I just noticed our neighbor has a smaller version of that same styled light.
I asked him where he got it and he told me found two of them in the basement when he bought the house!
He rebuilt his back then and it’s been find ever since. I noticed he had a “filament” LED in his, looks real nice.
I know all of this is sort of off topic, but at least it is a bump for the thread
Our replacement fixture is definitely commercial and it is wonderfully made. All pieces are cast aluminum and the top is even hinged for easy access.
Here is a peak inside looking down on 5 - 1600 lumen bulbs
The old fixture at our front door bit the dust too. Solid brass, someday I will strip it of paint and polish it up. The socket went bad along with the wiring. To the right, the old post light.
Awhile back I caught an awesome deal at Lowes for a light fixture of the same style as our original post light and I grabbed them all. I used 1 to replace our old front door fixture. I think they went on clearance because they took candelabra style bulbs and nobody wanted them. I know I didn’t back then. My intention was to convert them over to E27 sockets.
That all changed when the new “filament” style LED bulbs came out and I was able to get some at Costco in candelabra style. Here is a cheap Lowes fixture with 2 LED’s at our front door. Same style as the post light. I was even able to get a matching style light for the alcove. It can be seen hiding in the corner of the picture.
Anybody that knows me, also knows that I have the tendency to over buy when I come across a deal. Out in the garage I have a stack of 3 more of those fixtures. The arrow on the right pointsto the price I paid, $5, no wonder I bought all 4 they had.
…I tell you that you’ll probably never find another…and you come back with the fact that your neighbor has two…and that you bought a whole slew of them for $5 each… I have never seen one like that of solid brass although we had a black one at our house growing up exactly like yours.
My problem with the 150 watt Morris light (above) now is figuring out how to wire the ‘dimming’ feature that supposedly is part of the inner workings:
Dimming - PWM/TIME/0-5V/0-10V
…not to mention sourcing a ‘dimmer’ I’m guessing at an industrial electrical wholesaler.
This application won’t be under a flying gable where it is much less obnoxious. I’d like to be reasonable in terms of what this thing will look(glare) like 25-30 feet in the air where I’m second-guessing that side shades won’t do me any good.
I just couldn’t pay the same amount of money for less lumens as I don’t believe that they cost much less (ok, I just couldn’t bare to have any less light than I have out front and you just have to see 30 years of pitch dark turn in to day to believe it).
I ended up at ProBuild (great service) and ordered a 28’ x 5 1/2 x 4 9/16 laminated (untreated) post for $157 OTD/delivered. I’ll try the old method that we used when putting up lights outside the commercial buildings we built: two short poles set in the ground with concrete straddling the middle (main) pole set on the ground with two threaded rods drilled through all three (one for the pivot; one for the ‘lock’).
If I could figure out the Dimming feature included in the ballast– “PWM/TIME/0-5V/0-10V” I could probably find a schematic somewhere to add a long range motion detector and a dusk to dawn control (wish that they sold all three as a package).
“…You have to be smart than what you are working with…” the old geezers used to say.
…woke up in the middle of the night worrying about beam adjustment using the pole style that I picked and overhung weight versus the trunion mount version 28’ up. It turns out that they are the same concerning the latter. There is no adjustment on the pole style yet I don’t see anything else that is (cough) ‘outdoor rated’ so we’ll just have to see how this one holds up to mother nature with a little silicone everywhere to help.
Back to bed…
Welllll….I’m back to the original (adjustable) trunion mount after finding out that the pole mount is obsolete and will be replaced in 60 days. At least this company is advancing with next generation models which is always a good sign. I found another light with similar or even better specs. (3000K) yet it is over 8# lighter and doesn’t look like it has the more defined cooling fin design of the Morris product. https://www.superbrightleds.com/moreinfo/led-flood-lights/150-watt-high-power-led-flood-light-fixture/3568/#tab/Specifications
I’m guessing that any solar (battery driven) unit which could maintain 150 watts would work. As for motion capability I’m guessing again that I will be able to study any common wiring setup of at least the same wattage and swap out any detector to adapt. A lot of guessing…yet my main concern is finding someone who can explain the dimming system to me (above) so that I can incorporate a dusk to dawn accessory as well.
My ‘unicorn’ seems to be a plug and play, long range (preferably) motion detector with dusk to dawn sensor and compatible dimmer which doesn’t seem to be possible given the feedback here to date.
I’m a little surprised that more aren’t in to high lumen/low Kelvin lights of this size as they are the tiny ones costing much more.
Thank you so much my friend. After struggling with MegaDepot to (finally) get this light ordered today, your help will (finally again) allow me to finish this project less the long range motion detector.
RAB used to make (stupidly expensive) detectors which I swore by until every single one of them eventually failed/took out the (500 watt halogen) lights with them. I’ve never ran in to anybody else who used these and hate to throw them away lest they be fixable (100 foot range believe it or not).
Morris has obsoleted a number of their lights of late and has moved on to mounting configurations requiring a second accessory mount to be purchased. The good new is that they are apparently trying to improve what are some very low Nema beam angle numbers in their area lighting line.
Whether this will translate in to significantly higher prices is anybody’s guess. The first lights will(?) appear in May with higher NEMA numbers and supposedly be followed with even higher angles by the end of the year.
I’m happy with the promised improvements yet didn’t realize how low that these Nema numbers were in the first place due to where my first light was mounted under a flying gable.
I think that they told me a ‘4’ by May and a ‘5’ by 2019 yet I need the latter (minimum) up on my 28’ pole and will probably start looking for a ‘7’ if I can find one in 4000K or less.
…btw…I realize that after 5 months of asking the same question (see the title of this thread) that there probably is nobody out there other than Morris pushing $200 delivered lights with these specs.
The next step up to get this project back on track?
I’m not sure that I want to know. :person_facepalming:
If these aren’t the same Morris lights (they say ‘Best Lighting’ which don’t seem to carry them or manufacture them anymore here in the U.S.http://www.bestlighting.net) the housings are pretty much look a likes.
Initial thoughts (I saw these for $160 online):
Is the massive drawdown in output over time (see the last column) due to the quality of the chips here or did I simply miss the boat somewhere in that this is ‘common’ in LED arrays of this nature?
There is very little information in terms of the beam pattern and the amount of light shown (where) as compared to Morris. https://www.lightbulbs.com/catalog/product_pdfs/morris/71833-Spec.pdf. This will be a real crap shoot in terms of wondering what it will illuminate on a 28’ pole (65’ isn’t much; yet spill is obviously what you’re after).
No lumen difference between 4000K and 5000K at 150 watts despite the obvious in other sizes.
Frustrating that there isn’t anyone out there (on here) who plays around with these things or who applies them on a daily basis.
I would pay the extra money (within reason) to get what I want yet there seems to be no middle ground between these lights and near insanity in terms of price…and what is the ‘gold standard’ in the (non-fake LED) area lighting market anyways?
I’m hoping that this will be the best selection for my application (save a much higher number NEMA scale beam angle) a 28’ pole situated close to the house on the other gabled end. The light will try to illuminate what the other gable light does not (side yard) and the other end of the house
The whole interchangeable lens concept took me by surprise as I was certainly hung up on the previous NEMA beam angle numbers mentioned and probably never getting what I was after. This one came in at $236 (I didn’t shop around).
We’ll see what happens…
I finally managed to hook the 15,500 lumen Westgate up using an extension cord on the second story porch so that I could judge where I wanted it to point on the 28’ pole. The Type 2 beam pattern is pretty much as advertised (oblongish). The coverage is hard to judge at 13’ with a deck below your feet yet I’m pretty impressed. The tint seems even better than the Morris and seemingly more natural. The overall brightness seems less (as advertised) yet the other one is 30’ up so I have no idea. The beam patterns will probably overlap a bit so we’ll see.
Light years different (better) than any other yard light that I’ve ever owned or installed. i like the idea of the remote operated motion sensor with dimmer yet I’ve not been quoted it and I’m not sure that I want to part with the coin. Might just go dawn to dusk at only 150 watts yet even a cheap timed motion control has its advantages.
Again, I was just as skeptical this time around regarding any 3000K claim as I was with the Morris. It sure beats the halogens, sodiums and halides.
Thanks my friend. I follow your adventures as well and learned in the process. Too many projects this spring so I decided to bust my finger all up and put them all on hold. It will get up on that pole laying in the driveway (still) soon enough as I’m eager to see what it looks like. Cutting the cable and going back to the antenna/simpler days of old right above this new light is a motivator in and of itself.
We’ll see…
…in the meantime, I went to Home Depot and picked up 2 small socket extensions. I had previously purchased a 100,000 L corncob at Menards on a whim (sale price was $52 if remember). Screwed all 3 in to a standard two bulb floodlight style motion light (had to support it a bit at the fixture deflector’s edge) This should get me by until I’m all healed up and the Westgate can (finally) shine.
…I would say that a 100,000 lumen corncob might not be the most efficient way to light up an area but that it does the job in a pinch. Directional shielding or just plain shieldng your view of it is obviously needed. It throws light a lot farther than expected and some nice shadows in terms of any movement through the coverage area.
Lost all sense of reason/frugality/(not to mention) pledges made and purchased the following today:
(1) PN# SK618-601X outdoor rated control which senses motion (turns on/off and has an adjustable timer), is remotely dimmable and which can be manually controlled (off/on) through PN# SK618RC. The remote is evidently RF controlled and should go through walls.
The above was what I was told these two part numbers would do for the Westgate light above.
