chance to get coupon codes for following AceBeam flashlights, too?
AceBeam K70
https://www.banggood.com/Acebeam-K70-XHP35-HI-2600LM-7Modes-Brightness-LED-Flashlight-With-Long-Distance-1300meters-p-1268408.html?rmmds=search&cur_warehouse=CN
AceBeam X65
https://www.banggood.com/Acebeam-X65-XHP35-12000Lumens-7Modes-AC-Adapter...LED-Flashligh-p-1261167.html?rmmds=search&cur_warehouse=CN
Thank you!
“Everyone, deep in their hearts, is waiting for the end of the world to come.” (Haruki Murakami, 1Q84)
M4D M4X
M4D M4X's picture
sure Wink
as soon as they are ready to preorder
deals.m4dm4x.com
